I have Grunaire GMI093HX and F4 code is flashing. What does that mean?
3 Suggested Answers
catriver
  • 878 Answers
SOURCE: F4 error code on Jenn-Air W30400BC expressions built in oven
Slone, F4 is the code for a shorted temperature sensor. This is the temp probe in the oven. There are 2-quarter inch screws holding it on. It should pull out through the insulation until the quick connect comes through. If you want to make sure, the sensor should ohm out at 1143 ohms at 100 degrees. I think you can be pretty sure that this is the problem. The part number I have is 704657. Catriver.
Posted on Dec 04, 2007
  • 48 Answers
SOURCE: can you tell me what code F4 means? model
Code F4 means you need to repair the line to or replace the oven temperature sensor. The line typically runs from the display to the back of the oven, you'll have to trace it yourself. The oven sensor should be mounted to the back of the oven lining (Obviously on the inside) by two screws. Disconnect the power from the unit and unmount the sensor to check it, you should have around 1080 ohms of resistance but first you'll have to get that annoying plastic housing of wires through the mount hole and disconnect it so you don't lose it inside the oven. If you don't see screws from the inside of your oven than you'll have to remove the back panel to access them, but this may be a good thing as you don't have to worry about fiddling the plastic connector piece into the oven. You're measuring the resistance from one lead to the other inside that plastic housing, again at around 1080 ohms in a 70 degree environment. If you're way off, or 5 - 6 ohms off, you'll need to replace the sensor. If the error occurs while cooking you can also run the oven hot, turn off and disconnect the power and take your measurements again. If they read the same your wiring harness should be okay and replace the sensor.
Oh and btw, you'll most likely have to splice the wires to adapt to your new sensor they're never the same.. not in my experience lately anyway.
Posted on Apr 25, 2010
When the indoor unit is on F4 fault error code display.please help to solve the problem.
f4 mean Air Conditioners Questions & Answers - Fixya
www.fixya.com > Forum > Tags > f4 mean
My gree split type ac error F4 what is problem Name of malfunction = Outdoor tube sensor open or short circuit Display of double eight code = F4 this means
Oct 29, 2015 | Heating & Cooling
I have a grunaire split ac system. I moved in and just was given the remote. What do all the symbols mean? How do you get the ac to work?
Service Manual - Grunaire - LoPDF
www.lopdf.net/...,/Service-Manual-Grunaire.html?...Grunaire-Remote-C... 1 Summary and features Indoor Unit GSI091HXD GSI121HXD Outdoor Unit GSU091HXD GSU121HXD Remote control window YT1FF Summary and features.
hope this is your unit, on page 11 it tells you what the buttons on remote do
Mar 03, 2015 | Heating & Cooling
Code f4
need washer brand PLEASE! for f4 code. Good-Day!
Jun 23, 2014 | Dishwashers
Display has gone blank on my GSI181HXB air handler from grunaire what can I do?
appliance repair or unplug it and ask grunaire for technical support before getting too serious with a BTU unit of 18000 somedisplays have energy efficient sleep modes built in and should awake when loss of power or carbon monoxide sensing. use the manufacturing labels to find a .com of technical support or leave that to the repair man.
Aug 21, 2013 | grunaire GSI181HXB / GSU181HXB 18,000 BTU...
Range displays code of F4 and stops working
F4 Oven temperature sensor (RTD) shorted Replace Oven temperature sensor (RTD)
The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
Hope helps.
Jun 14, 2011 | KitchenAid Kitchen Ranges
What does it mean when it flashes f4
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 14, 2009 | Kenmore Elite 45986 Front Load Washer
Dec 04, 2007 | Jenn-Air JJW8527C Expressions Collection...
Washing Machines Logo
Top Washing Machines Experts
