How to remove the 3/8 hose assembly
Hello
  • Lawrence Oravetz Dec 21, 2016
    Hi Cordell Daniels, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Need to know what you're working on.
    Top Expert:
  • Televison & ... Master
  • 45,410 Answers
No hose assembly on dvd players
Posted on Dec 21, 2016
1998 Oldsmobile Aurora heater core removal
Tools Required:
J 37097-A Hose Clamp Pliers
Remove or Disconnect
1. Drain cooling system.
2. Heater hoses from heater core.
3. Console assembly.
4. Trim sound insulator as necessary to allow removal of heater core cover.
5. Heater core cover from HVAC module.
6. Retaining straps from heater core.
7. Heater core.
Install or Connect
1. Heater core into HVAC module with attaching straps and screws.
2. Heater core cover and attaching screws.
4. Heater hoses to heater core.
5. Fill cooling system.
Mar 01, 2017 | Oldsmobile Cars & Trucks
How do i replace the heater core 1997 isuzu hombre
See me at website for images can only send one through this channel. www.autorepairhelp.us
Best Regards,
Master Tech Lee
HEATER BOX SHIELD
Heater Box Heat Shield
1. Fasteners that retain heat shield to heater box assembly.
Image [ Heater Box Heat Shield
Install or Connect
1.Fasteners that retain heat shield to heater box assembly.
Tighten
-Bolts Screws to 2.2 N.m (25 lb in).
HEATER ASSEMBLY
Image ' Heater Hoses
Image ' A/C Evaporator Tube Assembly
Image ' Evaporator Core
Image ' Evaporator Core Assembly
Image ' Heater Assembly
1.Engine coolant. Refer to Draining and Filling Cooling System in Engine Cooling.
2.Heater hoses. Refer to Heater Hoses.
3.Instrument panel. Refer to Instrument Panel Replacement in Interior Trim.
4.Air inlet assembly. Refer to Air Inlet Assembly Replacement.
5.Vacuum lines.
Important
-Clearly label vacuum line connections.
6.Heater assembly studs inside engine bay.
7.Blower motor resistor. Refer to Blower Motor Resistor.
8.Stud inside heater core housing.
-Stud is revealed by removing the blower motor resistor.
9.Rear case screws.
10.Heater assembly.
11.Seals.
Imagt
Imagt
Imagt
Imagt
Imagt
Heater Hoses
Evaporator Core
Heater Assembly
Install or Connect
1.Seals.
2.Heater assembly.
3.Rear case screws.
4.Stud inside heater core housing.
Tighten
-Stud to 1.9 N.m (17 lb in).
5.Blower motor resistor. Refer to Blower Motor Resistor.
Tighten
-Studs to 1.9 N.m (17 lb in).
7.Vacuum lines.
8.Air inlet assembly. Refer to Air Inlet Assembly Replacement.
9.Instrument panel. Refer to Instrument Panel Replacement in Interior Trim.
10.Heater hoses. Refer to Heater Hoses.
11.Engine coolant. Refer to Draining and Filling Cooling System in Engine Cooling.
-Check the system for leaks.
Sep 06, 2014 | 1997 Isuzu Hombre
Alternator remove
all this is in the FSM , buy one read it.
or login to alldata.com
no engine option stated, . 2UZ?
smog pulley, ? no, not since 1970.
ok ill look it up
i go to alldata.com , so can you, and look
i see what.
sure thing.... quotes.
1:REMOVE ENGINE UNDER COVER NO.1
2. REMOVE THROTTLE BODY COVER
3. DISCONNECT CABLE FROM NEGATIVE (-) BATTERY TERMINAL
4. DISCONNECT INTAKE AIR CONNECTOR FROM THROTTLE BODY
5. REMOVE DRIVE BELT
Loosen the belt tension by turning the belt tensioner counterclockwise, and remove the drive belt.
The pulley bolt for the belt tensioner has a left hand thread.
{that means liftytighty-rightyloosy or backwards}
6:REMOVE PS VANE PUMP FROM ENGINE
it's not smog; its steering. see below. vane.
7. REMOVE GENERATOR
  • Disconnect the generator connector.
  • Remove the terminal cap and nut, and disconnect the generator wire.
  • Disconnect the wire clamp from the cord clip on the generator.
  • Remove the bolt, the 2 nuts and the generator.
then, sigh.... the vane pump removal
VANE: the P/s is a vane type oil pump, for steering assist.
