How fix sc390 code richo - Office Equipment & Supplies
My copier machine comes up with functional error code sc672. can anyone help
That error code appears to indicate 'Op panel to controller problem' see here http://multifunctionalcopier.blogspot.co.uk/2012/06/ricoh-error-code-list.html
Sep 05, 2015 | Ricoh Richo KR-5 with 35-70mm f3.5-4.5...
Mp2000le sc390 - after excute develepor sc390 out..
Perform the TD sensor initial setting after clean the TD sensor.
Feb 13, 2013 | Ricoh Office Equipment & Supplies
Error message sc390
SC390: TD sensor error
-Definition- [B]
The TD sensor outputs less than 0.5V or more than 4.0V 10 times consecutively
during copying.
- Possible causes -
· TD sensor abnormal
· Poor connection of the PCU
Jul 07, 2011 | Ricoh Office Equipment & Supplies
Sc390
SC390 = Toner Density Sensor abormality
Possible causes:
  • Poor concentration of developer
  • Toner density sensor faulty
Are the prints/copies coming out ok? If the copies are very faint or heavily overtoned then changing the developer may cure the error code. If the copies look OK then you probably need to get the toner density sensor replaced by an engineer.
Hope this helps.
Feb 10, 2011 | Ricoh Aficio 450 Copier
Sc390
- Possible causes -
Dec 30, 2010 | Ricoh Aficio MP 1600L Black and White...
Ricoh 3310l fax shows error code 0390H in display. Anyone know what this means?
I've never seen a message like that with the 0390H code. There is no mention of that code in either the user manual or service manual. The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that problem.
If the new PCU doesn't fix the problem, you might want to try calling Ricoh for support, since their documentation doesn't mention that code.
Jun 11, 2010 | Ricoh 3310LE Plain Paper Laser Fax
LANIER 5515 ERROR CODE SC390
the problem is with the toner density sensor.a quick fix would be to replace the photoconductor unit.thereafter you need to do the developer initialization adjustment.
Jun 09, 2009 | Office Equipment & Supplies
Getting a code SC390 on my Ricoh Aficio 1045
I call my tech support. The problem does have to do with an abnormal reading of the Toner density sensor.
Adding toner may be just the ticket to fix the problem.
Apr 15, 2009 | Office Equipment & Supplies
Solve my problum
I have a richo 2018d all in one copier machine it can be a error code SC541.
what is its solution ....
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Richo 3310 fax
What is the model? There are not all the same for the service mode. And what is the reset code for?
Aug 28, 2008 | Ricoh FAX3900L Plain Paper Laser
21 people viewed this question
k24674
