The rotor is not rotating speedy while it's on washing mode but it's okay when machine is on drainage mode... Model # T7011tdfp
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Washing Machine Drum doesnt rotate
Try this site.
In you browser box type in youtube.com
then in the search box type in whirlpool washer repair
Then click on appropiate video(s)
This should hel p with your prob.
PLz rate this solution.
Thanks.
Posted on Dec 31, 2008
  • 713 Answers
SOURCE: MACHINE MAKES DOES NOT WASH,WATER OUT FROM DRAINAGE PIPE
is it a top or front loader?is your drain hose same level as top of machine?if not ,raise hose to level and start cycle.machine will not wash if it does not fill.please reply if u need more help
Posted on Apr 10, 2010
Macmarkus
  • 2605 Answers
SOURCE: Washing machine fills and seems to wash and
Welcome to FixYa
It sounds like (based on your initial description) the unit is detecting an incomplete drain or an unlocked door, hence the control will not initiate a hi-speed spin.
I know most folks will rule out the lock initially because the unit does indeed "lock", however, the lock on these machines are a two part device, a set of contacts to lock and a secondary contact to activate hi-speed spin, It may simply only manifest intermittently.
this is the latch/lock assy, i.e.
**Unplug the unit from the wall first...safety first**
**The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, ASIDE FROM PUMPS BEING OBSTRUCTED.**
You should be able to purchase one at most local brick & mortar stores or on-line part's depot's such as "searspartsdirect.com" "repairclininc.com" to name a couple. They usually sell for about $50 or so, part # 1531974 ( # at repairclinic.com ) and are relatively easy to replace. It should resemble the image here...
As for replacing said switch, There are a couple ways to access it, through the top and squeezing your arm down the front or the way I prefer, remove the front bellows spring/retainer.
1) **UNPLUG THE WASHER FROM THE WALL OR TURN OFF THE BREAKER.**
2) Remove the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swap the wires from the old assembly to the new one and you`re in business.
4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
It is also possible you've used too much soap or the tub bearing is worn, but you'll need to rule those things out yourself. Let me know if you need further assistance going forward or if my instructions are not clear.
Thank's again for visiting FixYa today. Good luck. Please take a moment to rate the solution provided and a short testimony is also appreciated.
Regards,
Macmarkus :)
Posted on Mar 21, 2011
richroth
  • 9472 Answers
SOURCE: WASHING MOTOR WONT ROTATE
What is the model number of the unit?
Posted on Nov 14, 2012
F54 code after repair
Okay F54 is a motor over current doubt if bearing was original problem this a rotor stator setup you should get a little resistance with the motor installed since the rotor has magnets, this code can drive you nuts there could be a crack in the rotor magnets are they rusty did the original seal leak,check the stator resistance on the control board ohm out the 3 wires on terminal P5 1 to 3, 2 to 3 you should get 31 ohms +/- 5 to get into diagnostic make sure machine is off use any button except power, start,stop, pause/cancel press and hold for 3 seconds, release for 3 seconds do this till 88 displays press the same button within 5 seconds of 88 should hear a beep you are now in manual diagnostic slowly rotate the basket the wash, rinse and spin light should flash as you rotate if all of the checks are good you have either a bad rotor or a bad control hopes this helps.
Jan 29, 2014 | Whirlpool Washing Machines
Spin dry
I have washer Model # XQB60-91BF It do all functions eccept spinning when it comes on spinning drum does't rotate. I replaced drain pump but does't spin. Can you guide me about trouble.
Thanks. email: khansaleemuddin@hotmail.com
Jan 20, 2013 | Haier XQB60-91BF 1.92 cu.ft. Portable...
Nov 13, 2012 | Washing Machines
Hi, I have an ASKO 1253 which is working fine except that the rotors aren't spinning anymore. I have taken the trays out and the rotors off to check for blockages/obstructions but they are fine. I...
HI,
When you refer to rotors, are you talking about the spray arm that circulate water? If you have no water movement within the dishwasher, this unit has 2 motors, one for wash mode and the other for drain. If the unit drains but would not wash, I would think the wash motor/circulating pump has failed or jammed. The only was to see if the motor is jammed is to manually rotate the motor from the back of the unit. There are vent fins that you can safely rotate to see if the motor was jammed, if after rotating the motor the unit fails to run, need to replace circulation pump.
I hope this helps.
Aug 09, 2011 | Dishwashers
Model MDB7100AWW. Machine washes okay but does not dry dishes. Element tested as okay. No drainage problem. Is there a thermostat that should be replaced?
