Question about Hunter Dryers
I would like the electrical shore power diagram for a1992 hunter legend sailboat
2 Suggested Answers
SOURCE: on a 2001 bayliner 2455 some of my electrical doesn't work on shore power
Do the lights or stereo work without shore power? If they don't that you have a dead battery. They are likely part of the 12 volt system and the shore power only charges the battery that runs them.
Posted on Apr 22, 2012
What can I troubleshoot to determine why my RV Rooftop Heatpump does not work on generator, only shore power?
There are a couple of possible causes:
1. There is a Front/Rear Switch somewhere in the unit, usually in the main salon or near the breaker box. This is most common if your generator is not large enough to run 2 units at the same time. It is not always labeled as such, sometimes it's just 1 or 2 and in others it's a set of breakers.
2. You have dropped a leg from the generator output. Normally the generator has 2 outputs, each feeding a separate circuit. This could be in the generator, the transfer switch or the breaker box. If you have issues with other 110v circuits, this would be a place to start.
3.
Mar 18, 2015 | Dometic Rooftop RV Air Conditioner
On a 2001 bayliner 2455 some of my electrical doesn't work on shore power
Apr 22, 2012 | Computers & Internet
Connect (-) power up cable to my four windows acura legend 1192
havent a clue to be truthful,does the kit come with a wiring diagram ,i should imagine that their is a central block with 4 outlets ,one for each window that connects to teh earth side of the window winder motor.if you have a diagram with instructions then i could tell you more sorry
Oct 24, 2009 | 1992 Acura Legend
I have a 1987 mercury 9.9 outboard drive problems
the inside of the prop has a rubber between the prop itself and the inside splines to act as a shock absorber,say if you were to hit a rock. that rubber had spun out and the splines are turning inside the prop. the prop is screwed. seen it 100 times before.
Aug 25, 2008 | Sport & Outdoor - Others
T-stat copatbility
On the back of most t-stats is a dip switch that is marked E or G that is changes the stat to work with either Electric heat or Gas heat just make sure you set it for the appropriate type of heat source your house has. Usually when we speak of Furnaces we are talking about gas, if that is so just change the switch to G. Good luck
Jan 16, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44630 thermostat
Here is a link that will have wiring diagram it is for a similar model hunter. Also check your dip switch on the back of the stat to ensure it is set for gas (HG) or electric heat (HE) depending on your type of unit. Good Luck. Rule of thumb for most four wire systems is RED (power to stat) Yellow (Cooling) Green (Fan) White (heat)
Jan 12, 2008 | Hunter Fan Company 5/1/1 Programmable...
Dryers Logo
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
