I have a gaffers and sattler u100. The heater and fan work but the fan never turns off. PG&E says it's a wiring issue at the furnace, not the thermostat. Any ideas? Thanks!
  • 10,291 Answers
There is a "Klixon" switch mounted to the heat chamber that is stuck closed. It will be wired in series directly into the motor wires
Posted on Dec 21, 2016
  • 30 Answers
SOURCE: Honeywell TH8000 5 wire
7wires? wtf with that! how many things you got runnin there. you need to give way more info to get a decent reply.
Posted on Feb 04, 2008
boanhtgclg
  • 34 Answers
SOURCE: New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Posted on Nov 12, 2008
  • 3 Answers
SOURCE: electric furnace/heater pump/fan unit won't shut off
There are dip switches on the main board.. When you remove the lower panel on the air handler there are instructions to where the dip switches should be for your units fan control. if the switches are in the correct configuration.. The Thermostat may be malfunctioning or not wired properly. and last.. and most expensive.. the motherboard may also be failing.
Posted on Jan 12, 2009
  • 5 Answers
SOURCE: Honeywell CT3611 thermostat, not working..
if you cross the two wires and you see a slight spark and heat comes on, then the problem is in the thermostat, if not then problem is at furnace it self.
Posted on Apr 26, 2009
dmftrucker
  • 1922 Answers
SOURCE: I have model#2509622 Williams wall
can you manually fire the unit w/o the thermostat by shorting 2 of the 3 wires, there may be more wires than that, but you should be able to fire it on 2 to 3 wires alone let me know it sounds like something is floating voltage wise on the unit
Posted on Oct 09, 2009
?Location and photo of the transformer for a gaffers and sattler wall furnace model S 90 FE.
No. The transformer "transforms" 240 volts to 24. Meaning the high voltage coming into the machine. Normally has a "c",208,240 written on one side. Follow your main power wire into the machine. Branches to heater and transformer. Look at wiring diagram
Mar 01, 2017 | Heating & Cooling
Where is the reset on an old Gaffers and Sattler furnace
on my old furnace (gravity) there is a overheat relay which will shut off the furnace if it is very cold and it overheats. it is at the top of the furnace box on the side with a pipe coming out to a relay box.....it needs resetting.....if its like mine with a pilot light...
Dec 20, 2013 | TPMS Scan Tool with TPR Reset Tool Kit...
My gaffers sattler gas oven stopped turning on. can not smell any gas when i turn it on.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 25, 2011 | Microwave Ovens
With my thermostat on auto and on heat, and the furnace turns on, the fan will not turn on with it. If I switch the fan to on it will run after I repeat back and forth from auto to fan on several times...
Well, here is the deal: unless you rewired from two wire to multiple (usually 4 to 10 wires) wires, the fan cannot be controlled from the thermostat, even though the thermostat indicates that it can > it is a physical wiring and fan administration issue.
Unless you have a newer furnace, the fan is controlled by plenum temp. Works like this: burner turns on, no fan until the plenum temp reaches set temp,....then burner off, and fan keeps running until pelnum temp drops, and often the fan may kick on a few more times as this temp depletes.
Oct 03, 2010 | Honeywell Electronic Programmable...
I have a gaffers & sattlers hollywood oven
where did you purchase the thermostat from?
Apr 10, 2010 | Kitchen Ranges
HEATING ELEMENT GAFFERS & SATTLER BUILT-IN OVEN
our 1985 gaffers and sattlers oven would not turn off tonight. Any idea? Its Propane oven
Dec 22, 2009 | Ovens
Have a Gaffers and Sattler furnace mod # 85 FDF ser # PV 09020. Pilot is lit, when I call for heat nothing happens. T-stat is okay, thermo couple okay/new. Fan will run when manually turned on at unit with...
When it call for heat you need a voltmeter to see if you have voltage at your gas valve. Check that first. You could jumper your stat between w and r to see if you have a bad stat. Rus
Nov 28, 2009 | Heating & Cooling
Hello I have a Gaffers and Sattler HVAC System the wind has blown out my pilot and I cant seem to locate were to relite
If you can see the gas valve there is a thin hard wire called a thermocouple that comes from the gas valve and ends uo in front of the pilot light and this is where you would relight the pilot if the pilot wont stay lit then you need to replace the thermocouple you can get one from any hard ware store
Nov 27, 2009 | Heating & Cooling
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
Gaffers and Sattler vintage stove oven pilot 1956 W54 series similar problem
My mother had the same problem with her Gaffers-Sattler range. No one could figure out what was wrong with it. Her local new appliance repair people said to contact J.E.S. Enterprises, Inc at www.theoldapplianceclub.net. Whew; thank God for that tip. They knew exactly what the problem was and repaired the unit for her. The stove is running again like a workhorse! Here is their number - 805-643-3532.
Bob Allen
May 07, 2008 | Garland H283 Gas Kitchen Range
Heating & Cooling Logo
135 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