1. REMOVE AIR CLEANER ASSEMBLY WITH AIR CLEANER HOSE
  • Disconnect the MAF meter connector.
  • Disconnect the hoses.
  • Remove the clamp.
  • Remove the 3 bolts and air cleaner assembly with air cleaner hose connected.
2. REMOVE DRIVE BELT
  • Loosen the drive belt tension by turning the drive belt tensioner counterclockwise, and remove the drive belt.
3. DISCONNECT VACUUM HOSE
  • Remove the 2 clips and disconnect the 2 vacuum hoses.
4. DISCONNECT RETURN HOSE
  • Remove the clip and disconnect the return hose.
5. REMOVE PRESSURE FEED TUBE ASSEMBLY
  • Remove the union bolt and gasket, disconnect the pressure feed tube.
6. REMOVE VANE PUMP ASSEMBLY
  • Remove the 2 bolts, nut, stud bolt and PS vane pump assembly.
on my jeep this is a 5min job. love jeeps.
Jan 29, 2014 | 2006 Toyota Sequoia
Do I have to drop the fuel tank to replace the fuel pump on a 94 Buick le saber
Yes ,,instructions are below, Use eye protection for this procedure
Remove or Disconnect:
  1. Relieve Fuel Pressure
  2. Disconnect negative battery cable
  3. Raise vehicle on hoist
  4. Remove Fuel Tank
  5. Remove Fuel Gage sending and pump assembly by turning cam lock ring counterclockwise. Lift assembly from fuel tank and remove fuel pump from fuel gage sender unit.
  6. Disconnect pump wires, hose clamps, and clamp around pump body
  7. Pull pump assembly out of rubber connectors
  8. Inspect fuel pump attaching hose for any signs of deterioration. Replace as necessary.
Install or Connect:
  1. Push fuel pump assembly into attaching hose
  2. Connect pump wires, hose clamps at attaching hose and around pump body
  3. Place Fuel tank sending unit and pump assembly into tank using new O-ring
  4. Place cam lock over assembly and lock by turning clockwise
  5. Install Fuel Tank
  6. Start engine and check fuel pipe connector for visual leaks
Oct 20, 2010 | 1994 Buick LeSabre
What do i need to take off in order to put the thermostate on a Ford Focus 2007?
Hello! Here is procedure to replace the thermostat on your vehicle.....Guru.....Saailer
  1. Thermostat and housing are an assembly
  2. Disconnect battery negative cable from battery and properly isolate to prevent accidental reconnection.
  3. Drain the cooling system.
  4. Raise vehicle.
  5. Remove or disconnect the following:
    Accessory drive belt shield Accessory drive belt Two power steering hose bracket retaining nuts and position the hose and brackets aside. Cooling fan motor and shroud 3 A/C compressor bolts and position the compressor aside Hoses from the thermostat housing
  6. Remove the bolts, the thermostat housing and the thermostat as an assembly.
To install:
NOTE Lubricate the thermostat housing O-ring with clean engine coolant.
  1. Install or connect the following:
    New thermostat/housing assembly and tighten the bolts to 89 inch lbs. (10 Nm) Hoses to the thermostat housing A/C compressor bracket and compressor and tighten the bolts to 18 ft. lbs. (25 Nm) Cooling fan motor and shroud Power steering hose, bracket and tighten the nuts to 89 inch lbs. (10 Nm)
  2. Fill and bleed the cooling system.
  3. Reconnect the negative battery cable.
retailerIdd874f148debugOnfalsecustomerId117788472vehicleId3089401
Sep 11, 2010 | Ford Focus Cars & Trucks
Changing headlight on 2006 VW passat
Hello, to change the headlight on your passat, follow this steps:
1. Pull off the air intake cover, and remove the intake mounting bolt and set the intake hose aside,(passenger side only).
2. Twist off the protective cover from the back of the headlight assembly. Press the tab to pull off the electrical connector.
3. Turn the bulb socket counter clockwise to unlatch, and then slip it away from the assembly.
4. Turn the old bulb counter clockwise to release from the socket .Install the new bulb by turning it clockwise. Hold the plastic base of the new bulb when installing . Touching the glass can cause it to prematurely fail.
5. Insert the module and turn it clockwise to lock it in the assembly. Reattach the electrical connector and twist the protective rubber cover unto the back of the assembly .
