SOURCE: MFC 7420 always say toner low after you change new toner
1. Open the front cover door.
2. Press the "Options" button.
3. Type *00 on the keypad.
This will clear the error message.
Enjoy!
SOURCE: Brother Printer won't accept mostly full toner cartridge
On the side of the cartridge (TN2000) there is a white reset flag, this need to set to twevle 'o' clock, thats towards the black roller. If that hasn't been reset the cartridge will register as low.
SOURCE: Install Cyan Toner Error
ensure that the one you install is the exact model name and number, if this is correct, try unistallling once again and check one more time,
you might want to get a new cyan toner if this still fails, i dont think there is a prob in your machine, cheers
SOURCE: BROTHER MFC 7820N MACHINE PUT IN NEW DRUM, CHANGE
To manually reset the counters, do the following:
(If nothing happens when pressing option, try using the back/clear button instead.)
SOURCE: The display reads "TONER LIFE END". But when I put
You need to reset the drum counter in order to reset your machine.
Press the cover release button and then open the front cover of the printer. Press and hold down the Go button until it displays "DRUM CLEAR". Release the Go button, close the cover and you should be all set.
I hope this helps.
