Question about Kyocera Office Equipment & Supplies
KYOCERA 2500 LIGHT COPY
I CLEAR THE DEVELOPING UNIT & DRUM UNIT,,,, WHAT I DO
SOURCE: problem with developing unit for canon ir1018
canon ir1018 showing error 354 code what is the cause
Posted on Jan 06, 2009
babaprithi
  • 372 Answers
SOURCE: canon ir 1020 print image doubled everyytime i
something is wrong with the fixing.it might be teflon /element or the pressure springs
Posted on Jul 01, 2011
  • 118 Answers
SOURCE: very light copy in 2nd side copy
its a moisture issue in the paper. try nice new dry paper and i bet it works fine
Posted on Mar 19, 2012
  • 1294 Answers
SOURCE: dirty and light copy of my Kyucera KM 1505 copier machine
Clean the optical parts (lens,mirrors),and the poligon motor mirrors.
Posted on Apr 10, 2013
SOURCE: How To Replace Kyocera Taskalfa 180 Copier Drum
Hopefully this will help.
Source:
http://www.manualowl.com/m/Kyocera/TASKalfa-180/Manual/345566
Posted on Dec 30, 2013
Testimonial: "operation guide will not show the way of replacing drum..."
No copies or clean paper with no signs of copy on my kyocera km 1635 copier can you help me with these ? tnx a lot
try to make a copy from your PC,if it was working fine that means you have a problem with your scanner unit.
Mar 08, 2016 | Kyocera Office Equipment & Supplies
CALL SERVICE 7402
Error code 7402
Developing unit C noninstalling error
No density detection signal is output from toner sensor C in developing unit C.
Reinsert the connector. Also check for continuity within the connector cable. If none,
replace the cable.
Developing unit C and Drum relay PWB
(YC10)
Drum relay PWB (YC1) and engine PWB
(YC34)
Long story short, the printer MUST go in for a service as you will void ANY warranty if you try this yourself, it is an electronic failure.
Feb 09, 2013 | Kyocera FS Office Equipment & Supplies
FS1128 whats the setup for dev on this?... is it like the CS2550 ? U130
1-5-5 Developing section
(1) Detaching and refitting the developing unit
Procedure
1. Open the front cover.
2. Remove the developing unit.
3. Check or replace the developing unit and
refit all the removed parts.
NOTE:
When the periodic maintenance (replacing
the maintenance kit, see page 2-4-4), perform following maintenance modes.
1. U251 Clearing the maintenance count (see
page 1-3-39)
2. U111 Clearing the drum drive time (see
page 1-3-33)
3. U130 Initial setting for the developing unit
(see page 1-3-34)
Jan 28, 2013 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
Ir 6570 copy light
When you were replacing the drum did you tuch the drum surface?Best would be that you take some toner on piece of cloth, and polish the drum, while turning it in good direction, that the cleaning blade can clean it.After you must let it copy about 50 copies.
You can try to replace the whole drum unit cexv14, or clean the laser unit.
Also could it be that the toner unit, or toner cleaning blade are not properly distibutes the toner accross the developing/toner cylinder
May 07, 2012 | Canon Office Equipment & Supplies
Instructions required to replace the maintence kit for a Kyocera FS4020DN
You must unplug your printer before doing any work and be very carefule not to damage any of your parts.
(1) Precautions
Be sure to turn the power switch off and disconnect the power plug before starting disassembly.
When handling PWBs, do not touch connectors with bare hands or damage the PWB.
Do not touch any PWB containing ICs with bare hands or any object prone to static charge.
Use only the specified parts to replace the thermal cutout. Never substitute electric wires, as the printer may be seriously
damaged.
When removing the hook of the connector, be sure to release the hook.
Take care not to get the wire caught.
(2) Drum
Note the following when handling or storing the drum.
When removing the drum unit, never expose the drum surface to strong direct light.
Keep the drum at an ambient temperature between 0 °C/32 °F and 40 °C/104 °F and at a relative humidity not higher than
90% RH. Avoid abrupt changes in temperature and humidity.
Avoid exposure to any substance which is harmful to or may affect the quality of the drum.
Do not touch the drum surface with any object. Should it be touched by hands or stained with oil, clean it.
(3) Toner container
Store the toner container in a cool, dark place.
Avoid direct light and high humidity.
Procedure
1. Open the top cover.
2. Open the MP tray.
3. Remove the developing unit.
4. Check or replace the developing unit and refit all the removed parts.
(2) Detaching and refitting the drum unit
Procedure
1. Remove the developing unit.
2. Open the left side cover and then remove the waste toner box.
3. Unlock the drum unit lock and then remove the drum unit.
4. Check or replace the drum unit and refit all the removed parts.
(3) Detaching and refitting the fuser unit
Procedure
1. Draw the rear unit.
2. Insert a flat-blade screwdriver to push the fuser lock (gray colored) on the rear unit and the fuser unit is separated from the rear unit (rails).
Do it both ends of the rear unit.
3. Check or replace the fuser unit and refit all the removed parts.
Place the fuser unit on the rear unit (rails) and push the fuser lock so that the fuser lock catches the fuser unit.
Do it for the both ends of the fuser unit.
(4) Detaching and refitting the transfer roller and separation charger brush unit Procedure
2. Remove the drum unit.
3. Slide the paper chute guide and unhook the hooks.
4. Remove the paper chute guide.
5. Remove the shaft (transfer roller) from the both bushes.
6. Release four latches and then remove thecseparation charger brush unit.
7. Check or replace the transfer roller and separationccharger brush unit and refit all the removed parts.
CAUTION: Note the following, when refitting the separation charger brush unit.
