What is the error 4???? - Office Equipment & Supplies
  • 6,694 Answers
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Dec 21, 2016
Testimonial: "I didn't get it what should I do? This site didn't help The washer didn't get out the water from it"
Beep codes
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem. If any other correctable hardware issues is found the BIOS displays a message. No Power, Loose Card, or Short.1 Short BeepNormal POST, computer is ok.2 Short BeepPOST error, review screen for error code.Continuous BeepNo Power, Loose Card, or Short.Repeating Short BeepNo Power, Loose Card, or Short.One Long and one Short BeepMotherboard issue.One Long and Two Short BeepsVideo (Mono/CGA Display Circuitry) issue.One Long and Three Short Beeps.Video (EGA) Display Circuitry.Three Long BeepsKeyboard or Keyboard card error.One Beep, Blank or Incorrect DisplayVideo Display Circuitry. Phoenix BIOS Q3.07 OR 4.X Beep Code Description and what to check 1-1-1-3 Verify Real Mode. 1-1-2-1 Get CPU Type. 1-1-2-3 Initialize system hardware. 1-1-3-1 Initialize chipset registers with initial POST values. 1-1-3-2 Set in POST flag. 1-1-3-3 Initialize CPU registers. 1-1-4-1 Initialize cache to initial POST values. 1-1-4-3 Initialize I/O. 1-2-1-1 Initialize Power Management. 1-2-1-2 Load alternate registers with initial POST values. 1-2-1-3 Jump to UserPatch0. 1-2-2-1 Initialize keyboard controller. 1-2-2-3 BIOS ROM checksum. 1-2-3-1 8254 timer initialization. 1-2-3-3 8237 DMA controller initialization. 1-2-4-1 Reset Programmable Interrupt Controller. 1-3-1-1 Test DRAM refresh. 1-3-1-3 Test 8742 Keyboard Controller. 1-3-2-1 Set ES segment to register to 4 GB. 1-3-3-1 28 Autosize DRAM. 1-3-3-3 Clear 512K base RAM. 1-3-4-1 Test 512 base address lines. 1-3-4-3 Test 512K base memory. 1-4-1-3 Test CPU bus-clock frequency. 1-4-2-4 Reinitialize the chipset. 1-4-3-1 Shadow system BIOS ROM. 1-4-3-2 Reinitialize the cache. 1-4-3-3 Autosize cache. 1-4-4-1 Configure advanced chipset registers. 1-4-4-2 Load alternate registers with CMOS values. 2-1-1-1 Set Initial CPU speed. 2-1-1-3 Initialize interrupt vectors. 2-1-2-1 Initialize BIOS interrupts. 2-1-2-3 Check ROM copyright notice. 2-1-2-4 Initialize manager for PCI Options ROMs. 2-1-3-1 Check video configuration against CMOS. 2-1-3-2 Initialize PCI bus and devices. 2-1-3-3 Initialize all video adapters in system. 2-1-4-1 Shadow video BIOS ROM. 2-1-4-3 Display copyright notice. 2-2-1-1 Display CPU Type and speed. 2-2-1-3 Test keyboard. 2-2-2-1 Set key click if enabled. 2-2-2-3 56 Enable keyboard. 2-2-3-1 Test for unexpected interrupts. 2-2-3-3 Display prompt Press F2 to enter SETUP. 2-2-4-1 Test RAM between 512 and 640k. 2-3-1-1 Test expanded memory. 2-3-1-3 Test extended memory address lines. 2-3-2-1 Jump to UserPatch1. 2-3-2-3 Configure advanced cache registers. 2-3-3-1 Enable external and CPU caches. 2-3-3-3 Display external cache size. 2-3-4-1 Display shadow message. 2-3-4-3 Display non-disposable segments. 2-4-1-1 Display error messages. 2-4-1-3 Check for configuration errors. 2-4-2-1 Test real-time clock. 2-4-2-3 Check for keyboard errors 2-4-4-1 Set up hardware interrupts vectors. 2-4-4-3 Test coprocessor if present. 