Question about Dryers
Beko sensor condenser drier.no heat .element .sensors. Ok cleaned
  • 1314 Answers
SOURCE: Need a diagram to change heating element and sensors
unplug the drier pull it out from the wall about a foot facing the drier take a small putty knife and insert it about 3" from the edge push the knife in till you feel the spring clip push in on it and lift the top then repeat that on the other side fold the top back till it leans against the wall look in the drier on the front edge of the front door panel there are two 5\16 in screws there remove them and un plug the light switch and the door switch assembly .grasp the front door panel and give it a quick snap forward to disengage the retaining clips and the door from the drum remove the door .Lay on the floor reach in and remove the belt from the idler pulley and blower motor pulley .Then while standing at the side of the drier grasp the belt with one hand and the front of the drier drum with the other and **** up sharply on the belt to release the drier drum from the rear drum bearing then remove the drum out the front on the rear you will see the heating element there will be one sensor on the heater pan that's the safety or high limit thermostat the tiny one on the drier body is the thermal overload the one on the vent at the bottom is the operating thermostat but its rare to have a problem with them if the drier is not heating the first thing i recommend is check your voltage and connections and don't assume just because its running its getting full voltage check it with a meter driers will run on 110 but will not heat without 220
Posted on Mar 10, 2008
  • 7 Answers
SOURCE: Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Posted on Oct 25, 2008
TheMobilian
  • 8220 Answers
SOURCE: the wires on my heating
the 2 wires that go to the element are largest. Does not matter which one goes where. The other 2 wires are smaller and imposible to get on the wrong terminal.
Posted on Dec 31, 2008
  • 2920 Answers
SOURCE: My tumble dryer is spinning but no heat.
it sounds like either your heating element went out or your limit switches are bad
Posted on Jan 14, 2009
SOURCE: Zanussi condenser drier: tank full light on even though empty
its either going to be fluff in the float which you can get at by taken the side panel off .or its fluff in the valve behind the water tank
Posted on Jan 31, 2009
Beko DRCT 70w condenser dryer not heating inside drum element is new and works any ideas ?
check the 2 thermostats with the element.........if ok.....
check the condenser unit.......they fill with fluff and stop condensing.......i use a hose pipe to shift all the fluff.....
cheers
Nov 23, 2016 | Dryers
How do I fix a Tumble drier which does not heat up please?
you will have to replace the heating element
Sep 27, 2015 | Dryers
Whirlpool AWZ 7686 Tumble Dryer heater works for only 10seconds
Might want to check for an obstruction in the outlet of the exhaust
Well if you had mention that in the first place I wouldn't be asking you. No wonder your trying to fix the problem by yourself because with that attitude you can't get a technician to come out for service.
Sep 12, 2015 | Whirlpool Dryers
What does the Code C3 mean on my Asko Dryer
Here is the list for the DRYER not sure what model... guys please post MODELS!!!!!!!!!!!!!!!!!!!!!
Asko
Dryer
Failure Code Condition Check/Repair
F1 Condensate drain overfilling.
1. Check condensate reservoir pump and drain tube.
F2 Maximum drying time exceeded (3hrs) 1. Check for tripped circuit breaker or blown fuse
2. Check ductwork for lint build-up
3. Check hi-limit and cycling thermostat
4. Check heating element
F3 Thermistor fault 1. Open thermistor, replace
2. Bad wiring to thermistor
F4 Too much lint in the lint filter, front housing, or in the condenser.1. Clean lint from lint filter and/or condenser
F5 Fault in the moisture sensor ยท Lint covering sensor in front of housing1. Bad sensor
2. Bad wiring to sensor
Sep 26, 2014 | Asko Dryers
Kenmore 500 dryer
If you mean that it is not heating and stays cool, most likely the pilot sensing thermocouple needs replacing (if you have a gas drier with a pilot light) or the electronic ignition contacts need replacing (if you have a gas drier with electronic ignition). Not sure about an electric drier, but probably the heating element needs replacing, or the thermocouple sensor (most likely). None of these are very expensive.
Jul 23, 2014 | Kenmore Dryers
Clothes warms up but will not dry
I suggest you check the exhaust system to make sure it is clear. Secondly, is yours a drier that has a sensor that determines when to shut off? If so, clean your sensors according to the manufacturers direction.
Thank you for your question @ FixYa.com
Mar 02, 2011 | Asko T721 Electric Dryer
Amana electric dryer will heat but only when.../ LEA60AW
It seems there is some wire loose, check on the both side of heating element points.
The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter.
Good Luck!!
Thanks
Jun 22, 2009 | Amana Dryers
Mar 10, 2008 | Frigidaire GLER341A Electric Dryer
Dryers Logo
Top Dryers Experts
