How do I find Catch Up on my PVR decoder? - Televison & Video
When I cancelled my extra view do I lost the option of record and play back on my PVR
probably will . we here at FIXYA have no idea what that company does
Aug 12, 2016 | Televison & Video
Hi I have a PACE PVR Decoder which skips channels when p+ / p- is pressed
Hi, This may be due to one or two things. The remote and the box should have P+ and P- buttons. If the box operates ok but the remote doesn't the remote buttons are causing what is called switch bounce and needs replacing but if the box and remote jumps channels they are not the cause but programming and memory retention of the PVR.
Make sure the pvr is not recording anything first as this may inhibit some channels from showing. go to the update page and make sure that the box is fully updated. Another reason could be the aerial not giving strong enough signals for some of the multiplexed stations. To check this select the channel number rather than using P + or P-.
If the channel does not show it could be signal related or moved to another number and not updated. Tim
Aug 22, 2014 | Televison & Video
New remote is not working on the pvr decoder
You have to setup the device with its codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 27, 2013 | Universal Remote Control Dish Network...
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
Sd pvr remote
it sounds like the remote needs to be re-programmed to work with the device. the 2 blinking dots illistrates that it is looking for a device to operate.
May 03, 2012 | Televison & Video
Connecting pvr dstv decoder 3001
My pvr decoder model 3001 remote control doesn't work I checked battrey it works but no answer for decoder what shall I do
Dec 15, 2011 | Televison & Video
I'm not able to connect my dstv decoder and dvd player onto my samsung 51"plasma tv because there's only one AV plug. Can you please help?
  • i cant connect my standard decoder to samsung 51inch as ther are only ports compements and hmdi,do i need a pvr decodr?
Jul 12, 2011 | Televison & Video
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
