Question about Garden
190c 54 inch deck bought in 2006. Changed fuel filter, fuel pump and vacuum hose, new gas, no leaks, cleaned gas cap breather vent, no obstructions in fuel line. Filter used to run dry in 1/2 hour
Filter used to refill when mower sits for several hours. Gradually, took more time to refill and then run grew shorter and shorter. Now filter doesn't refill with gas no matter how long it sits.
    Top Expert:
  • Garden Master
  • 49,241 Answers
Replace the fuel line from tank to filter mine went bad last summer
Posted on Dec 21, 2016
My cub cadet modle LT1045 doesn't seem to be getting gas. The fuel filter looks clean. If I spray gas directly into the carb it runs fine but as soon as I stop it dies.
Confirm that the choke is closing completely., Check that the fuel pick up hose does not have a air leak. Confirm that the vent hole in fuel cap is not plugged.(common problem)
Remove fuel line hose to carburetor catching fuel output in a suitable container crank engine and confirm fuel pump is working.
Remove fuel bowl and confirm needle valve is not stuck closed.
Hope this helps?
Fuel Pump
Needle stuck closed
ca4f54cab4d4c1bb583599b331fd2337--small-engine-repair-lawn-mower-repair-u3ralalmkh2yk13xn5gn3lpt-2-2.jpg Check fuel filter
Check vacuum line connection for leaks.
Jul 01, 2017 | Cub Cadet Garden
Wont take gas
General advice:I understand as a no fuel condition
1Immo condition,bad key,chip,antenna ring ignition barell
2Fuel pump related:bad fuse/relay,pump malfunction,cloged filter.
3Fuel lines cloged/fuel breather/tank cap cloged (vacuuming the tank,must open to get air,then clean the breathers/cap)
3Dumb guess:no gas in the tank(!?)
Cheers,hope u deal it,share the solution.
Oct 27, 2013 | 2006 Pontiac Solstice
Want idle unless chocked give it gas it dies
It could be a clog fuel filter. you can start in changing the filter and clean the fuel system.
ITP tires
Mar 18, 2013 | Honda 2006 FourTrax Rancher 4X4
My kawasaki 23 hp model # fr691v on a toro 50 inch ztr from home depot started back firing. there was dirt in fuel filter so I changed it. changed the plugs and new air filter. Cleaned the carb. now thw...
hi there
if you had the carby off and cleaned it out , was the fuel flow from tank to fuel pump ( if it has one ) good , and was the output from pump to carb good on cranking?
if so and the breather in cap is venting , it could be that the governor needs adjusting, possibly have got a spring in the incorrect position and there is no binding , pay to check , carby main jet closly for any obstruction. check the fuel level and float hieght .
most times hunt / surge is caused by obstruction to fuel flow , or governor
try holding the governor in a fixed position if hunt / surge still apparent - carby is causing fault
but if not governor setup is causing problem
cheers pauly46
May 28, 2011 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
My 95 7.3 turbo runs and idels good no miss but something is holdeing it back when u push the gas I have changed the fule filter and air
Here is what my Haynes Diesel Engine Repair Manual says for a noticeable lack of power, which is what you are describing.
1. Blocked air intake
2.Incorrectly adjusted timing
3.Blocked or damaged exhaust system
4.Obstruction in fuel filter
5.Blocked fuel tank vacuum vent in fuel cap
6.Insufficient fuel supply from tank to injector pump
7.Obstruction in fuel tank filter
8. Pinched or restricted fuel return line
9. Incorrect or contaminated fuel
10.External compression leaks ( glow plugs or injectors)
11. Obstruction in injector nozzles
12.Low compression
This book has an excellent diagnosis and repair section for your engine. It's Haynes part #10330 and costs about $20. Hope this helps.
May 27, 2011 | Ford F-350 Cars & Trucks
I have 120000 model engine on a troybuilt 566 self propelled mower. The engine will start and run for about 3-4 seconds and die. I have changed the spark plug,air filter, cleaned the fuel line, and...
You have done the correct things. This is definetely a problem with the fuel supply. Here are some other things to check.
1. Loosen the gas cap to ensure you don't have a vacuum in the tank. If you have a vacuum in the tank, it can prevent fuel from flowing to the carb. This is an easy thing to check, typically the engine will run for longer than 3-4 seconds when first started, but when restarted I have seen short run times like this. There should be a vent hole on the gas cap to prevent this from happening. If this is the problem clean the vent hole or get a new cap.
2. I don't know if this engine has a fuel pump, but the troubleshooting process is the same. Take off the hose to the carb and make sure you have fuel flow to the carb (use gravity if it doesn't have a fuel pump, or crank the engine if it does). If you have fuel, then the problem is in the carb (probably a stuck needle in the bowl assembly). Disassemble the carb bowl and clean the needle and seat with carb cleaner.
3. If you are not getting fuel through the hose to the carb, then you have a bad fuel pump or a plugged line.
Apr 18, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Hi, I have a scanner cause engine light is on, shows vacuum leak large. tried new gas cap, cleaned filler tube where gas cap contacts, replaced a plastic tube from valve cover to air filter hose. tried to...
what code is it?po440,p0455?If it is one of those codes it means you have a large evap system leak not a vacuum leak by the engine.the evap leak is most likely a inop vent valve or a fuel cap not properly sealing.
Apr 13, 2011 | 2005 Chevrolet Uplander
Poulan Pro 20hp Tractor with B&S fuel flow problem
sound like to m e that your gas cap is bad if its not venting it will do that
Apr 16, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman riding mower 2003 DLT 3000 ,Blowing oil out of the fuel
Head gasket is blowed .Its building pressure in the crankcase seen it twice. Remove the head and check for a blowed out spot between piston and the valve side
Jul 29, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
