Question about Cell Phones
I have a Plum Boot 2 and with bluetooth paired it to my car. However the contacts will not download, what do I need to do
  • 75 Answers
SOURCE: phone won't stay paired w/bluetooth
may be software problem..or make sure that your phone is visible for other devices..
Posted on Dec 13, 2008
  • 638 Answers
SOURCE: Have new Samsung Alias 2 that won't pair to my
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Posted on Jan 05, 2010
ZJLimited
  • 17970 Answers
SOURCE: thx for advice but i
I found this welcome surprise after the 3.0 iPhone software upgrade a couple months ago...
Problem: I had too many contacts on my iPhone syncing with my car making it tough to scroll to my desired contact.
SOLUTION: Setup a 'GROUP' in your iPhone's Contacts which lists only those people you want to have available while in your car; Next, goto Settings, General, Bluetooth, MB Phonesystem (or your Bluetooth name) and choose the GROUP you want synced.
The new setting will take effect the next time you sync with your car (you might have to restart bluetooth on your iPhone to make the selection stick).
Hope helps.
Posted on Jan 28, 2010
award462
  • 395 Answers
SOURCE: when pairing my Emerson bluetooth for my car it
Refer to this tip.
http://www.fixya.com/support/r5008953-pin_codes_most_bluetooth_headsets
Posted on Jun 02, 2010
patrick_dier
  • 310 Answers
SOURCE: nokia2600c-2 trying to download pictures to laptop.laptop bluetooth pairs with phone.how to get phone to download
nokia 2600 has only black and whit colors for pictures
Posted on Jul 26, 2012
How do I get my contacts to download to my car?
when you pair your phone to the car using bluetooth, the car will display the contacts.
Mar 11, 2016 | Cell Phones
Bluetooth paired but not coneected
How to pair and then connect to a Bluetooth device on your T-Mobile G1 Google smartphone.
1. First, ensure Bluetooth is enabled.
2. From the Home screen, press Menu.
3. Select Settings.
4. Select Wireless controls.
5. Select Bluetooth settings.
6. The G1 starts searching for Bluetooth devices in range. Select the device when it appears.
7. Type the PIN for the device.
8. The device should then pair with the G1. You can then select the device name to connect.
Bluetooth only supports ad2p profiles for headsets, music, and sharing of contacts and pictures. This is limited by VZ. Until the phone is rooted, there is absolutely no way around this. You cannot send files other than contacts and pictures via bluetooth.
It sucks... I know. I am in the same boat. I am [im]patiently waiting for the droid to be rooted so I can use bluetooth to share files between two droids.
Feb 24, 2012 | T-Mobile G1 Android HTC Google Smartphone...
Is h350 compatible with windows vista? i try installing one, i easily paired it with my compaq laptop windows vista os without asking any passkey. the problem is it would'nt work. i downloaded a bluetooth...
I've successfully paired this headset with Vista but only for Skype. In Control Panel set the Bluetooth discovery and it should pair OK but then you need to run Skype which will find the headset and ask if you want to use it. The solution is a bit temperamental because the microphone volume is usually either low or there is too much background noise.
Feb 01, 2011 | Motorola Mobility H350 Wireless Headset
Need to transfer files to mac
You can follow this steps for your concern: Via Memory Card 1. Remove the memory card slot cover, located on the right side of the unit. 2. Insert a microSD memory card into the memory card slot until it locks in place 2. On the SGH-i607, navigate to the folder that contains the image 3. Highlight the desired image 4. Press the right soft key for Menu 5. Select Edit (4) 6. Select Copy (2) 7. Navigate to the Storage Card using the up or down navigation keys. 8. Press the left soft key for Select.to copy the image to the memory card Via Bluetooth On the SGH-i607 1. While in standby mode, turn Bluetooth on 2. Switch the Bluetooth visibility to On On the PC 1. Connect the Bluetooth adaptor to the PC?s USB port 2. Search for Bluetooth devices 3. Select the device to pair with the PC 4. Exchange PIN code(s) on both the PC & handset to pair devices (default pass code is ?0000?) 5. Using My Bluetooth Places, select File Transfer or OBEX to view the phone?s contents 6. Copy the desired Photo file 7. Paste the file in a PC destination
Feb 02, 2010 | Samsung Blackjack SGH-I607 Smartphone
My RAZR V3 won't pair with 2009 Chevrolet Silverado bluetooth
http://www.gm.com/vc/bluetooth/index.jsp?brand=chevrolet&landing=true
PAIRING A PHONE WITH YOUR 2009 Silverado
Before you begin:
To take advantage of the Bluetooth for Chevrolet functionality, you must first pair a Bluetooth-enabled phone to a Bluetooth-enabled vehicle.
Note: If you do not pair a Bluetooth-enabled phone, all calls will be made using OnStar® Hands-Free Calling.3
Some additional tips:
1. You can pair up to five phones with your 2009 Silverado.
2. Your system automatically recognizes the first phone you pair. To use a different paired phone, you must
select it using the "Change Phone" command.
3. Only one paired cell phone can be connected to your system at a time.
4. When the vehicle is in motion, you cannot pair a phone.
5. Pairing should only need to be completed once (unless changes to the pairing information have been made, or the
phone is deleted).
PAIR YOUR PHONE
Set up phone - Turn Bluetooth 'ON':
1. From the main screen, select "Menu"
2. Select "Settings & Tools"
3. Select "Connections"
4. Select "Bluetooth"
5. Select "Setup"
6. Select "Power"
7. Select "On"
Set up vehicle - Enter 'Pairing' mode:
1. Press and hold the Push to Talk button for two seconds
2. Your system will respond with a "Ready" message followed by
a tone
3. Clearly say "Bluetooth"
4. Your system will respond with a "Bluetooth ready" message
followed by a tone
5. Clearly say "Pair"
6. Your system will respond with instructions and a four-digit
Personal Identification Number (PIN); you will need to enter
this PIN on your phone
Begin the pairing process on your phone:
5. Select "Hands free"
6. Select "Look For Devices"
7. Select "General Motors"
8. Select "Yes" to bond with General Motors
9. Enter the PIN code provided by the vehicle
10. Select "OK"
Finish the pairing process in your vehicle:
1. The system will prompt you to give a name to your phone
2. Say a name that best describes your phone (example: Corey's
phone); this name will be used to indicate which phone is
connected
3. Your system will ask you to confirm your name
4. If you confirm that name, the system will respond with the
message: "'<Phone name>' has been successfully paired"
Sep 04, 2009 | Motorola Mobility RAZR V3c Cellular Phone
How can i reactivate my blueant blue tooth on my motorola ic902?
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 22, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Just bought a iPhone 3G and i have a BlueAnt Supertooth light and the iPhone isn't discovering it...help?
Supertooth Light.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 15, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Transfer Contacts to Pioneer Bluetooth CD-BTB200
if your 8300 is bluetooth capable then all you need to do is pair the 2 devices and transfer them maybe one by one
Nov 24, 2007 | LG VX8300 Cellular Phone
Address Book - Manual entry
You have to first pair your phone with the head unit. After that is successful, unpair it on your phone, but keep the bluetooth on. Go to individual contacts, and select "send using bluetooth". If the contact transfer is successful, the phone number will appear in the Phone Book list on the head unit, the next time you pair it.
Oct 31, 2007 | Kenwood KCA-BT100 Wireless Headset
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
