Question about Hardware & Accessories
The timer light keeps blinking,and heater will not turn on. Lost instruction booklet. How do I now turn it on?
  • Josh Tillette
    Josh Tillette Dec 21, 2016
    Hi Richard McGriff, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
SOURCE: Mitsubishi dlp tv green timer light blinking
timer light keeps blinking tv does not turn on
Posted on Nov 29, 2008
ginko
  • 19396 Answers
SOURCE: TV turned off itself and timer light (red) keeps blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
SOURCE: WD 62725 Timer geen light keeps blinking
Here is how you fix the problem. Turn off the power to your TV for 10 seconds, then turn on. Next, take a paperclip and push in the reset button for 10 seconds, then release and wait until the light stops blinking - may take up to 5 minutes - be patient. Then turn on your TV as normal and your problem will be fixed.
Posted on May 30, 2009
SOURCE: lost instructions booklet for atomic clock
how do I set the clock for PST?
Posted on May 20, 2010
SOURCE: I lost the instruction booklet.
http://waterheatertimer.org/Intermatic-ej500c-manual.pdf
EJ500 instructions are fairly long. Re-post if you have a problem following manual.
Posted on Sep 26, 2010
How do you set the light delay, I lost my instruction booklet.
The 4½ minute interval can be changed to 1½, 2½ or 3½ minutes as follows: Press and hold the Lock button until the light blinks (about 10 seconds). A single blink indicates the the time is reset to 1½ minutes. Repeat the procedure and the light will blink twice, resetting the timer to 2½ minutes. Repeat again for a 3½ minute interval, etc., up to a maximum of 4 blinks and 4½ minutes.
Jan 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
We have the Noma Exterior Mechanical No instructions. Shows on and off/dusk and then the hours. Do you turn to dusk and then the hours how do you set it to come at dusk then turn off 6 hours later?
Identify timer on following page:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Page shows instructions and troubleshooting.
That being said, if your timer has a dial with 2 4 6 8, then following instructions probably apply:
Timer turns on automatically at dusk,
Rotate dial to select when timer will turn off.
In your case, rotate dial to 6, and then timer will turn off 6 hours later.
Make sure to keep timer turned away from lights, or where car lights might reach photo-eye located on front of timer.
If timer is exposed to light, it will turn OFF, and then blink back ON few minutes later.
When timer turns ON again, the 6 hour countdown starts over.
Dec 22, 2010 | Garden
How do I turn the timer off my Creda slim line panel heater ? keeps coming on when not required. I have lost my instruction booklet. Many thanks bev
You can stop the unit coming on by turning the temperature dial down to as low as it will go. Also it could be turned off at the wall if all else fails and there is a plug point.
Jun 16, 2009 | Heating & Cooling
Honeywell HZ-705.....HELP!!!!
Should have oil in it. I don't think you can refill it. If it has leaked out, it's probably no good. Anyway, here are the instructions.
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Aug 17, 2008 | Heating & Cooling
Honeywell oil radiator
Set temperature:
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Hardware & Accessories Logo
54 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
