To set the time due to power cut - Televison & Video
If the clock is showing time you may have accidently knocked the auto button this will shut off the power to both ovens until the timer times out you must press the manual button it usually has a little hand printed on it. If you do not have any lights on the clock or oven it may be due to
1. a blown fuse or tripped power supply
2.Thermal cut out tripped or failure
3.A broken live or neutral wire isolate the power before doing any continuity tests.
4. A faulty timer.
Apr 30, 2015 | Ovens Ovens
DSP A 1092 keeps tripping when switched
try unplugging each set of leads 1 set at a time,and after each set of leads are unplugged switch it on as it may be a set of faulty leads,it sounds like the safety cut out is coming on and switching off the power to save your system blowing due to bad or broken phono leads or speaker could also be that you could have blown your output transisters or something else thats causing the saftey cut out to cut off the power,also make sure there are no loose connections inside your mains plug as this would cause the same thing.
Jan 06, 2013 | Audio Players & Recorders
Tv turns on no picture or sound, the light signal is green, but turns off and thr red light appears after 5 seconds.
The set is tripping and can be due to problems in the drive or the output section. You need to disconnect power to trace this and requires some knowledge of the circuit to go about. Since the set cuts off there will not be audio as the power is cut off in protection.
Jul 04, 2012 | Sony KDS-60A2020 60" HDTV
Power light blinks 3 times and cut off
The 3 blinks of the power indicator is indicating that the set has shut down due to failed convergence. The PT53WX53 convergence repair kit from will usually solve that issue. The kit contains the two Convergence ICs , heat sink paste and the low ohm resistors . The kit also contains the CD with complete repair instructions.
Jul 20, 2011 | Panasonic PT-53WX53 53" Rear Projection...
My modem is through insight and it works some times but it will cut off the phone and internet and I try to reset it and it only has solid lights on the power and ds and the US light blinks how do I fix...
it sound like the router overheat that is why it cut phone and internet. but if after reset it does not work and just do what u say , may be a defect iside due to overheat.
or use your IP address on browser and make sure settings are ok.
Dec 31, 2010 | Computers & Internet
There is static on the speakers all the time.
The static on the speakers can be caused due to many reasons. However, the most common trouble maker is a cut wire or loose connection. Try tweaking the sound settings before proceeding further.
If not resolved then, check whether all the connections are good and wires are not cut. Next thing to check is the power cord, try changing the power socket to see if it is due to the electrical noise caused by power socket.
The last thing to check for is the sound card. Use a headphone and insert it into the same jack where your speakers are inserted and check if you still can hear the static. If yes then the sound card is faulty and if no then there is an internal circuitry issue with your speakers. Please post back for any assistance.
Daniel Scott
Jun 20, 2010 | Creative Labs SOUNDBLASTER AUDIGY2 PCI...
Microwave starts as normal but cuts out after
This is happening due to either the magnetron, or the Power Diode, or both, is breaking down, under load, then the unit detects the fault condition, & then, for safety reasons, to avoid a fire or explosion, shuts down the system. You need to take it in to be looked at please obtain a "Quote" before proceeding with any work. This way you can decide to repair or replace.
Mar 24, 2010 | Neff H5642 Convection / Microwave Oven
C.Hausfeld HLseries compressor pressure cut in setting
Hello. The answer is yes. Let me warn you to make only small adjustments at a time and be sure to relock the two screws using some one minute clear epoxy.
Jul 24, 2009 | Campbell Hausfeld 04 Gallon Twin Stack...
Philips set top box malfunction due to power cut
sounds like a capacitor in the unit might be faulty. not reaching full charge, any other items get spiked in the blackout? insurance might be the way to go. i had a set top box that fried all the capacitors, i replaced the , cost about $10Au and some time soldering. unit works better now that before,
Jan 25, 2009 | Televison & Video
Why does the date and time setting screen appear when I turn on the camera?
Turning on the camera while the date and time are not set or after the date and time settings have been cleared due to a total cut off of power (which occurs when batteries are dead and the camera is not being supplied power via AC adaptor) causes the date and time setting screen to appear on the monitor screen. When this happens, be sure to set the correct date and time before doing anything else.
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
