Question about SWANN Home Security
I have Swann sr pro N3960 I/p12 4w cam by itself w/cut red,green,yellow,and no coloured wires hanging and an iPad,smart tv, and computer only to hook it up to as a monitor How can I hook up
SOURCE: Sanyo Pro Xtrax
You need to change th bulb. It's damaged
Posted on Nov 30, 2007
ginko
  • 19396 Answers
SOURCE: Microsoft SideWinder Precision Pro - wiring
Wiring color are not always the same they may change even within same model.
You need to buy a tester, like this Handheld Mini Digital Multimeter,
and find out functions for each cable.
A mistake at this point can result in damage to the computer power supply or the game card. The controller cable must have a 15-pin male connector on one end and bare wire ends on the other. A male plug is one with a hollow indentation filled with small pins. The outer jacket of the cable must be stripped sufficiently so that the wires can reach across the required span. A VOM or continuity checker is used to trace the wires out to the corresponding pin of the connector. The wires are color coded so one probe of the VOM is connected to a wire and the other is touched to a pin until continuity is achieved. The following list should be printed and the wire color noted in the appropriate column as it is found. The plug should have very small numbers imprinted adjacent to each pin. If it does not, the diagram below can be used to determine the pin number.
PIN ASSIGNMENT ON CONTROLLER CONNECTOR
(Only the pins shown in boldface italics are required in this project)
PIN # DESCRIPTION WIRE COLOR 1 +5 Volts>
2 Button 1
3 X-Axis, Stick 1
4 Ground
5 Ground
6 Y-Axis, Stick 1
7 Button 2
8 +5 Volts
9 +5 Volts
10 Button 3
11 X-Axis, Stick 2
12 Ground
13 Y-Axis, Stick 2
14 Button 4
15 +5 Volts
After the correct wires are determined, wiring can begin. The first thing that must be done is to isolate the unused ground (pin 5) and +5 volt wires (pins 8, 9 and 15). If the wires can be exposed at the male connector end, they can be cut off at the connector. Otherwise, any method possible must be used to isolate the ends of the wires to ensure that a ground and +5 volt wire can contact each other and short. Shorting ground to +5 volts can destroy the computer power supply. The wire end of the cable can be routed through the antenna hole or any other point the seems convenient. The +5 volt wire from pin one can be routed through the master switch to allow the power to be turned off to the controller while it is not in use. The use of the trainer switch as a select or fire button is optional. There are three wires on the trainer switch. The VOM is used to find the two wires that have continuity when the trainer switch is pressed and the other wire is removed. The ground (pin 4) is connected to one of the remaining wires of the trainer switch and the wire from pin 2 on the plug is connected to the other. These connections should be taped to avoid having them touch a +5 volt wire. The +5 volt line will be connected the pots so efforts must be taken to assure that no ground wire can make contact with a pot. Any wires that are not used must be removed or isolated.
Posted on May 15, 2008
SOURCE: replacing thermostat
YES THE BLUE WIRE DOES CONNECT TO THE C TERMANAL FOR COMMON
Posted on Sep 12, 2008
johnny5846
  • 379 Answers
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Posted on Jan 10, 2009
  • 1455 Answers
SOURCE: Hi, im searching for the stereo wiring chart for
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Posted on Apr 14, 2011
I have a swann n3960 how i connect its cut off 2 red 1 yellow 2 black
Red is for it and camara yellow is for picture and black is ground
Jan 08, 2017 | SWANN Home Security
I have a security cam from swann that wires have been cut two reds two blacks and a yellow what connect to what
Both red are for Power Positive and both black are Power Negative.
Yellow is for Video output and connect video ground to the Black Wires.
Oct 08, 2016 | SWANN Home Security
How do i wire my servalance cam swann wierlessY model no. SW231-WCH N3960 to my tv
you have to tune with the dial on the wireless box very slowly.
Dec 10, 2014 | RCA Televison & Video
Swann n3960
there should be a red audio and a yellow video cable / hook it the audio video jacks that are color coded on the back of the tv . the input will be labeled next to it . tune the input the tv to this input
May 25, 2014 | Televison & Video
Swann n3960
Hi ,
Is the colour of the other plug white ? Then red and white are for the audio ( red is right channel and white is left channel ) . The yellow plug is for video .
Regards .
Nov 20, 2013 | Office Equipment & Supplies
My swann n3960 dvr is not displaying any images,how do I fix it ?
I have opened my Swann SW 214-Scc N3960 but I don't know if a lost a lense. How many lenses does it hive inside
Oct 21, 2012 | Swann Communications Televison & Video
Home Security Logo
55 people viewed this question
Top SWANN Home Security Experts
gaucherre
Neil Frazier
Neil Frazier
Level 1 Expert
Are you a SWANN Home Security Expert? Answer questions, earn points and help others
