Question about Exercise & Fitness
When I hit the speed up button on my Solaris a 2050 the cool down blue mark on the screen pops up and the treadmill shuts down
  • 6,694 Answers
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts.
Posted on Dec 22, 2016
5 Suggested Answers
  • 5370 Answers
SOURCE: Horizon Fitness Treadmill - Quantum
Check the treadmill "continuity" , the treadmill connections correctly grounded. If that is checked ok then either the outlet itself is bad .Try plugging the treadmill on another stronger outlet, such as a kitchen outlet..But if its still shorting out and blowing the fuse then its internal motor problem.The motor or its wiring is got weak,so when you press the start button the motor starts and treadmill turns off and blow fuse.--------- This should help.Thanks.Helpmech.
Posted on Jan 23, 2011
  • 12223 Answers
SOURCE: i have a new balance 1500 treadmill that needs to be repaired. While running the incline went all the way up and I could not get it to come back down using the up and down buttons, i hit the power bu
please RUN THE software calibration for easy diagnostic, troubleshooting and fix it easy
God bless you
Posted on Oct 02, 2012
  • 12223 Answers
SOURCE: the treadmill shuts down as I go faster
This happen because the lack of LUBE maintenance schedule
Lube with 100% silicones or wax see your instr. manual
2) Lube the rollers bearing. with wd-40
3) test the drive belt motor.
4) Test the input voltage motor, if there are the motor need repair
see my personal TIPS for motor help
5) Test the output board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Posted on Dec 05, 2012
  • 937 Answers
SOURCE: Pro-form 1160 treadmill. When start button is pushed after speed sellected motor starts and immediately shuts off as if stop button was hit? Control board or motor issue?
2 good guesses. I think motor more likely.
Posted on Jan 11, 2015
The speed will not decrease once the treadmill is started. The speed will increase when the button is selected but will not decrease when selected. Everything else still works except the (speed down)...
Most likely the directional PCA has popped out of its housing. There is a small circuit board underneath the quick start button that works the controls. They are notorious for coming loose. If board is still in the housing then then speed down sector of the board may be bad and it will need to be replaced
Aug 13, 2013 | Precor C954i Commercial Treadmill
Life fitness 95t speeds up after confirming slower speed in cool down mode, and also pauses after touching increase button on screen. both issues are dangerous
book an engineer, sound like motor controller, loose belt could also be a issue, needs a safety check where are you based ?
Jan 27, 2013 | Life Fitness Exercise & Fitness
I hae a Pro Form 540 Iteracive Trainer treadmill. When the key is inserted, the treadmill cuts on but the control panel doesn't seem to work when you touch start. I waited and cut it off and went...
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful."
Aug 08, 2011 | Sport & Outdoor - Others
How do you shut this thing off . the lights on the display stay on. reebok 8700es
Hols the stop button and the speed decrease button down while inserting or attatching the key (magnet). There should be a "d" on the screen, press the incline down button and it should go away. As soon as it disappears, your done. Just pull the key off and your display will shut off.
Hope this helps
Nov 06, 2010 | Reebok 8700 ES Treadmill - Silver Service...
Hello, I have a Nordic Track 2050, and got on this
console is bad no other alternative, check ebay for part
Jul 05, 2010 | Nordic Track NordicTrack Treadmill, A2550
The incline will go up, but will not go back down. I have had this trouble since I bought it, and should have just returned it, but I have had it for several years now. I called for tech support a few...
Press down the stop and speed up button. Hold these buttons down and insert the safety key then release all. The screen should be different. Press stop once and hit the elevation up or down button. These are general direction. If you look under the hood of the machine, there is a trouble shooting guide. It will have the exact calibratiing proceedures.
Nov 01, 2009 | Proform Crosswalk 500 Treadmill
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