A. The separation charger brush unit is inserted into the two projections of the frame and does not run on to the projections.
B. The separation charger brush unit is firmly in contact with the separation charger plate of the frame.
The last things to replace would be your rollers which just pop in and out.
Jan 19, 2011 | Kyocera FS4020DN (A4) Workgroup Mono Laser...
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
I replaced the drum in Copystar 1820. What code
1-4-1 Maintenance mode
1) Executing a maintenance item
Press the System Menu/ Counter Key
Select Service Setting using the up/down cursor key
While pressing the start key and the # key press the enter key
Select maintenance mode using up or down cursor keys
Press enter key
Enter the maintenance item
number U-130 using the up/down keys.
The selected maintenance item is run.
Press the back key.
Press the enter key.
Start
End
Run another maintenance
item?
Turn power switch off and back on
U130 Initial setting for the developer
Description
Executes toner install operation.
Purpose
To operate when replacing the process unit.
Method
1. Press the enter key. A selection item appears.
2. Select On using the up/down cursor keys.
3. Press the enter key.
4. Turning the power switch off and back on.
ADDING TONER is displayed and installation of toner starts.
5. After approximately 15 minutes, the installation is completed and the machine becomes ready
.U157 Checking/clearing the developing drive time
Description
Displays the developing drive time for checking or changing a figure.
Purpose
To enter the developing drive time again after carrying out initialization with U020 and to clear the developing
drive time when replacing process unit.
Method
1. Press the enter key. The developing drive time is displayed in minutes.
2. Change the setting using the left/right cursor keys or numeric keys.
Setting range: 0 to 99999
To clear the developing drive time, set the value to 0.
3. Press the enter key. The value is set.
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
I hope this isn't too confusing for you, but this is what has to be done when replacing the Drum Unit (Process Unit Assembly)
Sep 14, 2009 | Kyocera Copystar CS-1820 Black and White...
Kyocera Mita 1635 Copier Printing Very Light Copies
Is one side lighter then the other side of the copy? Meaning uneven copy darkness? If so, I believe the problem is that one or both sides of the drum cartridge and the developer are not connected correctly. The two parts need to be close togather to make a nice dark copy. This model has a very wierd drum unit and has a defect that one or both side of the drum unit locking tabs break and you get very light or blank copies. It's some what coastly to replace the whole unit... That would be a worse case.... If it is just on one side you might be able to push on the cover on the side that is light. If the copies come out better. One side is broken..I would fold up some paper and make a wedge to push the catridges closer. Good Luck
Apr 15, 2009 | Kyocera KM-1505 Copier
Drum on model 1510 Kyocera copier
1-6-4 Image formation section
(1) Detaching and refitting the image formation unit
Follow the procedure below to replace or check the image formation unit.
Prucedure
1. Pull the drawer out and open the front cover, bypass tray and paper conveying unit.
2. Remove the waste toner tank and toner container.
3. Remove the two screws holding the waste toner tank cover and then the cover.
4. Remove the screw holding the developing retainer and then the retainer.
5. Remove the two screws and datach the connector and remove the image formation
unit.
Developing retainer
Image formation unit
Connector
Oct 28, 2008 | Kyocera KM-1510 Copier
Remove photoreceptor xerox 1505
1-6-4 Image formation section (1) Detaching and refitting the image formation unit Follow the procedure below to replace or check the image formation unit. Prucedure 1. Pull the drawer out and open the front cover, bypass tray and paper conveying unit. 2. Remove the waste toner tank and toner container. 3. Remove the two screws holding the waste toner tank cover and then the cover. 4. Remove the screw holding the developing retainer and then the retainer.
5. Remove the two screws and datach the connector and remove the image formation unit.
(3) Detaching and refitting the drum Follow the procedure below to replace the drum. Cautions: • Avoid direct sunlight or strong light when detaching and fitting the drum. • When removing the drum, spread paper underneath as there is a possibility of toner spill. Toner spill can be reduced by inserting an approximately 20-mm thick pad under the image formation unit toward the developing section and removing the drum with the unit slightly tilted. • Hold the drum at the ends and never touch the drum surface. • After removing the drum, keep it in the drum case or storage bag to protect the surface from light. Prucedure 1. Remove the image formation unit (see page 1-6-27). 2. Remove the main charger unit (see page 1-6- 28). 3. Remove the four screw and blade spring, and then open the cleaning unit. • Slide the cleaning blade back and forth and insert an approximately 4 to 4.5-mm thick spacer between the retainer at the rear of the cleaning unit and the housing.
4. Remove the screw holding the drum grounding plate and then the plate. 5. Remove the E ring from the drum shaft.
6. Remove the screw holding the upper developing seal and then the seal. Figure 7. Pull the drum shaft out and remove the drum. • Detach the drum horizontally. 8. Replace the drum and refit all the removed parts. • When replacing the drum, insert a sheet of paper between the drum and developing roller to prevent damage to the drum. • Check the letter indicating the drum type printed on the new drum flange. • Securely insert the drum shaft as far as it will go. When turning the drum shaft, turn it in the direction indicated by the arrow marked on the image formation unit frame. • Rotate the drum in its rotational direction and check that the cleaning blade does not flip up. 9. After replacing the drum, run maintenance items below. • U109 “Setting the drum type “ (set to the drum type printed on the new drum flange) • U110 “Checking/clearing the drum count”(clear the drum count) • U111 “Checking/clearing the drum drive time” (clear the value)
Oct 27, 2008 | Kyocera KM-1505 Copier
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
