Question about Hard Computers & Internet
I have a clover DV0890 security recorder, it's making a audio alarm sound inside box. on screen it says hard disk error and battery error.no disk. battery inside is a pancake type, coin type
  • Hard Master
  • 10,291 Answers
Measure the voltage on the coin cell first. If it's low replace it. That may take care of the Hard disk error too. If it doesn't, then the hard drive may be bad. Don't replace it with any hard drive. Look for one rated for CCTV video. It's built to last longer that an ordinary Hard drive.
Posted on Dec 21, 2016
  • Kevin Savisky
    Kevin Savisky Dec 22, 2016
    i replaced the battery no luck, will have to order new hard drive thanks for your help.
Have an error message on screen sayng NO HDD???
The system does give this message when the logic board can't access the Hard Disk.
Can be anything, from a complete over filled HD till a defect controller or just a corrupted first sector. Check what the user manual says about initialise the hard disk. If that won't help, consult a tech close to you. Btw. after an initialise or format you will have lost everything you recorded till now. So if something important is on the disk, ask a tech to get out the drive and recover the important stuff. This could cost you.
Mar 30, 2015 | GW Security Professional 4 Channel 1t Hdd...
I lost password clover tft2284c
Call the manufacture and see if they have a back door code. If not the only way to reset it is to send back to the manufacturer
Sep 03, 2014 | Clover Corporation CLOVER TFT2284C 22...
RESET A PASSWORD ON A CLOVER SECURITY SYSYTEM
remove motherboard battery 5 minutes ... reinstall ... causes checksum reset ... default passcode for most is 11111111 eight ones ... done ... enjoy!
Oct 02, 2013 | Clover Corporation Clover 17" CCTV...
Camera has fuzzy screen
Make sure the lens is clean and properly focused.
Aug 31, 2012 | Clover Corporation Clover Oc9602 Wisecomm...
Have a sony HDC 100 which is playing up, can't switch off, Has permanent Welcome display and makes a slight beeping sound every now and then. Is there a way I can fix?
Try removing the battery to force it to shut down, then fully recharging the battery and replacing it in the camera. This is known as a hard reset and may force your camera to reformat the part of its memory that is causing its unusual behavior.
May 06, 2011 | Clover Corporation CLOVER HDC365 1/3 inch...
Before formatting my laptop i transwereed all my data to my external hard disk. after formatting when i trnswering the data from hard disk to laptop the error comes redundancy check error mostley in...
Hi jrawat7,
A Cyclic Redundancy Check, known as a CRC error, often occurs when you're attempting to transfer data to a hard drive. It's most commonly caused by an interruption in the recording process, but also can be a sign that you've got problems with your hard drive or optical drive.
Here are some steps fixed the issue:
Rule out problems with your computer Start by Defragmenting your disk. Click the Windows or Start button in the lower-left corner of your computer screen and select Control Panel. Click the System and Security icon. Choose Administrative Tools, then Defragment your hard drive. This will clear up clutter on your hard drive that could be causing the error
Use the CHKDSK program in Windows to see if there are other problems with your hard drive. Click the Windows or Start button and select My Computer or Computer. Right-click the drive with the CRC error. Choose Properties, then select the Tools tab. Click Check Now. Make sure the program will fix disk errors by checking the top square in the dialog box. Click Start.
Don't Forget to say Thanks. Thanks for using Fixya.
Feb 05, 2011 | Computers & Internet
I am getting the data error (cyclic redundancy check)
A cyclic redundancy check, known as a CRC error, often occurs when you're attempting to transfer data to a hard drive. It's most commonly caused by an interruption in the recording process, but also can be a sign that you've got problems with your hard drive or optical drive.
  • Rule out problems with your computer Start by defragmenting your disk. Click the "Windows or Start" button in the lower-left corner of your computer screen and select "Control Panel." Click the "System and Security" icon. Choose "Administrative Tools," then "Defragment your hard drive." This will clear up clutter on your hard drive that could be causing the error
  • Use the CHKDSK program in Windows to see if there are other problems with your hard drive. Click the Windows or Start button and select My Computer or Computer. Right-click the drive with the CRC error. Choose Properties, then select the "Tools" tab. Click Check Now. Make sure the program will fix disk errors by checking the top square in the dialog box. Click Start.
  • Thanks for using Fixya.
    Jan 31, 2011 | Western Digital My Passport Essential...
    The box is making a sound like its rewinding.
    sounds like the harddrive is going bad , its the only moving part inside.
    Oct 11, 2010 | Clover Corporation CDR-4070 Video Recorder
    How to reset house alarm after power cut
    alarm may be in battery back up mode when power is lost it will automaticly start running off these batteries that are usually located in the panel. diffrent devices have diffrent ways or restoring regular mode. i would contact the maker.
    Feb 27, 2010 | Lorex 4 Channel Business & Home Security...
    Where do I get parts for a tlv1280a security vcr
    www.mcmelectronics.com They sell parts for electronics and componits.
    Oct 16, 2009 | Clover Corporation Clover Electronics...
    Computers & Internet Logo
    47 people viewed this question
    Top Hard Computers & Internet Experts
    john smith
    Nyte_Ryder
    gbob59
    Are you a Hard Computer and Internet Expert? Answer questions, earn points and help others
