Question about Roper Washing Machines
My roper washer model number rtw4640yq0 I put a new lid switch on it fill with water agitate For a second and stop.What to do after putting on a new lid switch
mohammed387
  • 1952 Answers
SOURCE: washer will not drain water or go into rinse and spin cycle
First thin I would try is to check your thermal fuse for continuity. Its located on the tunnel that incases the heasting element.
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
You also want to check the drain hose, the end of the hose is tapperd and tends to collect lint. Run a coat hanger up the hose and see if you can fish something out also check that belt.
Posted on Oct 06, 2008
  • 126 Answers
SOURCE: Top Load Roper Washer does not agitate during wash/rinse cycle
You may need to replace agitator dogs located inside the agitator or the drive coupler located above the motor. It dependis on which model you have.
Posted on Jan 02, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: washer fills with water then stops, won't agitate or spin
There are two possible causes. The most likely cause is the lid switch, which is supposed to keep you from sticking your hand into the moving basket. On many washers this only keeps the machine from spinning, but on other models it prevents agitating as well. The other possibility is the water level switch, but that usually causes no filling or overfilling if it's bad.
Both parts are available from Sears (www.searspartsdirect.com) and many other online sources. (I normally use the Sears site to find a part number if I don't already know it, then search for that number on Google. It's a great way to find good prices on more costly parts.) There are also a number of sites with detailed information about how to remove the cabinet to get at the parts if you want to try doing it yourself. Replacing these parts is pretty simple if you're comfortable with a screwdriver and have some mechanical ability.
If you'd rather have someone else repair the machine, this would normally be about a 1 hour plus parts charge for an appliance technician. It isn't time for a new washer yet.
Posted on Apr 25, 2009
  • 351 Answers
SOURCE: Roper top load washer Fills, agitates but stops at rinse cycle.
you are welcome
Posted on May 01, 2009
jsrock516
  • 5911 Answers
SOURCE: Roper RAX7245KQ Washer agitator does not rotate
If you are talking about the upper portion of the agitator (called the "auger") not spinning, you probably need to replace the agitator dogs. The following link epxlains how:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
This is a very simple and inexpenisve repair. The part number is included in the information I provided.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. I hope this information is helpful to you.
Posted on Jul 02, 2009
Roper Top Loader it will Fill with water, Agitate & 1/2 way through the wash cycle it just stops. Any suggestions I am not home so I don't have the model # but it is fairly old
Possibly could be a bad lid switch. Older models will allow it to do the agitate part of the cycle, but when it gets to the spin part of the cycle, it thinks the lid is still up and will not go any further. You might be able to repair it, if all it is doing is splitting in half at the seam by putting a zip tie around it and then put it back in place. Otherwise, you will need to replace it.
Oct 02, 2015 | Roper Washing Machines
RAX7244JQ0 Roper washer fills, starts to agitate but then it stops on the spin cycle and will not drain. not sure which part to replace--timer?
Hello, Thank You for using FixYa. I will be helping you today. The lid switch failed you need a new lid switch part number 3949247 this link has the part and a video how to change it http://www.repairclinic.com/PartDetail/Lid-Switch-Assembly/3949247/547225
Thank You and please rate my answer if it was helpful..
Jun 23, 2011 | Roper Washing Machines
Not spinning or rinsing?
After the machine fills the next step is to agitate. By agitate I mean the wash portion. The plastic fin in the middle of the tub rotates back and forth. So, after the washer fills, if the machine does not agitate, but stops dead, you have a broken lid switch. When I say stops dead, I mean no noise whatsoever. If the machine makes noise you have other problems.
If the machine fills, agitates, and then stops dead, the problem is still the lid switch. The next step would be describing the noise so I can more accurately give a suggestion. Problems include but are not limited to: broken couplers, malfunctioning water pumps, and/or defective motors or transmissions. These are the vast majority of the problems, and the others need no mention.
With a model number I can give a part number of the lid switch, and or other problematic parts. Also, I can give you an average price of the parts. With this information you could order it yourself and save money :) The model numbers are located under the lid of the washer. Not physically on the lid, but right under it. Get eye level with the top of the washer and you will see it ;)
May 28, 2010 | Roper RAX4233PQ Top Load Washer
I have a top loader whirlpool ultimate care 2 it keeps stopping once filled with water it stops have had timer replaced
May 27, 2010 | Whirlpool Washing Machines
I have a Roper Washer Model RTW4340SQD that
The lid switch is on the top left side of the top cover. If it is bad the machine will fill and stop. The lid switch must be good for the machine to agitate and spin.
Nov 01, 2009 | Roper RTW4300SQ Top Load Washer
The washing machine will fill and agitate but then stops...will not continue and water will not drain. When putting it on spin, rinse, anything, it just agitates then stops.
I think u need to open lid when in this condition put pencil in longgated hole if machine starts u need lid switch or acturater haundi24
Sep 29, 2009 | Roper RAS6233KQ Top Load Washer
Jul 02, 2009 | Washing Machines
ROPER MODEL RAX7245JQ0 WILL FILL AGITATO, DRAIN
Most of these spin related problems are attributed to a lid switch malfunction. A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
Let me know if you have any questions. I hope this helps you.
Jun 29, 2009 | Roper RAS8445KQ Top Load Washer
WASHER FILLS AND AGITATES, BUT THEN STOPS, WILL NOT DRAIN OR SPIN
It may be a bad lid switch. Cheak with your meter for continuity.And if you need more info let me know.Also how old is the washer for there are 2 differant styles of lid switch dipending on how old the washer is. hope i helped :)
May 18, 2009 | Roper RAX4233PQ Top Load Washer
Basin fills, does not agitate or drain
Check the lid switch. If you strip thwe wires and put on a wire nutit will go for ever For a switch call 7048196557
Mar 14, 2009 | Roper RAS8244KQ Top Load Washer
Washing Machines Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
