Question about Vizio Televison & Video
Vizio tv logo blinking rapidly - Vizio Televison & Video
3 Suggested Answers
SOURCE: Upon powering on my xvt47sv
The main board of this Vizio is known to fail after some use.
Its number is CBPF9D1KZ4 and as you will see it is hard to find, unless you want to pay $250 or so, which doesn't make any sense, at least to me.
Another common failure in those is the T-CON board, but from the sound of it the problem you have is in the main board.
Here's what I'd do if I were you: post a local ad on Craigslist, sell it to the highest bidder and use the money towards puchasing a new TV.
Not sure it's what you want to hear, but it's what I tell some customers and thus losing business that I couldn't have had anyway because it's insanely expensive and prone to more failures anyway.
If it helps you please vote for me - it helps me in turn :-)
www.coppelltvrepair.com
Posted on Jun 05, 2011
  • 517 Answers
SOURCE: tv won't turn no the vizio logo only blinks
That problem is 2 causes,its either power supply or system board.
This are some D.I.Y procedure for troubleshooting.
  1. Open the back cover by removing all screws at the back.
  2. Try to look at the power supply board and find the leak/bulge on top capacitors.If you found,replace it with the same type and ratings.
  3. If the power supply doesn't have any leak capacitors.Try to power it ON to perform voltage checking.
  4. Check the output voltage of power supply such as 5vdc,12vdc and 24vdc by using voltmeter.If this 3 supplies having a voltage drop or flickering voltage while on power ON.Check the following parts on the power supply,change value/open resistor,shorted transistor and diode or repeat step # 2.
  5. When the output voltage is stable and all parts looks OK.The problem could be on system board.Unfortunately the system board or main board is not for D.I.Y because the parts inside is very logic and very sensitive.That is replaceable.
Thank you and good luck.
Posted on Jun 11, 2011
My vizio tv is not powering on andi dont know what to check
I think this new tv have a chip cor the picture quality proba ly it burn ot die so if u warranty on the tv just call n they will fix it for free.
Oct 01, 2016 | Vizio XVT553SV 55 in. LCD TV
Vizio m550nv amber light is on but tv will not power on
EASY HOW TO FIX LED Vizio TV- no power - YouTube
? 6:13
https://www.youtube.com/watch?v=9xZcTWr2yV0
Nov 5, 2013 - Uploaded by Tampatec
DiY How to Fix led / lcd Vizio TV service repair - no powerservice repair review guide no red blinking led ... Theorange/amber light turns on when plugged in. But the TV won'tturn on after that (the light does not turn white).
Vizio TV logo Flashing (Blinking), TV will not turn on, not ...
? 4:01
https://www.youtube.com/watch?v=MDzCzZdgbdg
Jan 5, 2012 - Uploaded by Leo P
This is model XVT3D424SV, I was watching a DVD, I switched the input to TV, tried to connect to netflix, it was ...
HOW TO FIX VIZIO TV - What causes no power - YouTube
? 5:53
https://www.youtube.com/watch?v=5k1Mc1f6O3E
Jan 17, 2016 | Vizio M550NV 55 in LCD HDTV
I have a Vizio E422VA that will get to the Vizio logo screen, hold for about 1 minute then power off with the power light blinking for about 2 minutes. I have replaced the main board, power supply boa
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jan 22, 2015 | Vizio E422VA 42-inch Widescreen LCD TV -...
Vizio logo blinks orange/white for a minute then stops blinking. TV never comes on.
If there was a power surge, a power supply component may have failed.
Jul 01, 2014 | Vizio M550NV 55 in LCD HDTV
Xvt3d474sv logo blinks
Dear Sir:
This a problem HSYN+ VSYNC , if there are present,you need test the output signal RGB see the diagram
May 14, 2012 | Vizio XVT3D474SV 47 in. 3D LCD TV
Vizio m470nv will not come on, logo blinks orange to white.
It may not be the caps at all, a lot of the new LED Back-Lit TV have faulty LEDs. They short and pull down the power supply, and to a novice it will seem like a bad power supply. That means that you must replace the bad LED's in that particular LED strip before you can fix the problem. Not an easy repair for a rookie.
Mar 03, 2012 | Vizio M470NV 47 in. LCD HDTV
TV keeps shutting on and off on it's own. I have a Vizio 32 inch
Unplug the TV. Then press and hold the power on button on the tv for about 60-90 seconds and then release. The vizio logo on the frame will blink for a min. and then turns off. Then plug it back and turn on. If this doesn't resolve you got a lemon.
Oct 26, 2009 | Vizio Televison & Video
Televison & Video Logo
24 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
