Question about LG Dryers
My dryer is a lg dlex700ve it powers up and looks like it would work but will not run when I push the start button it just clicks?
  • LG Master
  • 2,300 Answers
Check to make sure dryer drive belt is not broken. Broken belt trips a switch.
Posted on Dec 31, 2016
Why will my dryer not start, but makes a clicking sound?
If the motor runs and the drum doesn't turn the belt may be worn or broken...or you may have a faulty idler
Aug 15, 2014 | GE Dryers
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 | LG Dryers
LG Gas Dryer (dlg0452w) needs a push to get going
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Apr 19, 2010 | LG DLG0452W Gas Dryer
LG Steam Dryer (DLEX3001R) won't start
Do you have 240 present at dryer. If so then check the belt and blower.
Oct 06, 2017 | LG Dryers
Drier button does not work when push it to start machine
You need to check the dryer door switch. I may be bad. If the timer is clicking it is probably working fine. Also you need to check that the dryer is getting power to the unit. Check your breakers and also pull the unit out and look at the dryer cord. Check the terminals for a short or burnt looking one. Once you have established you have power going to the unit, you can find where the comunication stops within it.
Apr 09, 2009 | Kenmore Dryers
Dryer won't work
Hi ginisa;
There might be a thermal cutout on the motor that drives the drum. You can check this by removing the back of the dryer. Most of them come off after removing a few small bolts. Look for a red button on one end of the motor. BTW, unplug the dryer before you take the back off. If you find the red button push it in and then plug the dryer in to the wall and see if it will run.
The thermal overload is a safety device that shuts things off if the motor gets too hot. So even if it does start and run, check it closely so see if it gets hot.
Hope this helps Good Luck Loringh
PS please leave a rating if appropriate Thanks
Nov 22, 2008 | LG DLE2532W Electric Dryer
Dryer runs like everything works but it is not heating
Check the high limit switch located at the combustion chamber tube.  There is reset button.  Push the button.  If you hear a click, then it should work.
Apr 13, 2008 | LG DLG5932W Gas Dryer
Dryers Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
