Question about Boating
88' Johnson 25hp tiller install model #j25tecca. replaceing with a 89 15hp tiller. cant find any instructions of how to install. help.
  • 6 Answers
SOURCE: 1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Posted on Jun 30, 2009
  • 1168 Answers
SOURCE: I have a 1970's 25hp Johnson outboard motor. Last
Hello Adam.
If your propeller is OK, your lower unit will need some repair. It may be as simple as a clutch dog worn and not engaging the gear. Usually they give warnings of problems by jumping out of gear though.
Other possibilities are broken driveshaft, propshaft, or gears. If it goes into reverse the shafts are OK and the clutch and forward gear become suspect.
It was common for these engines to break at the top of the driveshaft where they were tapered.This would give you no motion at all and no previous warning of a problem.
Check the gear lube for metal particles and signs of water intrusion. I hope your repair is an easy one.
KL
Posted on Dec 08, 2009
fishdoctorfi
  • 178 Answers
SOURCE: What is the corrct fuel mix for 2005 25hp johnson
2 stroke is rated at 100 to 1... but I always run it a little more like 50 to 1. I would rather put plugs in it than burn up a motor for lack of oil......
Posted on Dec 25, 2009
SOURCE: Bolens model 3012H lawn tractor attachment install instructions
I don't know the answer to this question but I wouldn't mind getting one of those tillers for my tractor. If you ever decide to part with it let me know! j e s s e m e r s o n @ m y m a c m a i l dot com
Posted on Aug 12, 2011
  • 1602 Answers
SOURCE: I have a 99 25hp Johnson Sometimes if seem to be slipping as its going
check all the fluid levels, make sure the service work up to date, if you stretched the service like the oil, transmission fluids you brake down the formula of the oil. than you loose the performance of that fluid. smooth run.
Posted on Oct 09, 2015
Does 1984 25hp johnson at tor need 2cy oil mixed wiyht gas
All 2stroke engines need 2stroke oil in the fuel !!! 50 to 1 mixture ! fuel to oil !...
Sep 23, 2014 | Seloc Johnson Outboards 2002-2007 Repair...
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Trying to get lower unit off a 88 25hp evinrude motor
www.youtube.com go there and type water pump replacement 25hp Johnson or evinrude. You can also go to
http://shop2.evinrude.com/Index.aspx?s1=gett3uheq5c0nce2mjg11d1eh0&catalog_id=0&siteid=1
Thank you, Lewis Hot Headz Marine
Sep 25, 2013 | Boating
1973 to 1989 Johnson 25hp cant find model or serial number
unless someone removed the plate it's usually one one side or the other of the motor mount.
Aug 13, 2013 | Boating
I cant find model or serial number on my johnson 25hp
usually had a brass plate on one side or the other with the numbers on it
Johnson outboard 25hp
You may be able to find a solution on the iboats.com boating forums.
http://forums.iboats.com/johnson-evinrude-outboards-24/
May 28, 2013 | Boating
Dec 25, 2009 | Boating
Hello Adam.
KL
Dec 08, 2009 | Boating
Disassemble 88 SPL Lower Unit
I dont have a diagram to send you, but if you take the model number and serial number to you local Johnson/OMC dealer they have all the diagrams and have even photo copied them for me to use
Jul 24, 2009 | Boating
Jun 30, 2009 | Sport & Outdoor - Others
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
