Question about Carrier Heating & Cooling
My low cool air works, but when I put it on high cool, it does not blow air. The low fan works but when I put it on high fan, nothing happens.
  • 52 Answers
Most likely the control switch is bad or burnt wire terminal
Posted on Aug 29, 2009
Fan wont change from low to high on GE heater/ac unit
clean blower and coils , check out fan motor and fan capacitor .
Nov 09, 2014 | Heating & Cooling
3500 propane forced air reddy heater not putting out much heat since I changed bottles
tank is being turned on to fast and the safety valve will close and not let the full pressure go to the burner same with any new tank that has the columbine valve in it pressure sensitive
Mar 25, 2013 | Reddy Heater-30,000 BTU Propane Forced-Air...
When i turn on my air conditioner on my 2002 Buick LeSabre my fuse blows for the right fan. Do i assume the fan is bad? The left fan still works when the car gets hot.
My air conditioner on my Buick has a full charge of Freon and when it is hot out I don't get the cooling power in the cabin as I have it on low switch so when I put the switch on the high the Air doesn't change to cool the interior on high. I had the Freon tested and it still doesn't work properly and I wonder if there is a sensor that doesn't allow the system to cool properly?
Jul 10, 2012 | 2002 Buick LeSabre
I have a rooftop ac unit on my popup that was replaced two years ago. The unit works fine but I would like the fan to shut off when the compressor isn't running. Is there a switch for putting the fan...
Please describe your controls. Does it not have low fan, high fan, low cool, high cool on the dial at ceiling? If yes, low cool or high cool setting should shut it down when temperature is reached via thermostat dial.
Aug 29, 2011 | Dometic Rooftop RV Air Conditioner
This is a heating and cooling through the wall heat pump. It works normally when heating is selected - the heat pump runs and both speeds of the fan blow warm air. But nothing runs when cooling is...
You have a bad board or bad switch. I would say board. You can have service tech check this out. There is only so far you can go without knowledge of Controls ad electricity. Russ
Jul 21, 2009 | Heating & Cooling
Ac not working cuts on and off when aux fans turn on. what could be the problem?ac was working fine, now it blows really low cold air then blows hot air.
i assume u r refering to the cooling fans,,, if this is so the freon is low ,fans come on and lower the high side ,there fore lowering the low side and the low side switch cuts it off and on,,charge it up
Jun 29, 2009 | 2002 Nissan Sentra
Unit will not come on at all has voltage to unit and to contactor?
Sounds like you lost the refrigerant charge. Low pressure switch will not let compressor run. Look for oil around the condenser tubes. If you find it, this is probably the leak source.
Jun 01, 2009 | Heating & Cooling
No Air
30 is too low. Raise the thermosta to 74 and see what happens
Jun 04, 2008 | GE Built-In Room Air Heat Cool Air...
Fan Seems To Be the Only Thing Working
no you problably have a bad thermostat on the unit
May 27, 2008 | GE AJCQ08ACB Air Conditioner
"high" vs "low" dual control
could be problem with either switch of fan. try continuity across both legs of the switch then try continuity across the fan windings.
May 25, 2007 | Fedders X Chassis A3X05F2B Air Conditioner
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
