Question about Fagor Dishwashers
Fagor water heater fault code on display fae not firing up
5 Suggested Answers
john224
  • 1378 Answers
SOURCE: My hayward heater fires up and then turns off
Thank you for posting your question here on Fixya.com.
The basics are covered in this excerpt from your owner’s manual. If you need direction or additional information about these steps please post your specific questions.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 13, 2010
richroth
  • 9472 Answers
SOURCE: i require a
• Fault codes for quick diagnosis and solution of operating anomalies: F0: Bad connection in NTC temperature sensor. F1: Ignition fault. F2: Operating fault. F3: Flue Control Device blocked
Here is a manual for the Fagor water heater. If the model is different, please let me know. This manual will cover most of the Fagor line.
Richard Roth
The FixYa Team
Posted on Aug 16, 2011
SOURCE: My Heater displays a fault code "OC". when this is
This is error code indicates an overheating problem. Please check if there are enough air/water flow to cool the system while it is running. Check the valves if they are operating properly.
Here are other error code that might be useful:
BD1 Board failure EEP Microprocessor error FAN Blower pressure failure FFL Flame sensing when pilot and gas valves are closed GVC Gas valve closed GVO Gas valve open HL1 High limit switch #1 open HL2 High limit switch #2 open IGN Ignition failure ILO Ignition lockout - Propane units only PRS Water pressure switch open ROL Heat roll-out safety switch open SNS Sensor failure, Water temp. below 36°F or above 110°F VNT Vent switch open
Please let us know if you will require further help. Thanks for using Fixya.
Posted on Sep 10, 2011
  • 48555 Answers
SOURCE: I have Fagor Compact Plus Gas water Heater and fault codes keep appearing I tried to get a manual in English but all are in Spanish can anyone help please
trya search thru Google
Posted on Feb 18, 2017
Fagor dishwasher not completing cycle showing f6
The heater or thermostat is faulty and not allowing the dishwasher to complete cycle as water is not getting hot enough. Try to run a cold or short cycle and see if is completed.
see explanation of fault codes in this manual.
http://www.fagor.co.uk/documents/LFU-65iT.pdf
Sep 21, 2014 | Fagor Dishwashers
Fagor dishwasher showing f6
Please check fault codes on page 70 in this manual.
F6 would mean the water is not getting heated. I am not sure which model you have but if there is only a cold water inlet connection then either heater or thermostat is faulty. If you have both hot and cold water inlet then you may have to check if hot water is getting in at right temperature. Easiest way to confirm is to run dishwasher in cold cycle (short rinse) and see if it goes through. The heater would get used in warm/ hot wash cycles and drying.
Sep 19, 2014 | Fagor Dishwashers
Fagor compact plus
You could have a defective gas control valve or a bad thermocouple. Also check the venturi tubes again. sometimes cob webs collect in them and it may be difficult to see unless you remove them and check.
Good luck,
Marty
May 05, 2014 | Water Heaters
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
Wont always fire up
You probably have tankless water heater.
What brand water heater?
Gas or electric?
Is this new installation or old installation?
For Rheem tankless:
Copy following link: If you get no error code on remote control, then scroll down to 'no error code.'
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Oct 11, 2012 | Water Heaters
Hi, my new FAGOR 2LF-013S has no problem fortunately, but i have questions. is it possible i connect the water hose to hot water mains ;if ok; does it lead to power consumption reduction, or any other...
some fagors have a built in water heater (not all) your manual should say so , even so I allways connect my machines to hot supply as yes it's less expensive to use domestic heater for water , the heater inside (if equipped) machine just boosts the temp for cleaner dishes
Sep 11, 2011 | Fagor LFA-013 Stainless Steel Built-in...
Our tankless water heater is not turning on, but
blockage at pilot ,gas valve faulty ,if you have a changeover valve fault could be there
Oct 07, 2009 | Rinnai Webstone The isolator EXP tankless...
FAGOR DISHWASHER LFU073IT WITH F9 COMING UP ON DISPLAY
Problem with the distributor motor. It is a small white plastic part which receives water from the heater, and alternatively distributes water to upper or lower difussors. If the motor locks, or the internal sensor doesn't sense the position well, it will show F9. Motor can be repaired in most cases, and at last, it can be swaped
Nov 28, 2008 | Fagor LFA-073 IT Dishwasher
Dishwashers Logo
56 people viewed this question
Top Fagor Dishwashers Experts
dannydoesita
ray gallant
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