You have to verify that element is actually receiving voltage at start of dry cycle. Cause will be timer or relay. Be sure to check hi-limit switch and door seal.
Aug 19, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
Lr code went into service mode but wont respond to commands model #fav6800aww
Tom,
The LR error code can be a tough one to troubleshoot but I'll see what if any help I can be.
The LR code stands for Locked Rotor.
If you Power Cycle the 120VAC to the machine will the error code clear?
What cycle was the machine in when you took the error code wash, spin?
If you remove the front panel and with the 120VAC power cord removed from the service outlet can you rotate the Clutch Pulley CCW (Spin direction) or CW (wash/agitate) direction.
Sounds like you have the FAV6800A/FAV9800A Service Manual.
Let’s see if the drive system is free and not locked up…………Rich
Jul 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The screen is flashing F3, what does this mean?
the drain pump of the washing machine is either got loose or its not working or the drain pump is blocked. Water outlet fault (Grey Hose) If F3 is flashing in the display, there is a problem with drainage. Check: • that no objects are stuck in the drainage hose outlet. • that the drainage pump is not blocked by foreign objects. Clean the pump (see the "CLEAN THE PUMP" chapter MENTIONED BELOW FOR MORE HELP). • that there are no kinks in the drainage hose. ------------------ CLEAN THE PUMP Checking the trap and drainage pump The washing machine has a trap, where coins, hairpins and the like can get caught. To clean the filter and drainage pump: 1. Make sure the machine is empty of water and that it is switched off at the mains. 2. Open the hatch for the drainage pump as shown in the illustration. 3. Drain out the water, into a bowl, for example, by unhooking the drainage hose from the pin inside the hatch. 4. Unscrew the cover anti-clockwise and remove. 5. Remove any foreign objects from the trap and pump assembly. Check to see that the pump blades, right at the back, will rotate. 6. Screw on the cover, replace the drainage hose on the hatch pin and close the hatch.
---------- This will help.please do rate the solution if helped.keep updated for further assistance.
Apr 29, 2010 | Asko W6021 Front Load Washer
My oasis kenmore elite keeps flashing f 50
The machine control through the rotor position sensor (RPS) cannot detect the motor running. The rotor is stuck, the rotor position sensor is faulty, or the machine control is malfunctioning. Open the lid and turn the drum manually. If it turns freely, activate the Manual Diagnostic Mode Test to check the functionality of the rotor position sensor and the machine control. If it doesn't turn freely, let us know to guide you in troubleshooting and repairing it.
The machine should be in standby mode when activating diagnostic test mode. That is, the machine is plugged in will all indicators off, or with only the Clothes Clean indicator on.
Choose any single button except Start, Stop, and Power. Press and hold the chosen button for 3 seconds and release it for 3 seconds; press it again for another 3 seconds and release it for another 3 seconds; press the same button again for another 3 seconds and release it (press, release, press, release, press; 3 seconds each).
The indicators will all light up for 5 seconds with 88 displayed in the Estimated Time Remaining display if the test mode has been successfully entered.
Repeat the procedure if the test mode is not activated. You may choose another button. Let us know if it cannot be activated after multiple attempts failed.
Press the same button chosen above before the indicators turn off (5 seconds). A single beep sounds and the two-digit console ID number is displayed. After 3 seconds the display is cleared (00) and the Add a Garment indicator flashes.
Open the lid and rotate the basket manually. The Wash, Rinse, and Spin status indicators should toggle on and off according to the rotation of the basket.
Press and release the 2nd Rinse button to lock the lid and the lid lock indicator turns on. Press and release the Rinse Speed button. The basket should spin slowly; pressing it again will raise the spin speed. The motor turns off and the basket stops the fourth time the Rinse Speed button is pressed.
With the basket stopped, press the Soil Level button to activate the Gentle wash action. Press it again to activate the Normal wash action. Press it again to activate the Heavy wash action. Press it again to turn off the motor and stop the basket.
Let us know the result of the test for us to guide you in troubleshooting the problem and eventually repair it.
Feb 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Zanussi washing machine will not start cycle.
check water level device,must have in manual,or water pump filter.
Feb 16, 2009 | Zanussi FJS1225W Front Load Washer
Samsung J1045 Front Loading Washing Machine Loud Banging Noise
Throw it off a cliff. I have the same model and have had so many problems. Don't even bother calling customer service, they won't help. Cut your losses and buy a new machine
Mar 06, 2008 | Washing Machines
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
