Question about Canon imageRUNNER 1133 Laser Multifunction Printer - Monochrome - Plai
Canon i.age runner 1133 a copy is ok bit scan page is to light
gremlin11
  • 78 Answers
SOURCE: Canon MX-700 scan software hangs
Markspin.
The issue is not with your printer, rather it is with your pc. You might need to get your computer cleaned up as the normal situation with this is a lack of available memory for the processing required to translate the scan. Check to see what other programs you are running. You can do this by pressing ctl-alt-del and enter your task manager. you will see processes and the numbers will be flicking up and down, it is possable that one of these is causing you an issue. Do not end any of the processes. close this window and open start, run. type "msconfig" and press enter. This will open up a series of windows. the last one is your "start up" any and or all of these can be removed from start up. You will then have to reboot your pc and see how it goes. Don't be too concerned about removing them all, you can simply put them back into your start up folder by re entering this window and reticking it.
Once you have done this, you will find your pc will run a heap faster, however if you are still having issues with scans, it may mean that you need to upgrade the memory in your pc or up grade your pc.
Gremlin11
Posted on Dec 10, 2008
  • 990 Answers
SOURCE: Blank sheets when Copying on the Canon Image Runner 1310.
Hello sir; I would like you to check the charge corona wire inside the drum cartridge or you just replace a new drum cartridge, before you change also check the discharge corona wire at the bottom inside the machine.
Posted on Sep 17, 2009
Testimonial: "Great Help, thanks a lot!"
SOURCE: Unable to scan or copy.
I also just found that I have the same problem. I called HP and of course it is out of warranty. I have only scanned a few things.
I have never had any luck with HP/Compaq. I think it's safe to say, "Don't buy HP Compaq". We also have a Compaq Laptop that it a POS, too.
Posted on Dec 04, 2009
canontech
  • 1219 Answers
SOURCE: copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Posted on Jul 25, 2010
Testimonial: "so thanks"
SOURCE: I have a Canon Color Image Runner C5180. When i
how to ip adres inetall
Posted on Sep 08, 2010
Canon ir 3300 printer has dark part in page not apper in print what is problem
dear
If the dark portion of the page is out side of the image scanned, then there may be chance of light passing to the scanner through platen glass.Pl. check the top cover and whiteness of the flap.
If the scanning through the PC has the same problem then the SHADING adjust to be done.
Thanks
Feb 21, 2015 | Canon Ir 3300 B/w Copier image Runner...
How can I clear error 355-0005
Dear
This error code can not clear without the help of canon people.
Thanks.
Feb 02, 2015 | Canon imageRUNNER 1133 Laser Multifunction...
Ir 1133 canon can not scan & copy
did you make sure that it was in the download when you did it? also did it work befor?
Apr 19, 2013 | Canon imageRUNNER 1133 Laser Multifunction...
Error message with canon mx410 "cannot scan from adf"
I fixed this by changing the Copy Intensity from Auto to Manual
I had the same paper jam (caused by pressing Stop during a page going into the ADF), but I had pressed OK as instructed and the page was auto fed back out again. Then I couldnt copy from ADF after that.
I tried everything, and then started to retrace my steps of all the things I might have tinkered with to try and get the copying working in the first place, before the paper jam.
Then I remembered I had set the Copy Intensity from Manual to Auto (thinking Auto is always best). With hindsight, it now makes sense for it to be manual with the ADF as otherwise how would it load a page, use it to set auto density, and then reload it again for the actual copy to occur. This happens okay on the flatbed scanner as it can scan a little, work out the settings, and then scan for real.
Copy Intensity is reached on my Canon MX from the Menu button at the bottom left of the front panel. - Then press the right arrow twice to get to Color Intensity. - Hit OK. - Then right arrow from "Auto" to "Manual Adjust"- Then pick a setting or leave it as half-way between light and dark- Press OK
Now every time my ADF copying works a treat. Thats what I get for tinkering in things I didn't need to change in the first place. I was just trying to get a quick copy going from ADF to paper without saving a file up on the computer and then printing.
Aug 09, 2012 | Canon Pixma MX410 All-In-One Printer
Copy darkness problem canon image runner 2830
Jul 25, 2010 | Canon imageRUNNER 2870 Copier
I have a Canon Imagine Runner 5000i and it copies but it will not scan or print anything from the computer
if it was able to scan before then those options have to be reinstalled... if it was not able to scan before then those options have to be installed... by a service technician or your IT Person...
Dec 19, 2009 | Canon imageRUNNER 5000 Copier
Need help to setup the scan fuction for Canon Image runner 4570
Do you have the send feature or just scan? If just scan you need to install scan gear to the computer you want to scan to and configure scanner, than can pull scan fro canon to any viewer installed on your computer. If you have the send feature, make a folder on the c drive of the computer , share the folder with all permissions. Touch send on screen, reg. new address, touch file, arrow down to smb file, browser button to see your network, highlight your network, touch down highlight your computer name, enter user name and password as shown, log in to your computer from canon and highlight the shared folder and hit ok. you should now be able to send to that shared folder
Oct 24, 2009 | Canon Office Equipment & Supplies
Scan
You need to install the Canon scangear tool to discover your equipment then you can use Adobe or word to scan a picture with the newly discovered scanner. You can only edit documents with the Imageware software that you will have to buy.
Jun 11, 2008 | Canon Image Runner 3320I Copier
Canon imageRUNNER 1133 Laser Multifunction Printer - Monochrome - Plai Logo
35 people viewed this question
old marine
old marine
