Question about Roper Washing Machines
How to change a motor coupling on a roper washer model number rtw4640yq0
    Sergeant:
  • 239 Answers
No motor coupling on that model.
Posted on May 08, 2017
  • 130 Answers
SOURCE: Roper Washer doesn't spin
If it is direct drive (no belt) it may be the motor coupling,
Posted on Jan 24, 2009
jsrock516
  • 5911 Answers
SOURCE: Roper RAX7245KQ Washer agitator does not rotate
If you are talking about the upper portion of the agitator (called the "auger") not spinning, you probably need to replace the agitator dogs. The following link epxlains how:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
This is a very simple and inexpenisve repair. The part number is included in the information I provided.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. I hope this information is helpful to you.
Posted on Jul 02, 2009
milten1
  • 1304 Answers
SOURCE: how can I replace a coupling on a Roper top
if your that far you should see two clips holding the motor in place one on top one on bottom
once you pop those off the motor willl fall away so top speak
the coupling is right there
the clips might be held on by a 1/4 inch srew
Posted on Oct 07, 2009
jumptrout51
  • 3361 Answers
SOURCE: I have a Roper Washer Model RTW4340SQD that
The lid switch is on the top left side of the top cover. If it is bad the machine will fill and stop. The lid switch must be good for the machine to agitate and spin.
Posted on Nov 01, 2009
  • 112 Answers
SOURCE: The washer tub on my Roper washer does not spin
SOUNDS LIKE A LID SWITCH OR A BAD MOTOR OR TRANNY. I WOULD CHECK THE LID SWITCH FIRST
Posted on Nov 03, 2009
How to change motor coupling on a roper top load washer
two screws to flip up top control panel. 2 clips to take off case. remove pump. then remove motor and change coupling. reassemble.
Dec 21, 2016 | Roper Washing Machines
Washer not draining
sounds like you need to replace the pump
Aug 30, 2017 | Whirlpool Washing Machines
Changing a belt on a washing machine
There is no belt on this machine.
It uses a direct drive coupling between the motor and transmission.
Ope the control console,then remove the cabinet clips to remove the cabinet for access to the motor.
Remove the motor then remove the broken drive coupling(3 parts).
Replace the part and re-assemble the washer.
Jul 25, 2010 | Roper RTW4100SQ Top Load Washer
Where are the belts located in a roper washing machine?
If the model number you posted this question under is correct, this model Roper does not have a drive belt. The washer uses a motor coupling in place of a drive belt and is known as a direct-drive system. The following link shows the drive system of your washer:
http://pcappliancerepair.com/model-display.php
The motor coupling is listed as item 13.
Symptoms of a broken motor coupling include failure to agitate or spin accompanied by the sound of the motor running with no tub action. Just to be sure...the following link explains the symptoms of a failed motor coupling and how to diagnose the problem:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
If you determine the coupler to be defective, the next link explains how to access the coupler and replace it:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number is included with the instructions I provided. Replacement parts (if required) can be purchased at any of the following websites:
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers I provided and go to your nearest appliance parts retailer. The coupler is usually sold as part of their in-store inventory. The average cost of a motor coupling is about $15.
If you have any questions, or if the symptoms I describe do not match the problem you are having, please post back with your complete MODEL NUMBER (if different from the one listed) and let me know. I hope this helps you.
Apr 28, 2010 | Roper RAB5232E
I have a roper washer and the tub will not spin just makes funny noise what could be
tip the washer back and look between the motor and trans there is a coupler that makes it spin it might be cracked-mike
Feb 21, 2010 | Roper RAS8445KQ Top Load Washer
My Roper washer Model# RAX4232JQ0 won't agitate or spin. Is it shaft driven or with a belt. I've tried everything. Even checked the switch for the lid.
The washer uses a direct drive system. What this means is that it uses a motor coupling in place of the drive belt. It sounds like to me that you have a broken motor coupling.
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
If you have questions, or require additional assistance, please let me know. I hope this has been helpful to you. NOTE: Roper is manufactured by Whirpool, so the instructions I provided will apply to your washer.
Jul 10, 2009 | Roper RAS6233KQ Top Load Washer
Jan 24, 2009 | Roper RAS8445KQ Top Load Washer
Washer won't do anything but fill
this could mean 2 things 1. check you lid switch first if it is broke your washer will fill up but the motor and pump will not function
2. your motor and pump coupling will need to be replaced BOTH THESE ITEMS ARE VERY INEXSPENSIVE USUALLY UNDER 15.00)and can be easily purchased online or at your local sears. be sure to take your model number with you. Glad to be of service
Jan 08, 2009 | Roper RAS8445KQ Top Load Washer
ROPER 5 CYCLE HEAVY DUTY. PART NUMBER 3952435
sounds like you have a bad motor coupling(part number 285753a, this machine equivelint to a belt.you tube has a few videos to aid you in this repair, search:: motor coupling whirlpool washer
Nov 23, 2008 | Roper RAS8445KQ Top Load Washer
Roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
