Question about Standard (CRT) Televisions
Is there a way to access the T.V. menu without a remote?
I need to know if there is a way to access the menu on the T.V. without a remote. And if there is how? The problem that I am having is that I need to reprogram what channels it will go to by pushing the channel up button, so that I can get in channels here in west michigan. But, I do not have a remote. Is there a way to access the menu? old sony trinitron 19"
  • 298 Answers
Re: Is there a way to access the T.V. menu without a...
A universal remote with all the bells and whistles and
the right working code for your TV, Buttons like
menu, enter,tv.vid,pip, etc
Posted on Nov 20, 2007
  • 1,694 Answers
1) Check for add / erase recessed buttons on set
2) Or consider buying a Sony universal remote for ten bucks
For further help,please supply model number from back of set
Posted on Dec 08, 2007
0 characters
3 Points
Access menu without remote on Toshiba 27AF44
You can follow the option of searching the internet for any of several suppliers of OEM replacement remotes. The problem with universal remotes is that not all functions of the OEM remote are replicated.
Dec 19, 2013 | Toshiba 27AF44 27" TV
How do I access menu screen without remote controller on my hd30746 Sanyo HD tv
Unfortunately without the remote you cannot access the menu screen
Mar 06, 2012 | Sanyo Standard (CRT) Televisions
How do I access the menu without a remote?
You don't. A good "universal remote" available from Radio Shack (Phillips) for about $15 will provide access to all TV adjustments. Easy to program for all TV models, VCR's, DVD players, etc. About $35 + S&H for the Sharp remote replacement.
Nov 14, 2009 | Sharp 27J-S100 TV
How to acess set-up menu without factory remote
The manual can be found near the bottom of the Product page for this TV.
From the manual, pg 11 -
If you misplaced your Remote Control you can still access most settings via the MAIN MENU screen when you press both CH UP (8) and DOWN (9) on the TV set. Some features of your TV Set will not be accessible without the Remote Control. If you lost your Remote Control, contact a Sharp Authorized Servicer by calling 1-800-BE-SHARP for a replacement.
Let us know if this fixes it for you.
Feb 11, 2009 | Sharp 25N-M100 25" TV
Magnavox TV accessing menu without remote
There may be away but need the model number to narrow it down, most remotes can be found at and for usaly under $20.00
Feb 13, 2008 | Standard (CRT) Televisions
Orion model 1929
Mightbe you can buy a universal remote on the market what support your tv set ?
Jan 16, 2008 | Orion1934 19" TV
I need to access the television menu screen
the tv's that dont have a menu button on the front will usually switch to menu by pressing either both chanell buttons at once or by pressing both volume buttons at once if this dont work let me know.
Dec 22, 2007 | Standard (CRT) Televisions
Phillips PC7225 Menu
Found it!
I have a Philips universal remote. After trying half of the codes for Philips TVs, I came up with one which allowed access to the SETUP menu. It was 0621. This allowed me to run the auto channel setup, as well as fix some of the other functions. I don't know if this works with all remotes, but if you try different codes, you should get lucky. I'm sure it helps if you have a SETUP button on your remote.
Dec 08, 2007 | Standard (CRT) Televisions
Accessing Menu Sharp TV
its very easy on the t.v and press on channel up or down on your tv. u will get the screen
Aug 25, 2007 | Sharp 25L-S100 25" TV
Aug 01, 2006 | Sansui COM3101 13" TV/VCR
Standard (CRT) Televisions Logo
1,300 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
