Question about Konica Minolta bizhub Office Equipment & Supplies
Bizhub pro 920 tray 3 is not loading paper, no code appear, machine is working nicely on two other tray. plz help
  • Konica Minolta Master
  • 10,053 Answers
The pick up roller is either out of sync or has a lot of paper dust embedded i=on the surface of it. Try cleaning it with alcohol and a swab.
Posted on Dec 21, 2016
Testimonial: "it was broken gear problem, thanks"
My minolta bizhub c6501 has a trouble code of c0203. How do I fix it?
Intermittent C-0201 (C0201), C-0202 (C0202) and C-0203 (C0203)paper lift error codes.
1.The trail edge paper guide (p/n A03U R756 00) may not be pressed against the paper. This will allow the paper to fall backwards and induce the error code.
Instruct the end user to check the position of the trail edge paper guide whenever paper is loaded into the paper tray.
2. Coupling for the tray lift for Tray 1, Tray 2 or Tray 3 is obstructed or out of alignment causing the tray to not lift.
Inspect the coupler in the back of the machine for paper preventing the pin from seating in the coupler. Check alignment when tray is inserted. If out of
alignment try to adjust the drive to properly align.
Oct 04, 2017 | Minolta Office Equipment & Supplies
Hi, Bizhub c450: i have a problem on scanning over the rear tray if i put paper inside message will appears close section properly but there is no other error code appearing on the screen.
When you say the rear tray what do you mean, ON the document feeder tray or raising the document feeder up placing the document on the big glass. Never heard of a rear tray?????
Feb 04, 2015 | Konica Minolta bizhub C450P Laser Printer
Bizhub c220 tray 1 problem
pull out tray and check any paper is jammed is remaining at the back end of that tray
Nov 19, 2012 | Konica Minolta Bizhub C220 Color Copier
Got a bizhub c550 and error code c-0206 came up and it just wont reboot or do anything. Help
This code means that your paper tray 3 is not lifting the paper properly. Usually this is because the paper is not loaded properly. Open then close the front door to reset the code then immediately open tray 3. Check to insure that the paper is loaded properly. I would remove all the paper and then re-load. Leave tray 3 open long enough to verify that the machine will warm up and make copies. Then close tray 3 and see if the code comes back. If not then you are good to go. If it comes back then there is a tray lift problem with tray 3 and it will need service. Open tray 3 and reset the machine again. You can leave tray 3 slightly open to at least be able to use the machine until it gets repaired.
Good Luck and Thank You for using Fixya.
Sep 09, 2010 | Office Equipment & Supplies
Paper will not feed through after replacing color
Good day, I suggest you must clean the roller and and use appropriate type of papers. to clean the roller, press power button to turn on the machine then remove any paper from the auto sheet feeder. press menu until maintenance appear the press ok. and try to load load 3 or more a4 letter sized paper and see if the the paper is automatically fed in and then out of the machine.
hope this will help you. have a nice day.
Jul 31, 2010 | Canon PIXMA MP240 All-In-One InkJet...
How to clear c-0204
C0204 - Tray 2 Elevator failure - The Lift-Up Sensor is not blocked even after the lapse of a given period of time after the lifting motion has been started.
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
Nov 23, 2009 | Konica Minolta bizhub C250 All-In-One...
Malfunction Detected C-0206 on Konica Minolta C351
this error code means that tray 3 paper could not lift up to the feed rollers. open the tray and check the paper tray and checkthat the paper is loaded correctly pull all the paper out of the tray and check to see if any is folded or crumpled if the paper is ok it could be the lift motor has failed or the main boardPF or main boardMC or the dc power supply needs to be replaced.
to reset the code leave the machine on and open then close the front door
Nov 11, 2009 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta Bizhub 920
You need to set machine for extra cassette.
Nov 23, 2008 | Konica Minolta Di1610 Copier
Bizhub C450 error (C-0212)
C0212 is a LCT (large capacity tray) shift motor, or lock release failure (they both use the same code)
Open the lower paper tray, and look for anything unusual.
Sounds like the paper was loaded incorrectly, and the tray tried to lift.
Feb 04, 2008 | Konica Minolta bizhub C450P Laser Printer
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
