Question about Beko Refrigerators
Hi i have a beko american fridge freezer and the red light has came on and the freezer isnt as cold as it should be, my food has started to defrost?
SOURCE: Food defrost alert
1. try re-gassing
2. the fridge rear wall may have come detached from the evaporator - if so get a new fridge youf FFA70 cannot be repaired
Posted on Jan 05, 2008
SOURCE: Hotpoint FFS70 fridge/freezer
water keeps appearing beneath salad bin we have checked to see that nothing has come into contact with back wall of fridge ,and we have used a straw to keep the defrost gutter drain hole clear but water still appearing beside gutter drain hole .
Posted on Mar 02, 2008
SOURCE: SAMSUNG RS20CCMS AMERICAN STYLE FRIDGE FREEZER
in the freezer section there is a 6 screws. unscrew them and remove the back panel. there will be 2 wires attached to the panels, remember where they go. you will see a metal evaporator which will be filled with ice. this is the problem. use a hairdryer to melt the ice. this is essential as you mustn't puncture the wall of the fridge with any sharp item. before replacing the panel ensure that everything is dry or ice will reform, and also ensure that the fan blades are turning properly or cold air will not be blown into the fridge.
Posted on Dec 10, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
iwillfixforu
  • 619 Answers
SOURCE: GE fridge/freezer on but no cold air
The main board on the back of the unit has gone bad or in lockout. Try unplugging unit for about 30 seconds. Then plug it back in. If it doesn't start the board is bad. wr55x10942 at about 169.00. Hope this helps. Very common GE problem
Posted on Mar 07, 2010
Hi. Why has my Beko fridge freezer ceased freezing. Fan & light still function.
compressor is running? u can hear it? may have a freon leak? or check the defrost timer or cold control thermostat, some freezers have a freezer thermistor may have gone bad can check all with a multi meter
Mar 10, 2015 | Beko Refrigerators
I have a Beko frost free fridge freezer kept in a garage that has all of a sudden just stopped working. I noticed that the bread I'd put in the freezer hadn't frozen and then noticed that the fan had...
If the fan has failed or intermittent, the freezer wont freeze the food properly but usually you get a mountain of ice build up at the back of the freezer. This ice jams and stops the fan from turning. Alternatively, there could be a defrost problem. Unless it is a fully electronic defrost machine, there is usually a little timer on the back of the fridge to force a defrost after a certain time. The fridge will turn off, the defrost heater operates to melt the ice and then usually with 20 to 45 minutes, the defrost timer will "click" back on and start the fridge running again. If the timer is sticking, the fridge may stay on its defrost cycle and never start again, thus, it doesn't get cold. If you find the defrost timer, have a close look for a little shaft or slotted screw type stud sticking out of the middle of it. A slight turn of this and you should hear it clicking around. When you hear a loud click, that is either the start or end of the defrost cycle. If you have a full electronic defrost system, it may be a failed board, heater, thermostat or defrost safety fuse.
Jan 05, 2015 | Refrigerators
Why is fridge freezing the food?
If your refrigerator has a separate "cold control" it could be defective.
Jul 19, 2014 | Beko Fridge/freezer Thermostat Genuine...
Hi,im having trouble with a hotpoint fridge,model number ctx14cybjrwww.Problem is the fresh food area isnt cold,yet the freezer area is.Thx for any help
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 15, 2011 | Hotpoint Refrigerators
Fridge freezer problem
Sounds like the defrost system of your freezer is not working. It could be either the defrost timer, defrost thermostat or the heater has a problem. The defrost timer turns off the compressor periodically to sent power to the defrost heater via the thermostat. The defrost heater then powers up and heats the evaporator coil to melt the accumulated ice buildup on the cold coils. Most likely issues are that the timer motor is not advancing the timer or the heater itself has burned out.
Jul 14, 2010 | Freezers
Fridge too cold.Freezer OK.
You probably have an issue with one of the following:
* temperature control assembly (controls freezer and/or fresh food temperatures)
* damper assembly (allows air from freezer to fresh food compartment)
Contact an appliance service company.
Feb 26, 2010 | Refrigerators
BEKO FRIDGE FREEZER
The best way is open freezer door wait 30 seconds then shut if the door pulls shut further then machine is working if not not working.
Thanks J
Dec 23, 2007 | Freezers
This is normal  the red light tells you that there is a slight of decreased in coldness .Eventually the red light will  disappear after the refrigerator has recollected it's coldness... in 24 hours approximately .....Jack Arevian.(.Aleppo Syria).Refrigeration Engineer...........
Oct 16, 2007 | Hotpoint FFS70 Bottom Freezer Refrigerator
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Refrigerators Logo
35 people viewed this question
Top Beko Refrigerators Experts
John Tripp
John Tripp
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
