Question about Roper Washing Machines
How to change motor coupling on a roper top load washer
How to change a motor coupling on a roper top load washer
  • 239 Answers
Two screws to flip up top control panel. 2 clips to take off case. remove pump. then remove motor and change coupling. reassemble.
Posted on May 08, 2017
  • 481 Answers
SOURCE: Roper top load lint filter
it has a self cleaning filter mounted under the tub. if you want to clean out the tub and filter thoroughly then:
  • run a cycle with no clothes using hot water and a gallon or two of bleach.
  • after the tub has filled up add a teaspoon or less of dish liquid like palmolive. this acts like a surfactant for the bleach.
  • make sure you also run an extra rinse cycle to make sure you have all the bleach out of the machine before putting clothes in.
Posted on Aug 04, 2008
  • 370 Answers
SOURCE: changing a belt on roper top load washer
There is no belt on a roper. It called a drive coupler. its direct drive. Go to sears online and go to the parts section and put in your model number. Look at the diagrams and it will show you where it is located (easier to show you than to tell you.)
Posted on Nov 19, 2008
  • 19396 Answers
SOURCE: I have a top load Roper washer that won't spin.Any ideas?
That sounds like a bad drum bearing, check and eventually replace the drum bearing.
Posted on Apr 27, 2009
  • 1136 Answers
SOURCE: How do I take off the back and top of a top loading Roper washer?
Hi, The whole cabinet has to come off. Here is how to do this:
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
I hope this helps you. Please let me know if I can assist you further.
Posted on Jul 01, 2009
  • 5911 Answers
SOURCE: roper top loading washer RTW444OVQ leaking when
You will need to remove the washer exterior cabinet in order to sufficiently locate the source of your leak. The following steps explain how:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
The pump and drain hoses connections are located in the FRONT of the washer directly under the wash tub.
The water inlet and dispenser hoses are located along the back.
To get the cabinet back on the washer, follow these steps:
1, With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
Some other things to consider:
1. Check your fill hoses to ensure they are tight and not leaking. What can often appear as a washer problem, may be a loose hose.
2. With the washer case removed, check the are UNDER the wash tub. If the leak is coming from the center above the transmission, the tub seal may be leaking.
3. Inspect the wash tub for any cracks. If the tub is cracked and its not serious, you may be able to get by with some marine epoxy to reseal it. If the crack is significant, a new tub will be required.
4. Check the air dome on the lower right hand side of the wash tub. This is a small plastic air hose that runs from the wash tub all the way to the pressure switch. If this hose comes loose, the washer will start to leak as it fills. Simply reattach if it comes loose.
NOTE: It is important to remove the washer case in matters like this so that you can get a full view of everything to determine the source of the leak. Read through everything thoroughly before beginning any repairs. I hope this information is helpful.
Posted on Aug 21, 2009
Changing a belt on a washing machine
There is no belt on this machine.
It uses a direct drive coupling between the motor and transmission.
Ope the control console,then remove the cabinet clips to remove the cabinet for access to the motor.
Remove the motor then remove the broken drive coupling(3 parts).
Replace the part and re-assemble the washer.
Jul 25, 2010 | Roper RTW4100SQ Top Load Washer
The washer tub on my Roper washer does not spin during rinse cycle. The motor coupling seems to be OK.
Nov 03, 2009 | Roper RAS8445KQ Top Load Washer
Machine will not agitate
Washer has a motor coupling between gearcase and motor. This coupling is probably broken.
May 18, 2009 | Roper RAX4232KQ Top Load Washer
Roper top load washing machine problem. Please see details...
probibly a coupled drive. motor coupling runs everything, pump,aggitator, spin. if none of these thrree, coupling is two plastic parts with rubber between directly on the shaft of the motor , see if there are two screws at the bottom of front of case., if so remove aathen look for clips at top rrear this should be an easy fix
Mar 27, 2009 | Roper RTW4100SQ Top Load Washer
Roper washer stopped spinning
Your direct drive coupling on the motor is broken and must be replaced.
This video shows the procedure.
Mar 26, 2009 | Roper RAS8244KQ Top Load Washer
Roper Washer doesn't spin
If it is direct drive (no belt) it may be the motor coupling,
Jan 24, 2009 | Roper RAS8445KQ Top Load Washer
Roper washer will not agitate
could be the transmission or the drive motor to transmission coupling. You say the agitator doesn't work but it washes fine please clarify your problem.
Jan 12, 2009 | Roper RAS8445KQ Top Load Washer
Roper washer will not spin or agitate
Your coupling between the gearcase and the motor has broken. Go to a appliance parts store and ask for a whirlpool washer coupling. Remove the cabinet by taking the 2 screws out just behind the control panel.
remove the whole cabinet.Everything clips together. Pump first, motor, and then coupling. BobH
Dec 04, 2008 | Roper RAS8445KQ Top Load Washer
sounds like you have a bad motor coupling(part number 285753a, this machine equivelint to a tube has a few videos to aid you in this repair, search:: motor coupling whirlpool washer
Nov 23, 2008 | Roper RAS8445KQ Top Load Washer
If that is a coupling--2 white plastic pieces holding a rubber coupling? Rubber with three holes? If so, you need to remove 2 holding clamps to the water pump above the motor, separate it, remove two screws and 2 larger holding clamps of the motor, pull motor out and replace coupling...alingn motor and coupling onto gear, clamp it and return pump into its place.
I am new here, tried to post a photo of what I think you have but cannot just yet. Still trying.
Nov 28, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
