Question about GPS
My gps says no map data.I cant get it to get me an adress
bunnydawg
  • 5158 Answers
SOURCE: when i turn my gps on it says no map data found.
go into the menu.... and look for the map section... make sure that all the maps you have on the gps are selected.
Robert
Posted on Jan 25, 2009
  • 5 Answers
SOURCE: GPS CAN NOT FIND MAP DATA FILES
I had a similar problem with a nextar X4-T, which has it's maps on an SD card. If your GPS uses an SD card for it's maps, you can try this:
You will need a computer with an SD slot, and running Windows Xp. I tried the following method on a computer running Windows Vista, and it did not work. I tried again on an older Xp machine, and it worked first time.
  1. Put the SD (Map) card in the computer's SD slot.
  2. Open Windows "explore". (RIGHT click on "Start", then select "explore"
  3. Locate your disk on the file menu.
  4. RIGHT click on the map disk
  5. A menu pops up.
  6. At the bottom of the menu, select "properties"
  7. Another menu pops up, with several tabs along the top.
  8. Select the tab that says "tools".
  9. In the "error-checking" section, select "Check Now"
  10. Another menu pops up.
  11. Select the box that says 'Automatically fix file system errors".
  12. Click "Start"
The program will only take a few seconds to run. If it works, you will see the file directories of the SD card display on the "Explore' screen. You can then put the SD card back in the GPS, and see if it works.
Good luck.
Posted on Apr 18, 2009
  • 4090 Answers
SOURCE: Nivi 200 no adress navigation possible with latin maps brazil nt4
Software not the full quid!
try a reinstall
Posted on Jun 30, 2009
  • 589 Answers
SOURCE: Just downloaded my free maps
When you do Where To... Address....on the top of screen it says Select City in__________
Is that the State the address is in, if not you must change it on the bottom of screen to the correct State you want to travel
Posted on Nov 03, 2010
GPSCity Mike
  • 464 Answers
SOURCE: my gps is stating no
Try performing a soft reset or a hard reset to the unit.
The soft reset is done by holding down the power button for at least 10 seconds and allowing the unit to power back on.
A hard reset is done by pressing and holding the bottom right hand corner of the screen while the power is off and then pressing the power button on. A pop up will appear asking to confirm the reset.
The hard reset will erase the user data, so it is advisable to save the data if possible.
You may also want to contact Garmin support for assistance.
http://www.garmin.com/us/support/contact
Posted on Sep 28, 2011
No map data availble
Your Garmin GPS has an internal memory or an SD-card that contains an "operating system" and "map data".The operating system is like windows or Mac OSX. It contains the menu and everything the GPS displays. The "map data" is a digital roadmap the GPS uses to calculate your route. If the map data was on a SD-card that was inserted in your GPS, it could me that you lost the SD-card. That could be the reason your GPS can't find the map data. Sometimes it happens that when people connect their GPS to a computer to update the "operating system" of the GPS something goes wrong. For example, when you disconnect your GPS from the computer while the update software is still writing data to your device, the connection gets lost and you're left with corrupt files on the GPS. It could also be a defect in the internal memory of the GPS. I suggest you try to update the operating system with a program called "Garmin Express" (just google and easy find it). You need to connect the GPS to your computer with a USB cable. Then you can perform an update. I hope it helps to solve your problem. What you could also try is to soft reset your GPS. To do that, you need to remove the silver or blue frame around the screen of the GPS (it pops off). Behind this border there is a reset button.
If the map data is completely gone, and you don't have a backup there is only one solution: Buy the latest map for your GPS online and download it to your GPS. It's expensive. In that case it's better to buy a new device in a shop. Most new devices contain Lifetime online map updates (model name nuvi -then the number - LM or LMT) (LM= Lifetime Mapupdates T= Traffic information) Then you can update your map data every three months if you want.
Nov 08, 2013 | Garmin StreetPilot C330 GPS Receiver
Just downloaded my free maps on my new gps 465. when I start a new route I go to "where to?" then new adress and it gives me no data available.
Nov 02, 2010 | Garmin GPS
How do I increase the number that's higher than 899. The address I need is 900 Montcalm, Hull QC
The version of map you have installed is not uptodate beyond the set of numbers presented. if 899 is the highest available that's all you can enter.
Check that it is available on Google Earth. The data in most GPS is collected over a 12 month period for release the following year after it has been converted to all the formats of GPS that use the data from whoever collects it. So GPS maps can be a year behind development.
I sell and repair GPS units as well as use them, but I still often have to use a book of maps for some adresses. Until we have injstant satelite updatesonjh auto downlaod of njew developments the lag will remain
Pleasde rate our help++++Thanks for using FIXYA
Oct 13, 2009 | Magellan RoadMate 1412 Car GPS Receiver
I bought the new maps from website, and can not install
If the software crashed whilst updating, you will find that if you try to restore from a complete backup when you switch on next time it will either say you cant use the map or will just freeze, fix re format both the internal memory and the memory card, then find where tom tom home had stored the files, then using windows copy the contents from the 2 folders back into the relitive internal and external card, you will then find that you will get the mesage that you cant use the map, this is because tom tom home doesent always put the map data into the correct folder, to fix this find the licence data and the map data that has been stored on the sd card instead of the internal memory and copy it into the internal memory, before switching off press the reset button, when you switch on you should find that you have a working tom tom
Aug 25, 2009 | Tomtom ONE XL GPS
Missing links/buttons
press bottom right hand corner as soon as you turn it on and it will ask you if you want to reboot. you will get factory reboot
May 30, 2009 | Garmin NUVI 270 GPS Receiver
Maps
You will have to adress this problem via TT Support.
(... or buy new map)
Mar 21, 2008 | Tomtom GO 910 GPS Receiver
GPS
hello.
if when u say 520 u talk about mio c520 with igo or miomap then the home adress is set to the first map opened by the program...i fixed the problem by deleting all the maps and putting them back... but u must copy first your desired countrys` map and open the device...then copy the rest of them....jope you`ll get it Fix-ed Ya...
regards
Feb 22, 2008 | GPS
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
