Question about PRINTER Office Equipment & Supplies
Dremel Build Sheet coming up at conners when when running Dremel 3D printer
    New Friend:
    Problem Solver:
  • 11 Answers
Dremel Build sheets are fixed appropriately before printing the objects from the 3D printer and if these are coming out, you need to get re-fix them, before performing the prints Anet 3D High Precision Quality Reprap Prusa i3 DIY Kit
Posted on Mar 12, 2018
What are your thoughts on 3D printing business?
Do you mean do they work? Yes they do, very well. Or do you mean will 3D printing make a good business? Probably over the long term, but will need a lot of advertising, and seed money. If you have a business plan, you could crowd fund it, if it's a good plan. Go for it!
Aug 13, 2014 | Office Equipment & Supplies
I have a laser printer 8150n. when i gives 20 print on it. on sheet print after another sheet vacant and third print fourth sheet vacant.. what is the reason
Might be page size mis match> Check paper size in system as well as in printer.> Remove tray &check for paper size.> Clean paper path sensors.
Dec 18, 2011 | HP LaserJet 8150n Printer
Why does it print with streaks through the pictures even when ive done the cleaning method a million times?
I've had that problem and running the special blue sheet that comes with the paper pack through the printer seems to work. I've had to run the blue sheet through before each printout for a while, but the problem seems to have gone away - I guess it finally got cleaned out. It also seemed like running the blue sheet through after not using the printer for several weeks was a good idea before printing. When I get a new pack of paper, I run the blue sheet through as instructed. Instead of throwing the sheet away, I store it on top of the blank sheets inside the printer. That way I can use it again if needed.
Sep 29, 2011 | Polaroid CZA10011B PoGo Instant Thermal...
Dremel 300 Series - I can't get a collet to go in the shaft. looks like something the same size is in the shaft but is not proturding to pull it out. Unable to wedge it out.
There is a collet stuck in there. It was probably in there without any tool in place, then the collet nut was tightened. With no tool filling the hole in the collet, it collapsed and became small enough to be pushed too far in. Fortunately these collets are soft steel. Find a sheet metal screw that you can screw into the hole. That will allow you to pull the collet out. Discard that collet. These collets come in at least two sized to accommodate different sizes of tool shafts. Unfortunately the spare one you have is one of those sizes, and the one you extracted is probably the other. But they don't cost much and you can buy them where you buy dremel tools. Good luck, Al K
Feb 02, 2011 | Dremel Variable - Speed Multipro Rotary...
Hi, the paper feed into the printer does not work properly. when printing the sheet will try to deed in, then stop. I can hear the roller still moving until the error lights go off. To get a sheet to print...
get yourself a can of electronic contact cleaner in a arisal can. spray this on a rag and clean the paper feed wheels and the seperator pad (cork piece about 3/16 x 1inch) located right under the paper pick wheel.these wheels get glue build up on them and become slippery the contact cleaner will remove the glue with out leaving a residue behind
Nov 01, 2009 | Lexmark E210 Laser Printer
I often print individual labels, but not all at one time. As I continue to use the label sheet for additional entries the labels get grey looking. Is there a better way to do labels on the WorkCentre 7328?
It is not advisable to run labels in laser equipment without all of the labels on the sheet. The grey looking labels are due to a small amount of backround or build up put on all documents that run through a laser printing machine. Run it through once and you shouldn't be able to notice it, but run the same sheet through multiple times, and eventually you will be able to see the buildup, especially on thick paper such as label paper. What I would suggest is to pickup a cheap inkjet from walmart, and use it for only labels. They are more expensive to run, but with your low volume of useage you probably won't notice it. This will allow you to use labels 1 at a time, and if a label comes off in the printing process, it is much easier to find and remove then it is in a larger laser unit.
Aug 07, 2009 | Office Equipment & Supplies
The HP psc 2210 all-in-one installation disk did not set up the fax
i'd go for contacting HP and check if they have a driver made for your printer that will run on 98, mostly if you unit is bought and made in 07-08, you will only get 2000 XP and vista drivers on the CD, you may try to download other OS drivers online. as far as i have checked it is not available for some reason.
Sep 05, 2008 | HP PSC 2210 All-In-One InkJet Printer
Extra background color in my printing
You really should not run labels through this machine unless they are full sheets. If you are running used pages the glue will build up on the tranfer belt and cause the hazing.
Jul 28, 2008 | HP Color LaserJet 2600n Printer
Hp 2200 laser printer tray 1 paper delivery from top
Are these printers designed to handle Legal sheets?
Did you tell the Printers Software that you will be sending Legal size sheets to this printer?
Apr 10, 2008 | HP LaserJet 2200dn Printer
Top PRINTER Office Equipment & Supplies Experts
Roger Knight
Roger Knight
Level 1 Expert
R Daniel Wolfe
 Andrew Henderson
Andrew Henderson
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
