Question about Freezers
Deep freezer defy MODEL DMF2940
Can i please have the drawing and starting Amps of this freezer
    Top Expert:
  • 45,139 Answers
Refer this question to Defy.
Posted on Dec 23, 2016
Specs for arctic king chest freezer model w8s-185c1ws how many watts does it use
Specs don't appear to be available. Freezers are usually rated in amps. To find the watts, multiply the amps by the voltage. Would also depend on the cubic feet of the freezer as the bigger the freezer, the more amps the compressor draws.
Only thing I could find is its energy star rating.
Find and Compare Products
Jul 09, 2016 | Freezers
Start up Amps 14
Hello Matthew, thank you for your question!
Based on the symptoms you are describing, it sounds like the unit could possibly have a faulty compressor or compressor start components such as the relay or overlay assembly. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Sep 14, 2013 | Frigidaire 14.1 cu. ft. Upright Freezer...
Amana upright deep freeze model AFU1505BW K3: We defrosted it today. Now it won't run and get cold after 5hrs being plugged it. Can't hear motor running. Help!
Please check your compressor and capacitor for malfunction. Check also the current draw and compare to your manual. If you got lower ( very low ) current draw reading , you problem with compressor. It may run out of refrigerant and need to top up.Also check your thermostat setting adjust to medium or a little bit colder.
Dec 04, 2010 | Amana Freezers
Start up current draw
Lock motor Amps ( LMA ) is the current draw when the compressor starts.This draw of current is less then 1sec.The amp amount shoud be on the compressor Name Plate.This amp draw is also the amps used when the compressor goes bad and locks up then the overload kicks out.
May 21, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Can I plug my freezer into a surge protector
i know where your going and its a good thought
read your compressor, it will label the start up amp,
it may even be on the model label
it will give you the rated amps and the start up amps
this is current draw to run
as well as start up a stopped motor
depending on the age
most units use about
short of that use a 3x method
if it has the run amp x3 is startup
then read your surge protector if its rated higher than the amps needed to start the unit
then you should be fine
i will say most SP are rated at 15amps
my freezer is rated at 18amperes
Oct 17, 2009 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Have power and light. can't hear compresser run
could be a bad start relay or start cap. could be a bad compressor. if you have an electric meter you can test the ohms of the compressor and that can tell you if the windings are good, however it cannot tell you if the piston is locked. if you have a locked rotor condition and bad starting components you will not be able to tell until you replace the bad starting components and test run. if it hums and draws lots of amps its locked rotor. most compressors will tell you RLA and LRA amperage, LRA is locked rotor amps, RLA running load amps
Oct 10, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Haier freezer hcm050La comes on then shutdown
could be overload, and relay , but more chance the compressor is drawing excess amps and needs replacing
Nov 25, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Kenmore chest freezer.
Most likely a bad compressor. You could try a new relay on it first.
Nov 21, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
175 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
