Question about Roper Washing Machines
How to do a automatic test mode on my roper top load washer model #4640yq0
  • 370 Answers
SOURCE: changing a belt on roper top load washer
There is no belt on a roper. It called a drive coupler. its direct drive. Go to sears online and go to the parts section and put in your model number. Look at the diagrams and it will show you where it is located (easier to show you than to tell you.)
Posted on Nov 19, 2008
  • 19396 Answers
SOURCE: I have a top load Roper washer that won't spin.Any ideas?
That sounds like a bad drum bearing, check and eventually replace the drum bearing.
Posted on Apr 27, 2009
  • 1136 Answers
SOURCE: How do I take off the back and top of a top loading Roper washer?
Hi, The whole cabinet has to come off. Here is how to do this:
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
I hope this helps you. Please let me know if I can assist you further.
Posted on Jul 01, 2009
  • 1564 Answers
SOURCE: Roper rtw4340sq0 top loader sicks in rinse mode.
The drive gear for the functioning unit sounds like it has gone south. Unless you are familiar with changing devices like this, I would call your local appliance guy!
Posted on Jul 24, 2009
dr appliance
  • 266 Answers
SOURCE: Roper top load washer spins but does not drain
replace coupler for direct drive whirlpool washer yes roper is a whirlpool washer #part number 285753 you can watch video on youtube to replace
Posted on Jan 24, 2011
Roper washer agitator won't spin after kids loaded
It sounds like a someone has broke the lid switch to the washer. Below I have attached a picture, Item number 9 would be the part you seek. P# 3949247 Under the control panel you will find a harness that contains 3 wires coming out of the cabinet housing. The colors should be tan, white and green. If you jump the white and tan you unit should run and think the lid switch is working. Safety way is to unplug the unit to by-pass the switch and plug it back in and select spin only. This is only to test, you need a lid switch for safety. You should replace it ASAP if this test works for you.
Jul 26, 2011 | Roper RAX4232KQ Top Load Washer
I have a Roper top load washer. when i start it, it automatically starts on agitiate. It skips the filling cycle. model# RTW4100SQ1
It sounds like you have a bad water level switch.The switch is the one you turn to set the water level.
Jun 24, 2011 | Roper RTW4100SQ Top Load Washer
Where do I add softener?
If your model doesn't have an automatic softener dispenser on top of the agitator, then you just add it directly to the rinse water
i.e. if the top cap on your agitator is flat, there's no optional automatic softener dispenser, if it looks like a cup, you have the dispenser, and that's where you would add your softener.
Hope this answers your question
Dec 31, 2010 | Roper RAX4233PQ Top Load Washer
how can I check the timer for my RAS6233RQO with a voltmeter?
Oct 13, 2010 | Roper RAS6233KQ Top Load Washer
I have a Roper Washer Model RTW4340SQD that
The lid switch is on the top left side of the top cover. If it is bad the machine will fill and stop. The lid switch must be good for the machine to agitate and spin.
Nov 01, 2009 | Roper RTW4300SQ Top Load Washer
Basin fills, does not agitate or drain
Check the lid switch. If you strip thwe wires and put on a wire nutit will go for ever For a switch call 7048196557
Mar 14, 2009 | Roper RAS8244KQ Top Load Washer
I have a roper washer that wont spin. Probably the coupler. I have changed couplers many times on other types of washers whirlpool amana and kenmore. etc. is the process the same with a roper ?
exact same as a whirlpool, for they own roper, amanas do not have couplers..... the kenmore might if the model starts with 110.********* or 118.*********
Jan 16, 2009 | Roper RAX4232KQ Top Load Washer
My roper washinging machine overflowed
Dear Customer
Please perform the following checks
  • Test the timer control
  • Test the water level switch
  • Inspect the air tube for damage
  • Test the water inlet valve
  • Please rate this,Thank u
    Nov 22, 2008 | Roper RAS8445KQ Top Load Washer
    Washing Machines Logo
    51 people viewed this question
    Top Roper Washing Machines Experts
    Dan Webster
    Dan Webster
    Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
