Question about Cell Phones
My Z797c screen will not time out. And the button used to time out screen is not working..Also do I need to do a software update? I try.. it says data service not available now, try again later
SOURCE: Camera
I have the same thing. even after taking the battery out and replacing it says the same message.
Posted on Sep 02, 2008
  • 677 Answers
SOURCE: Touche screen is freezed, I
Hi, when a phone screen randomly freezes, it means that the phones memory is faulty or when an application you downloaded has virus.
What to do is this,
You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone
Take care.
Posted on Sep 03, 2010
  • 17 Answers
SOURCE: Nokia 5800 Express music-Whenever I
you need to setup the gprs/3g through your phone carriers,the sevice provider will gave you proper settings for your phone.
Posted on Sep 22, 2010
  • 33 Answers
SOURCE: My se m600 update failed
restore firmware
Posted on Dec 23, 2010
SOURCE: problems re-flashing
pls, send by online phone screen display softwere
Posted on Jun 17, 2011
Only screen is the garmin logo with the battery charge icon. When power button is pressed another icon appears for 20s: a picture of the garmin unit linked to a charger then back to the first screen.
Don't know if this will help but it might be worth trying, especially if you just did a software update. I have a 520 and it gets frequent software updates. After an update it ends up just showing the Garmin screen and seems to be bricked because nothing else works - even the off button doesn't work. The solution is to just let it sit showing the Garmin screen for five or ten minutes so it can process and load the new software which seems to take a long time. It eventually opens onto the main screen.
Oct 07, 2016 | Garmin EDGE 705
Nuvi 660 cannot acquire sattelites
do a proper reset like take the battery out if its optional then press the power button for 30 seconds without connecting the power,if that doent help then you need to reset the software to the factory setting thorugh the menu itself.
Jul 04, 2008 | GPS
Sat nav won't reset. have tried the re-set button. Screen has frozen
If the reset button of your device is not resetting the device and it is still on the frozen screen. Just turn to the back of the device, unlock the battery from the device and remove it. Then you allow the device rest for about 5 minutes then you fix it back in. Plug the device for about 2 hours and power it on. It should work fine after this. Be sure not to turn on too many applications on the device at the same time time, because that could result in the device being frozen again.
You can as well update the software of the device by charging it for about 2 hours, then you connect it to the computer that has its software. That will show if there are recent updates for the device, then you update the software with the latest version. that should take a little while to update. Then install your maps on it, safely disconnect the device from the computer and turn it on. That can also help you solve the problem.
Hope this was helpful. Thank you for using fixya.
Jan 26, 2011 | SNK RAC SAT NAV 200 GPS Receiver
After i leave the main screen and go to lets just say text msgs....when i want to go back to main screen it will not allow me to go...seems like it freezes on current screen...
First you have to restart the phone and the reset it.Beacause the apple ios is corrupted you have reset the ios to work properly.When you reset the apple i phone new Ios will be re-installed it will not update it will only reinstall so the firmware will work properly.
To restart iPhone running iOS 3.0 or later
1. Press and hold the Sleep/Wake button until the red slider appears. When the red slider appears, release the Sleep/Wake button.
2. Instead of dragging the red slider, press and hold the Home button for six seconds.
3. If the device does not return to the Home screen, see the steps below to restart.
To restart iPhone iOS 2.2.1 or earlier
1. Press and hold the Home button for six seconds.
2. If the device does not return to the Home screen, see the steps below to restart.
If the iPhone touch remains unresponsive, try restarting the device:
Restarting iPhone :
1. To turn it off, press and hold the Sleep/Wake button until the red slider appears.
2. Slide your finger across the slider to turn off iPhone.
3. To turn iPhone touch on, press and hold the Sleep/Wake button until the Apple logo appears.
Resetting the iPhone:
Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds.
If still the problem persist you have to update the firmware:
Updating and Restoring iPhone Software
You can use iTunes to update or restore iPhone software. You should always update iPhone to use the latest software. You can also restore the software, which returns iPhone to its original state.
If you restore, all data is erased from iPhone, including songs, videos, contacts, photos, calendar information, and any other data. All iPhone settings are restored to their original state.
1. Make sure you have an Internet connection and have installed the latest version of iTunes from
2. Connect iPhone to your computer.
3. In iTunes, select iPhone in the Source pane and click the Summary tab.
4. Click “Check for Update.” iTunes tells you if there’s a newer version of the iPhone software available.
5. Click Update to install the latest version of the software. Or click Restore to restore iPhone to its original settings and erase all data on iPhone. Follow the onscreen instructions to complete the restore process.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 04, 2010 | Apple iPhone Smartphone
My gps is stuck on magellan boot up screen.
turn on your 1210 once it boots to the magellan screen press and hold the power button for about 15 seconds, once it shuts off, power it back on by pressing and holding the power button for up to ten seconds then let it load.
if that fails,power it up and try the reset button, (either on the bottom or on the side)the little pinhole, and use a paper clip to depress the reset
Jan 01, 2010 | Magellan RoadMate 1210 Car GPS Receiver
Iphone 3g 3.0 stuck on iphone apple logo loading screen
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Aug 27, 2009 | Apple iPhone Smartphone
Touch screen doesnt work all the time
Pop the face off to reset it, could sort it for you.
Press the power button for over 1 minute to calibrate the screen
and use the Garmin Web-updater to update the software.
Should be good then
Apr 15, 2009 | Garmin StreetPilot c530 GPS Receiver
Stuck on nokia start up screen
Try this:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Tip! Only use one Anti Virus Application on your phone.
If the above doesn't work try another update. (it may have mis-updated).
Before updating software you should check that there's a newer version of software available.
When updating software on Mobs, be sure to:
And obviously don't unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you're up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
Mar 25, 2008 | Nokia N70 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