6. Reattach the intake hose (passenger side only) and tighten the bolt. Snap the plastic intake cover back on.
Thanks
Aug 12, 2010 | 2006 Volkswagen Passat
I have a 2000 mazda millinia and it is overheating and the coolant is leaking. Could you tell me what some of the problems may be?
Hello, the thermostat on the Mazda Millenia is the heart of the coolant system. The thermostat regulates the flow of coolant to your motor and ensures your Mazda runs cool at all times. The thermostat acts as a valve to allow just enough coolant to flow through the system to maintain the engine temperature. When the engine temperature cools, the thermostat will close and pressurize the coolant. This cycle is what keeps your engine running cool.
To remove the thermostats follow this steps:
1. Pull the hood release latch under the steering wheel. Access the engine compartment to replace the thermostat.
2. Remove the top radiator hose by unscrewing the hose clamps with a flat-head screwdriver. The hose clamp may have a hose clamp requiring pliers. This clamp will have two tabs on it. Pull the tabs together to loosen the hose clamp.
3. Remove the bolts at the top of the thermostat assembly. The radiator hose will stop at the thermostat assembly.
4. Remove the top portion of the thermostat assembly. The thermostat will be sitting in the bottom portion.
5. Remove the thermostat with your fingers. The thermostat is positioned a particular way. Remember the position it was sitting in the housing.
And for installing the thermostats follow the following steps:
1. Place the new thermostat in the housing. Remember the position of the old one.
2. Lay down the gasket around the surface of the housing. Scrape off the old gasket with a putty knife or a razor blade.
3. Tighten the housing back together. You will want the housing snug to help create a seal for the assembly.
4. Install the radiator hose back on the assembly and the radiator. Tighten the hose clamp snug.
5. Refill the coolant level back to full. Some coolant may have been lost during the replacement.
Thanks
Jul 19, 2010 | 2000 Mazda Millenia
I need instructions on how to remove a heater core from my 1967 Cutlass Supreme with A/C. After looking under the dash, the heater and A/C control cables are attached to what must be the enclosure box....
Hello! Disconnect the negative battery terminal...Drain the radiator and disconnect the heater inlet and outlet hoses at the dash...Remove the blower inlet to firewall screws...Remove the blower inlet, motor and wheel as an assembly...Disconnect the control wires from the defroster door...
Disconnect the vacuum hose diverter door actuator diaphragm...Disconnect the control cable from the temperature door lever...Remove the four nuts securing the heater assembly to the dash...Remove the screw securing the defroster outlet tab to the heater assembly...Remove the heater from the car...
To install...Make sure the heater assembly seal is in good condition...Position the assembly onto the dash and tighten the retaining screws...Reconnect the heater hoses, electrical connectors and negative battery cable; Refill the engine with coolant, start the vehicle and check for leaks...
Guru................saailer
Jul 01, 2010 | Oldsmobile Cutlass Supreme Cars & Trucks
Ihow do you replace rear struts on a 1999 ford
Suspension Strut: Service and Repair
Removal and Installation
REMOVAL
1. Remove the package tray trim panel.
2. Remove the upper strut and spring assembly nuts.
3. Raise and support the vehicle.
4. Slide the brake hose clip off and position the brake hose aside.
5. If equipped with anti-lock brakes, remove the Anti-Lock Brake System (ABS) sensor bracket bolt.
6. Remove the lower strut and spring assembly bolts and the strut and spring assembly.
INSTALLATION
1. To install, reverse the removal procedure.
Sep 11, 2009 | 1999 Ford Escort
Water pump replacment precedure on 2001 jag stype 3.0
Hello
To replace water pump : Raise the car
1- Drain cooling system. 2- Remove drive belt tensioner clip (if there is one) 3- Remove accessory drivebelt * Rotate the belt tensioner counter clock wise , 3/8 inch square drive bar should do it
* Remove accessory drive belt
4- Lower the car 5- Remove the upper shield. 6- Remove the throttle body. 7- Detch the coolant hose from housing assembly. 8- Remove the upper radiator mounting bracket 9- Detach the hose assembly from the water pump and lower hose. 10- Remove the hose assembly * Detach the hose clips
11- Remove intake manifold support bracket * Detach wiring harness
* Remove intake manifold support bracket
12- Detach coolant hose from water pump 13- Remove coolant hose from the water pump to lower housing. 14- Remove water pump
Installation :
in reverse order and make sure to use new gaskets and seals
Jul 07, 2009 | 2001 Jaguar S-Type
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
