Question about Pelonis Heating & Cooling
Pelonis heater not blowing hot air
Space heater is problem
vmhreha
  • 77 Answers
SOURCE: air condition/heater
sounds like the air-conditioning expansion valve is probably not working correctly here is a way you can fix your air conditioning:
  1. Realize that auto AC is basically a refrigerator in a weird layout. It's designed to move heat from one place (the inside of your car) to some other place (the outdoors). While a complete discussion of every specific model and component is well outside the scope of this article, this should give you a start on figuring out what the problem might be and either fixing it yourself or talking intelligently to someone you can pay to fix it.
  1. Become familiar with the major components to auto air conditioning:
  2. the compressor, which compresses and circulates the refrigerant in the system
  • the refrigerant, (on modern cars, usually a substance called R-134a older cars have r-12 freon which is becoming increasingly more expensive and hard to find, and also requires a license to handle) which carries the heat
  • the condenser, which changes the phase of the refrigerant and expels heat removed from the car
  • the expansion valve (or orifice tube in some vehicles), which is somewhat of a nozzle and functions to similtaneously drop the pressure of the refrigerant liquid, meter its flow, and atomize it
  • the evaporator, which transfers heat to the refrigerant from the air blown across it, cooling your car
  • the receiver/dryer, which functions as a filter for the refrigerant/oil, removing moisture and other contaminants
  1. Understand the air conditioning process: The compressor puts the refrigerant under pressure and sends it to the condensing coils. In your car, these coils are generally in front of the radiator. Compressing a gas makes it quite hot. In the condenser, this added heat and the heat the refrigerant picked up in the evaporator is expelled to the air flowing across it from outside the car. When the refrigerant is cooled to its saturation temperature, it will change phase from a gas back into a liquid (this gives off a bundle of heat known as the "latent heat of vaporization"). The liquid then passes through the expansion valve to the evaporator, the coils inside of your car, where it loses pressure that was added to it in the compressor. This causes some of the liquid to change to a low-pressure gas as it cools the remaining liquid. This two-phase mixture enters the evaporator, and the liquid portion of the refrigerant absorbs the heat from the air across the coil and evaporates. Your car's blower circulates air across the cold evaporator and into the interior. The refrigerant goes back through the cycle again and again.
  2. Check to see if all the R-134a leaks out (meaning there's nothing in the loop to carry away heat). Leaks are easy to spot but not easy to fix without pulling things apart. Most auto-supply stores carry a fluorescent dye that can be added to the system to check for leaks, and it will have instructions for use on the can. If there's a bad enough leak, the system will have no pressure in it at all. Find one of the valve-stem-looking things and CAREFULLY (eye protection recommended) poke a pen in there to try to valve off pressure, and if there IS none, that's the problem.
  3. Make sure the compressor is turning. Start the car, turn on the AC and look under the hood. The AC compressor is generally a pumplike thing off to one side with large rubber and steel hoses going to it. It will not have a filler cap on it, but will often have one or two things that look like the valve stems on a bike tire. The pulley on the front of the compressor exists as an outer pulley and an inner hub which turns when an electric clutch is engaged. If the AC is on and the blower is on, but the center of the pulley is not turning, then the compressor's clutch is not engaging. This could be a bad fuse, a wiring problem, a broken AC switch in your dash, or the system could be low on refrigerant (most systems have a low-pressure safety cutout that will disable the compressor if there isn't enough refrigerant in the system).
  4. Look for other things that can go wrong: bad switches, bad fuses, broken wires, broken fan belt (preventing the pump from turning), or seal failure inside the compressor.
  5. Feel for any cooling at all. If the system cools, but not much, it could just be low pressure, and you can top up the refrigerant. Most auto-supply stores will have a kit to refill a system, and it will come with instructions. Do not overfill! Adding more than the recommended amount of refrigerant will NOT improve performance but actually will decrease performance. In fact, the more expensive automated equipment found at nicer shops actually monitors cooling performance real-time as it adds refrigerant, and when the performance begins to decrease it removes refrigerant until the performance peaks again.
Posted on Jun 05, 2008
SOURCE: heater blows only cooled air
my heater only blows cold air please could you give me some advice on this thanks . everything else is ok temp ,engine etc
Posted on Oct 02, 2008
rickzilla
  • 706 Answers
SOURCE: Heater wont blow hot air anymore.
In all probability the heating element has failed and the cost to repair would be more than the cost to replace it. Inexpensive heaters do that over time.
Posted on Dec 02, 2008
OLDERQT
SOURCE: 93 gmc sierra heater not working
THERMOSTAT REPLACE IF NOT SEE IF HOSES ARE CLOGGED SHOT OF AIR COULD HELP OR DISSCONNECT BATTERY CABLE 10-15 MIN CONNECT BACK TRY HEATER
Posted on Jan 04, 2009
  • 12 Answers
SOURCE: Heater doesn't blow hot air
First check the coolant level in the radiator. Check your heater core hoses on the firewall underneath the hood. Let the car come up to temp. and feel the two hoses. If only one of them is getting hot you may have bad heater core or a bad heater control valve.
Posted on Jan 05, 2009
How do i get my pelonis electric heater to work right?
sometimes it helps to blow thru them with compressed air backward. some dirt gets past filters
Jan 07, 2015 | Pelonis Heating & Cooling
Pelonis heater smells like burning something
Three possibilities come to mind: First, there may be some foreign objects stuck between the sections of the coils where they connect or in their individual holes, the next is that the cord or outlet in your house is getting too hot (the circuit is being overloaded, perhaps; and finally, the clincher, you have a tiny oil leak in the coils themselves.
Jan 15, 2013 | Pelonis WM-HO202C Oil Filled Radiator...
I wondering if my Pelonis gas-filled heater is emitting dangerous fume causing me to feel depressed... do you have the phone number of the company?
Have you tried not using the heater for several days to a week, to see if your depressive state improves? That would be the litmus test involving the heater, wouldn't it?
Never the less, their phone # is 1-866-876-4332
Feb 16, 2011 | Pelonis HO0221 Electric Radiator Heater
Heater is not blowing hot air like it use to only warm air?
You can try using a compressor and blow gun and cleaning it with the forced air once front to back and back to front. There is no given number of times to do this, I do it until I have clean air going thru both directions. This is the easiest way with out taking the fan apart and man it is a fast repair for sluggish heaters.
Dec 21, 2010 | Pelonis PF-1212-L3 FlexiFurnace II Ceramic...
Where can I get a replacement air filter?
dear sir/madam
please try to search at near of your area on pelonis product,s dealer and then you can buy your air filter there.
hope answer the question
thank you
please vote!
Sep 29, 2010 | Pelonis Disc Furnace Heater
Only warm air
If its' tank is full of water then empty it. If it is not full of water then the switch underneath the tank may be faulty
Apr 19, 2010 | Pelonis KCD-25YI Air Conditioner
When temperature is placed on HI, very little heater comes from heater
if the fan is blowing air normally, but the heat is less! than you need to replace the heating coil of the heater. i'm sure your problem will solved................have a nice day:-)
May 13, 2009 | Pelonis WM-HO202C Oil Filled Radiator...
I need a switch for Pelonis 4 Disc Ceramic Space Heater Furnace 1500W
generally a primary power swich can be obtained at your local hardware store. A switch rated for at least 15 amps will be needed. Unplug the heater remove the bad swich and take it with you, match up a replacement and install.
Dec 18, 2008 | Heating & Cooling
Heating & Cooling Logo
41 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
