Question about GE Refrigerators
How do i determine if the main control panel is bad on my GE FUF 21SVDRWW freezer? the coils are clean/not frozen. When I unplug and reset the freezer runs for a short time brining the temp down. .
After a while the alarm rings for hi temp and comp is not running. Reset - same results. I can repl. the panel myself but i do not want to spend $ if it doesn't fix it.
    Top Expert:
  • GE Master
  • 49,276 Answers
Try having the freon level filled by a professional
Posted on Dec 21, 2016
Fuf 14
If the compressor is running yet the suction (larger pipe) on the compressor is not cold, or if it is frozen, you probably have a refrigerant leak and need refrigerant.
Jun 11, 2014 | GE Freezers
GE gss22jepa frost and frozen coils on back pannel of freezer, fan and compressor working. How to fix.
Giving it a shot, hold on.
Opening on bottom that goes between fridge and freezer always open its just a hole there. Took this acid panel off and coils are frozen.
I think its the temp control, I changed it and I don't remember what its suppose to be set on
Feb 27, 2012 | GE Refrigerators
The refrig is not getting cold enough, but the freezer is starting to get ice in the back of it
evapator is frozen up heatin g element may be bad or defrost timer or defrost terminator is bad
Sep 26, 2010 | GE Refrigerators
Have a S/S GE Profile Artica. We came home tonight to find the freezer not cold enough and the fridge sweating inside. I have done the best i could to clean the condenser unit and the evaporator coil in...
the ice maker quit because the tempt in freezer is too warm / like abofe 15 deg./ the sweating is caused by the ice blocking the air flow . . to correct the problem from comming back ( next week ) you will have to replace the heater or defrost thermo . if these are not bad then replace the main control board .. mm hope thes helped ..
Feb 23, 2010 | GE Profile Arctica 25.4 Cubic Feet...
I have a ge sxs model #gss22jepcww fride not cooling i removed panel in freezer to inspect coils coils are froze up around coils,I thinking its a frost free problem this model has a circut board in back is...
If you have cold temps and humidity sometimes the coils freeze up and you need to unplug your refrigerator until the ice on the coil melts, clean the coils and plug in, you may overflow your condensate pan, so you might need a towel if it does.
Jan 21, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi there. My GE GSL25JFPD side by side has major issues. The evaporator has completely frozen over. We called a technician twice. The first time he replaced the main electrical board. This fix lasted about...
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board .. Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Nov 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Top section not cooling on GE Side by Side
IF the evaporator is frozen then the defrost is not occuring. Probably the heater or the defrost thermostat.
Sep 10, 2009 | GE GSH22JFT Side by Side Refrigerator
I have GE side by side fridge. The freezer built up frost and then started to defrost. I took everything out andoened the back panel. The freezer was getting cold again but frost on the coils. the fridge...
Pull refrig out from the wall and unplug . Remove the 8" x 10 " panel covering the main control board . On this board , unplug the blue plug with 3 larger wires going to it . The sequence looks like this : wire1,wire2,space,wire3 . Use a piece of wire , with both ends stripped about 1/4 " , and insert an end into wire2 and wire3 . Plug refrig back in . Look inside the freezer at the back bottom , and see if you see a red glow . It may take about 30 seconds for the glow to appear . If no glow appears , the defrost heater located at the bottom of the coils ( glass tube ) is probably shorted . Pt # WR51X10042 . Also replace the defrost thermostat Pt # WR50X10068 . To access these parts , the inside freezer panel has to be removed . If you do get a red glow , then the main control board is bad Pt # WR55X10656 .
Sep 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a 3 year old GE side by side that isn't cold.
Sounds like a defrost problem or an evaporator fan problem . I would suggest you have a professional check it for you to find the problem and then do the repair yourself . If the fan isn't working , probably a main control board problem and not the actual fan ,which is costly . Also , possible thermistor problem which takes experience to diagnose . Buying parts without knowing which is bad can be realy costly on GE refrigerators .
Jul 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
