Question about Toshiba 50L4300U 50" 1080p LED-LCD TV - 16:9 - HDTV 1080p 1920 x 1080 - Audyssey EQ, Audyssey ABX, Audyssey Dynamic Volume - 4 x HDMI - USB - Ethernet - Wi-Fi - PC Streaming - Internet Access - Media Player
I have a 50 inch Toshiba 50L4300U that has no picture but has sound. What board do I replace?
  • Toshiba Master
  • 10,543 Answers
Do this test first. With the TV on normally, shine a flashlight on the screen. look for a dim moving picture.
1) If you see one, the backlight led driver isn't working.
2) If you DON'T see a picture replace the T-Con board.
You can get parts here: www.shopjimmy.com TV Parts Universal TV Stands DLP Chips ShopJimmy
Posted on Dec 21, 2016
Testimonial: "Which bed is which. One is green and one is tan."
  • Laurie Kaczmarek
    Laurie Kaczmarek Dec 21, 2016
    Which board is which? What is the bed number for the back light led driver?
  • Lawrence Oravetz Dec 22, 2016
    The folks at shopjimmy can give you that information for your model TV. They are great to do business with.
SOURCE:
My toshiba TV 50L4300u goes from clear to blurry back to clear every other second
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 26, 2015 | Toshiba 50 Inch Cloud LED TV 1080p Smart...
Screen moving in and out of focus regardless of input or settings
Fault to its T'Con board. Replace it. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 27, 2015 | Toshiba 50L4300U 50" 1080p LED-LCD TV -...
I have a horizontal line about 1/3 way down from top of tv, resulting in bottom 2/3 with slightly "blurry" picture alternating with normal picture every couple seconds. Any tricks, tips or diagonstic
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 14, 2015 | Toshiba 50L4300U 50" 1080p LED-LCD TV -...
How do I restore picture? Worked fine when turned off night before. this morning, no picture, only sound
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sep 19, 2014 | Toshiba 50 Class 1080p 120Hz LED Smart HD...
Power surge on my Toshiba 50L4300U and now no sound. I do have picture
Check fuses and breakers on Polk.
If they are ok then take it to the shop.
Mar 30, 2014 | Toshiba 50L4300U 50" 1080p LED-LCD TV -...
My toshiba 50 inch when i plug it in it clicks and that's it no picture sound nothing
not knowing the model number just a general answer: Click is likely a mechanical power relay that should do that--problem likely in power supply of set or something triggering protective shutdown elsewhere in set, a bit like saying my car won't start as a number of different reasons for this issue.
Nov 03, 2012 | Toshiba Televison & Video
Toshiba Projection Television TZ50V61, Red power light blinks, no picture, no sound
That sounds like the deflection board. You can get the replacement deflection board from www.tvrepairworld.com under Toshiba Circuit Boards catagory
Jun 14, 2011 | Toshiba TZ50V61 50" Rear Projection...
No sound
make sure the external speakers are not turned off
Apr 28, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba 50L4300U 50" 1080p LED-LCD TV - 16:9 - HDTV 1080p 1920 x 1080 - Audyssey EQ, Audyssey ABX, Audyssey Dynamic Volume - 4 x HDMI - USB - Ethernet - Wi-Fi - PC Streaming - Internet Access - Media Player Logo
435 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
