Have a pair of speakers from the 89's. Kirksaters. Small and not used for a decade. Noticed one speaker has a tear in top cone. Repairable?
  • Audio Player... Master
  • 9,587 Answers
Yes. There are repair kits available. Online Instructions
Posted on Dec 21, 2016
  • 14 Answers
SOURCE: Kef Q Series iQ1 problem
You may have broken the cross over, which is fixable by an service agent, or you may have damaged the voice coil in the mid driver. you can check this by sofly pushing the main driver in, making sure that you done push the cone, if there is a lot of resistance then you have damaged the voice coil, and you will need to replace the driver.
Posted on Dec 13, 2007
  • 14 Answers
SOURCE: Busted cone (i think)
First try swapping the leads on your source, powering the left speaker with the right channel, and the right speaker with the left, if the problem follows, then the issue is with your source, and not the speaker.
If the cone is torn, then try to patch it, using some basic glue and several layers of tissue paper. White Glue, embed tissue paper in the glue, more glue,embed tissue paper in the glue, do this several times building up several layers. Guessing this is a standard paper cone...
Now if you are still having the issue, could be that the woofer is damaged. Look for a replacement.
john
Posted on Aug 20, 2008
  • 4 Answers
SOURCE: i have a pair of TDL studio 10 speakers, both bass
I'm guessing that you have Bi-wireable binding posts on the back and your jumper straps are not installed. You'll be able to tell if they are biwireable if there are 4 sets of speaker connections vs the standard two. When you are only using one set of speaker wires you need to have metal straps installed between the upper and lower pair of connections so that all of the drivers are getting signal.
Posted on Jun 06, 2009
Ganx
  • 113 Answers
SOURCE: i Have a buzzing mordaunt short avant 916i cone
Hiya, its the cone. The former is touching the magnet inside. Realignment is really tricky and dont know many people who can do that so you may either have to live with it or see if someone can recone it in your area.
Best of luck
Posted on Jul 15, 2009
  • 308 Answers
SOURCE: The spongy rubber around the speaker cone has come
The foam surrounds degrade with the years. No bugs, just old age. If the speakers are worth it, you can have them repaired at better audio stores.
Posted on Apr 21, 2010
Blown speaker
Your best bet here would be to contact one of these authorized dealers for advice I think.
-Steve
Find Service Center
Nov 14, 2013 | Behringer B1520 Pro Eurolive 15" 2-Way...
Is the cone tweeter in a RF-15 speaker repairable?
Hello
It is not a repairable speaker. Replacement only can be done.
Feb 29, 2012 | Klipsch RF15 Speaker
REPAIR CONE TEAR IN 18"
If the tear is large, or the speaker cone is brittle because of age, you might be best off having the speaker completely reconed. There are companies that offer the service, or you can buy replacement cones and do it yourself.
For small tears (an inch or so long), you can glue a patch in place. I have used a piece of a paper coffee filter as a patch, and plain white Elmer's glue slightly thinned with water. Put the patch over the tear and use a small brush to spread a thin layer of glue over it. Give it a day to thoroughly dry and you should be set.
I have found this repair to be more effective on smaller speakers than on large woofers, though. The woofer cones are more mechanically active. But I patched a couple of 15-inch cones that had been punctured for a friend, and they are still playing after a year. So it can't hurt to try.
Jan 30, 2011 | Audio Players & Recorders
I have a pair of pioneer ts A-6987 connected through an amplifier and pioneer cd player..i noticed today that the left speaker's cone woofer stopped working whereas the its producing voice but if very low...
double check the ratings on the speakers and amp. speakers that size don't usually require an amp. compare the wattage and resistance numbers, if you haven't fried an amp, you may have blown a speaker. another possibility is a short in the channel. check wiring connections.
Jan 29, 2011 | Pioneer TS-A6987 Car Speaker
I have a 15'' Yamaha MSR800W powered sub speaker with a torn cone. Can I replace this myself or should I send back to be repaired?
If you have a warranty on it send it back, if you don't you can do several things. It depends on how bad the tear is. If its a small less than 2 in or so tear, a beed of hot melt glue on both sides of the cone is a sturdy but not permanent fix. If its a large tear you'll need a new cone. I looked a bit online for recone kits for that model but i couldn't find anything. So my advice would be to find a speaker service in your area, or send it back to yamaha for repair. If you want you can do a more thourough search for a recone kit, you might find something... hope you get it workin.
Sep 15, 2009 | Yamaha Music
Blown sub, butIdon't know why
if you use a right channel on one coil and a left on the other different frequencies are going in different directions in each channel thus blowing a coil or badly damaging it-z
Feb 20, 2009 | Infinity Reference 1052W Subwoofer - 10"...
Radio sound with a noise
Please take out the speaker and inspect it for a torn cone. At times, humidity, amp power or just wear and tear ruins the cone. Then you can replace the speaker or re surface the old speaker with a new cone. That will save you some bucks but may not be as well as buying another speaker. Also please use the same model and Ohms of it. 8 or 16 ohms
Dec 30, 2008 | Elliott's Car Radio Ford-COSF-18808-E Car...
What kinda glue do you use on a blown speaker?
A blown speaker needs the windings replaced and re-coned. If you have deteriorating foam\cardboard type edges you an use clear silicone caulk from any home improvement store to fix small tears or detererioration. Tears and such on a large scale will require re-building.
Oct 03, 2008 | Audio Players & Recorders
6x9s cone not working!
can you swap speakers with other one?if so do this and if speaker still sounds bad it is definately the speaker. there is really no way to take speaker apart and repair
Oct 02, 2008 | Infinity Reference 6412cf Coaxial Car...
john
Aug 19, 2008 | Alesis M1-Active MkII Main / Stereo...
 Grubhead
Grubhead
