Question about Watches
How to set new date of month on watch
Can not set new date oday on watch tried using side mount to no purpose
    Top Expert:
  • Watches Master
  • 8,374 Answers
How to change date on a watch?
Pull out the crown to the second click, and advance the hour and minute hands until the desired date and day appears. * If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock. 5. Adjust the time by turning the crown in the desired direction.
Instructions for Analogue Quartz and Mechanical Watches - Seiko
https://www.seikowatches.com/support/ib/pdf/Analogue_E.pdf Search for: How to change date on a watch?
How to set new date of month on watch Google Search
Posted on Dec 21, 2016
  • NOEL
    NOEL Dec 21, 2016
    thank you
I have an Armani watch ar6049. The date goes way past 31 to at least 35. I have never seen a watch go past 31, what gives??
There are Mondaine watches that do the same thing. I believe that it's because the date display is actually two separate disks, each reading 0-9. Most date watches only have a single large disk for 1-31. Although your watch is capable of displaying, for example, the 33rd of the month this doesn't happen in practice as the logic built into the watch prevents it.
I assume that using 2 smaller disks to display the date, rather that 1 large one, is for design purposes - possibly it would get in the way of additional hands or other features on the watch.
Hope this helps.
Sep 02, 2017 | The Watches
How can I set the date on my watch? I could set time and alarm but I couldn't set the date .
Hi ajcruz_h,
To set the digital time and date on your Timex, please follow the steps below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Mar 04, 2011 | Timex 1440 Nylon watch
How to set time on a 1440 timex watch
Hi tsgoode99,
Timex Digital Watch
Hope it helps.
Dec 25, 2010 | Timex 1440 Nylon watch
Fix date n month on wrist watch
mcdevito75 here The stem has 2 positions, we all know the 1 to pull the stem out and set the time, day, date. try this, first go thru the watches 24 hour cycle to get the month you need, now slip a fingernail just under the stem (crown) and gently lift to it"s first position, it may take a few times to get used to, when you have it turn the crown (stem) to change the date easily, change the date to 1 date before the date you want, now go thru the watches 24 hour cycle to get to the date you need. Now the watch is set and will change on time at around mid--nite.
Jul 19, 2010 | Pulsar 5117 Wrist Watch
I cant set the right date on my timex 1440 sports watch
Hi travislietha,
To set the right date on your timex, please follow the instructions below.
Hope it helps.
Jun 28, 2010 | Timex 1440 Nylon watch
I have a etica watch au9101 I don't know how to set the month and if it takes a battery when i got the only thing I got was a 5 year warranty card with ( no owner manual) Thank you
As I can see from the picture here:http://www.etica.ch/banner/AU9101.jpg your watch do not need a battery as it is automatic/selfwinding mechanical watch. There are two push buttons on the side. One of them is for month setting and another one for day setting. Use small pin or ball point pen to push them. Try both and you will see which one is for the month and which for the day setting. Push repeatedly until the desired month and day is set. Date in small window can be set by winding crown. Pull out crown half way out and set the date, then pull out crown further out to the time setting position and set the correct time. Push the crown back in and wind it back and forth at least 15 times to start the watch going. Before you start any of adjustments, set the time to 5.30 (am or pm - doesn't matter). It will prevent accidental damage of day/date/month mechanism. Rate me, plz.
Feb 28, 2010 | Watches
1440 date change
Hi jhnmeserole,
Timex Digital Watch
Hope it helps.
Nov 05, 2009 | Timex 1440 Nylon watch
I can change everything but the date. How can I change just the date on my watch. The model I have has 4 buttons (Mode, St/Stop, Set, and Light). Can someone tell me how to change nothing but the date?...
Hi 1234910,
Hope it helps.
Jul 16, 2009 | Timex 1440 Nylon watch
What is the function of the winder on left hand side please
The crown on the left side is HELIUM VALVE and is designed for compensating and keeping the right air pressure inside watch case if it is used for diving purposes.
If you will try to set something using this crown, nothing will happen, as it has special springs, gaskets and bars built into it, but has no any connection with watch movement.
Do not forget to rate, please.
Jan 29, 2009 | Omega Seamaster James Bond 007 2220.80...
Setting month, date, and day of the week on non-digital watch
Try pulling the stem out. Turn the stem in the counter clock wise direction and see if that changes the date/day
Dec 21, 2008 | Watches
Watches Logo
50 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
