Question about Bernina Sewing Machines
I have a 1973 Bernina Record that I have been using quite regularly in recent months. It suddenly started running by itself. Is there a fix for this problem?
  • Bernina Master
  • 12,285 Answers
Generally, it is a problem with the foot control.
http://www.instructables.com/answers/How-do-you-fix-a-sewing-machine-that-wont-stop-ru
BTW, if the foot control has the number 213 on the bottom and there is not a "T" or "S" etched or label somewhere, these control units have a risk of catching fire. (The T or S indicates it has been repaired.) You can have the foot control repaired or pick up a replacement.
sewing machine running on its own Google Search
https://tv-sewingcenter.com/bernina/bernina-830-fire-hazard
Posted on Dec 21, 2016
I am looking for a bernina 930 service manual. I dropped the feed dogs and they will not come back up.
Most likely they have seized due to lack of regular oiling. I have used the following method on several older seized Berninas with great success. Just be sure to NOT get any oil near the 930 basting stitch mechanism (about the middle of the needle bar) or it will most likely lock the machine.
Wheel on right side that controls the needle up and down is very tight...
This is a diagram for the Bernina 830 Record, but it will give you a good idea of what & where to look for oil ports.
I've never used this source (use at your risk):
Bernina record 930 electronic service manual
Nov 25, 2016 | Bernina Sewing Machines
I have been away from sewing for a while but have recently begun again. I have a Bernina 1010. The fabric feeder has quit working. Any trouble shooting tips? I no longer have my manual.
Hm, I'm more familiar with the Berninas older than the 1010. The old mechanicals will seize if they haven't been regularly oiled. Could be the feed dogs on your machine have seized for the same reason.
I've resurrected several seized Berninas from a 930 on down to some 530s by opening the top, side, and bottom and applying a couple drops of oil where metal rubs on metal. After the 830 Record, Bernina stopped including any extensive oiling directions in the owner's manual, even though the 930 requires it frequently. (Some say Bernina really wanted the repeat maintenance business, but the 930 also presented some special issues with the basting stitch and the electronic board.) However, I am uncertain how much a user can oil a 1010 without causing damage. Most Bernina manuals provide information for oiling the race but don't go beyond that. Something that may be worth trying is directing hot air from a handheld hairdryer into the area that houses the feed dogs to see if that loosens anything.
Whatever you do, don't use WD-40, 3-in-1, cooking oil, or anything other than fresh good quality sewing machine oil.
You can find a manual for the 1011 here. It may be close enough to your model to be of some use:
BERNINA Sewing Systems
There are some Yahoo groups whose specialty is the Bernina owner/lover, ie BerninaThirtySomethings, and some others. They are a very helpful and knowledgeable group that could be of assistance to you.
Oct 30, 2016 | Bernina Sewing Machines
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
My machine Bernina 830 does not run
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
Why bernina electronic wheel won't turn and motor bogs down
You don't mention which model Bernina you have. If it is a Bernina mechanical, ie 930 Record, it sounds like it hasn't been cleaned or oiled in a while and the oil has hardened making it difficult for the motor to move the parts. Pick up some Bernina oil for "mechanical" machines, or for a quick fix a bottle of Tri-Flow Synthetic Oil at the hardware store. Following the diagram in your manual, put one or two drops of oil every place indicated (be sure to oil both the top of your machine and the area below the sewing surface). In your case, pay particular attention to the oil holes located nearest the handwheel. That is probably where the problem is worst. To help loosen things up, you can direct heat from a hand-held hair dryer into the interior of the machine. In the future, be sure to keep your machine cleaned and oiled on a regular basis. My policy is every time I change bobbins, after 8 hours of continuous sewing, or every six months if the machine has not been in use.
Mar 10, 2015 | Bernina Sewing Machines
How can I fix the needle assembly on my Bernina 930 Record...it all of the sudden doesn't move up and down?
There is a screw-in "hub", a round thingie, to tighten on the end of the machine, in the middle of the big spinning wheel. Hold the wheel and turn the hub clock-wise to tighten it ("Righty-Tighty, Lefty-Loosy).
It may be a bit tight to start with, they can "jam" open. Just turn it firmly as needed.
The reason the hub tightens and loosens is so you can run the machine quite fast when filling a bobbin up with thread without having all the gears and werkin's clatter as you do so.
Here is a VIDEO (better than just a photo, yes?) on how to operate your very model sewing machine! https://www.youtube.com/watch?v=drLD66Wa7U0
Aug 04, 2014 | Bernina Sewing Machines
Bernina Record 730 hand wheel stuck
OK OBRIGADO VOU LIMPAR A MAQUINA PODE SER POEIRA PORQUE FICOU ALGUNS MESES SEM FUNCIONAR.
aGRADECIA SE ELA FUNCIONASSE TENHO MUITOS TRABALHOS POR FAZER SOMENTE O ERROR C14A3 ESTA A BARRAR-ME E NAO ACEITA MAIS NADA A FUNCIONAR
Feb 06, 2014 | Bernina Sewing Machines
Bernina 1030 needle not moving up or down
I believe the 1030 has a basting stitch, similar to the 930 Record. If the basting stitch is not run regularly, it may lock up the machine requiring a technician's expertise to get it working again.
Mar 31, 2013 | Bernina 1008
Bernina 830 Record foot pedal won't engage sewing unless I turn the hand wheel.
your motor is going out. time to replace or rebuild your motor. both are high skill and should be attempted by a professional. take it to your nearest bernina shop.
Feb 07, 2013 | Bernina Sewing Machines
How do i use the zigzag stitch on my bernina 830
Hi, open the top cover and if you watch what goes on inside from the top when you move the top change lever you will see part of it goes through a fork or U-shape part. This part is probably stuck and needs some oil. After oiling and working it back and forth a bunch eventually it will start snapping into the notches its supposed to. I beleive then you will have your zigzag back.
Either that or you have the stitch width set on zero.
Feb 01, 2009 | Bernina Artista 180
Bernina 830 stopped running
Motor brushes are usually the problem
Jan 03, 2009 | Sewing Machines
Sewing Machines Logo
137 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
