Question about Sewing Machines
Pr655 first inappriate needle position then says then days main motor current error. Machine will not comes on is working but will not push needle through fabric without stalling. What can I do?
  • Sewing Machines Expert
  • 484 Answers
Have you tried a new needle, perhaps it is blunt. Or perhaps your fabric is too thick for the needle you are using.
How to get brother pr600 out of main motor test mode?
Looks like the machine is bound up, or the motor is failing. If the hand wheel is easy to turn then it is probably the motor drawing too much current.
Brother recommends a new motor and belt every 1500 hours of run time.
Feb 25, 2015 | Brother Sewing Machines
What is the best course of action.I have a 10 needle baby lock Plus, today my "Main Motor Current Error" appeared on display screen. I shut off for short time and started again. Is there anything i can do...
From the Brother web site I find, " If you are receiving a "Main motor current" error message indicates there is a problem with the unit, and it is recommended that you get the machine serviced.
Take your machine to the nearest Authorized Brother Service Center for repair.
You can locate a Brother Authorized Service Center (ASC) in your area by clicking on the link below.
http://www.brother-usa.com/service/default.aspx or contact Brother Customer service by calling 1-877-Brother (1-877-276-8437) Monday through Friday, excluding holidays.
Service Center Locator
Feb 21, 2015 | Baby Lock Sewing Machines
I have a Juki ams-210en that is giving me error e306 thread clamp position error. what is that and how do you fix it
hello Rick
have a good day to you
regarding JUKI machine model AMS-210EN with error E306 please check next points:
1-Needle thread clamp pulse 1-A) There is a certain obstacle in Check the mechanical block to see if there is any
Needle thread clamp position error motor fails to properly work. the mechanical block. position with a heavy load or any section caught
by something.
1-B) The driver circuit is out of order. Replace the MAIN board.
1-C)Motor defective Measure the resistance of the motor winding by means
of a circuit tester.
2-The sensor is not turned ON. 2-A) Sensor defective Check the sensor with the check program I_03.
2-B) Disconnection of connector Check CN66 of INT board.
2-C)Sensor mounting inadequate Check the operation with the check program I_08.
BEST REGARDS
aabozid@hotmail.com
ASHRAF ABOZID
CAIRO - EGYPT
Jan 06, 2015 | Juki Sewing Machines
Main motor lock, inappropriate needle position, after broken needle
The broken needle may be lodged in the bobbin housing. If you cannot locate, take it in for professional servicing. You may have put the timing out of whack.
Mar 09, 2014 | Brother Sewing Machines
I have a new Singer 1507 sewing machine- needle position wrong
Turn the big knob on the right of your Singer 1507 machine so that the vertical stitch line in the center. (Currently your machine most likely has the vertical stitch line to the left.) Don't push your needle manually; you will damage the needle.
Nov 22, 2009 | Singer 1507
Brother PR-600...does anyone know if it's a major problem if it says "main motor lock"? The needle broke while sewing, and it is stuck in the down position and will only say "main motor lock" on the...
I took the case off, and was able to raise the lever, and am NOT getting the error msg anymore. However, now machine is out of time (I think) I want to fix it myself...can I?
Nov 04, 2009 | Brother Sewing Machines
Step motor error Janome My Craft step motor error shows up on screen and then stops. Turn machine off, sometimes comes back straight away then another time it may be a day or so later. Is this a motor...
If it really is your motor overheating, you either need it serviced, or replaced, possibly with another machine which is more suited to the type of sewing you do.
Feb 19, 2009 | Janome Memory Craft 9000 Computerized...
Brother pro 600 embrodiery machine
You may have a bent bar inside the machine (big trouble), needle error is easy it is just to wind the big nob at the back of the machine, make sure you are on the correct needle when you move it, on mine it is a little stiff, just do it slowly. The engineer just bent my bar back into shape, that was 1yrs ago. Good luck have fun :-)
Karen (wytchstitch)
Oct 21, 2008 | Husqvarna Designer I
Sewing Machines Logo
98 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
