Question about Water Heaters
Will my fury (vt1300cxa) start if the emission controls were flooded with water?
Where is the thermostat located on a rheem fury 81v52s ?
Hi, The thermostat on most hot water heaters is part of the gas control unit.
if you disconnect the wiring on an electric unit or the piping on a gas unit the whole controller should screw out. Make sure that the electrical power is off, gas **** is closed and water tank is empty.
Hope this helps.
Rob
Oct 07, 2011 | Rheem Water Heaters
The water leaked out overnight. We have not tried to start it again as it is still dripping water. We have a rheemglas Fury Model # 22-40 natural gas.
Open following link to troubleshoot cause and solutions for leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
Rusted water heater must be replaced.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
For money-saving water heater information:
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 28, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
I just bought a house, and the water heater instructions posted on the water heater is all covered up by the earthquake straps! The earthquake straps are a requirement in California, I can't remove them....
1) Model 41VR50N is Rheem fury gas water heater.
Look on tank label, the second 2 digits of serial number are year of manufacture.
2) Rheem does not show that specific model number, but has generic manuals for Fury series:
Open link to read about Fury series, and access brochures and manuals.
http://www.rheem.com/product.aspx?id=CC643E03-4C15-4775-B139-E504A95651F7
3) Sample manual for Fury appears on following link:
http://globalimageserver.com/fetchDocument.aspx?id=01091171-3bac-4cb9-a0a8-a11aac3bd668
4) Rheem phone number: 1-800-432-8373
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Jan 30, 2011 | Rheem Water Heaters
I have a Rheem glas fury model 22-40 gas water - leaking
Dear Hank McNeal; I have successfully used a "boiler plug" to seal a water heater tank leak in 2007. It was a 100 gallon electric commercial hotel unit. To this day it's still in use. It depends where the leak is located....Predrilling the leak is necessary to be sure the plug will ernguage it's threads into good material... Start as small as possible, then use the best suited plug. they come in an assortment of sizes. rheem-glas-fury-model-22-40-gas-water-qbzdprdp3yetvbzozs4dsujq-4-0.jpg
Oct 23, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water Heaters Logo
37 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