3-1-1-1 Disable onboard I/O ports. 3-1-1-3 Detect and install external RS232 ports. 3-1-2-1 Detect and install external parallel ports. 3-1-2-3 Re-initialize onboard I/O ports. 3-1-3-1 Initialize BIOS Data Area. 3-1-3-3 Initialize Extended BIOS Data Area. 3-1-4-1 Initialize floppy controller. 3-2-1-1 Initialize hard disk controller. 3-2-1-2 Initialize local bus hard disk controller. 3-2-1-3 Jump to UserPatch2. 3-2-2-1 Disable A20 address line. 3-2-2-3 Clear huge ES segment register. 3-2-3-1 Search for option ROMs. 3-2-3-3 Shadow option ROMs. 3-2-4-1 Set up Power Management. 3-2-4-3 Enable hardware interrupts. 3-3-1-1 Set time of day. 3-3-1-3 Check key lock. 3-3-3-1 Erase F2 prompt. 3-3-3-3 Scan for F2 key stroke. 3-3-4-1 Enter SETUP. 3-3-4-3 Clear in POST flag. 3-4-1-1 Check for errors 3-4-1-3 POST done - prepare to boot operating system. 3-4-2-1 One beep. 3-4-2-3 Check password (optional). 3-4-3-1 Clear global descriptor table. 3-4-4-1 Clear parity checkers. 3-4-4-3 Clear screen (optional). 3-4-4-4 Check virus and backup reminders. 4-1-1-1 Try to boot with INT 19. 4-2-1-1 Interrupt handler error. 4-2-1-3 Unknown interrupt error. 4-2-2-1 Pending interrupt error. 4-2-2-3 Initialize option ROM error. 4-2-3-1 Shutdown error. 4-2-3-3 Extended Block Move. 4-2-4-1 Shutdown 10 error. 4-3-1-3 Initialize the chipset. 4-3-1-4 Initialize refresh counter. 4-3-2-1 Check for Forced Flash. 4-3-2-2 Check HW status of ROM. 4-3-2-3 BIOS ROM is OK. 4-3-2-4 Do a complete RAM test. 4-3-3-1 Do OEM initialization. 4-3-3-2 Initialize interrupt controller. 4-3-3-3 Read in bootstrap code. 4-3-3-4 Initialize all vectors. 4-3-4-1 Boot the Flash program. 4-3-4-2 Initialize the boot device. 4-3-4-3 Boot code was read OK.
http://www.computerhope.com/beep.htm
Jul 09, 2014 | EliteGroup GeForce6100PM-M2 Motherboard
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
Tip
System Beep Code Error
Beep Code Manual, Better Than Gold Techies, American Megatrends Int. & Phoenix
BIOS Beep Codes
When a computer is first turned on, or rebooted, its BIOS performs a power-on self test (POST) to test the system's hardware, checking to make sure that all of the system's hardware components are working properly. Under normal circumstances, the POST will display an error message; however, if the BIOS detects an error before it can access the video card, or if there is a problem with the video card, it will produce a series of beeps, and the pattern of the beeps indicates what kind of problem the BIOS has detected.
Because there are many brands of BIOS, there are no standard beep codes for every BIOS.
The two most-used brands are AMI (American Megatrends International) and Phoenix.
Below are listed the beep codes for AMI systems, and here are the beep codes for Phoenix systems.
AMI Beep Codes
Beep Code Meaning
1 beep DRAM refresh failure. There is a problem in the system memory or the motherboard.
2 beeps Memory parity error. The parity circuit is not working properly.
3 beeps Base 64K RAM failure. There is a problem with the first 64K of system memory.
4 beeps System timer not operational. There is problem with the timer(s) that control functions on the motherboard.
5 beeps Processor failure. The system CPU has failed.
6 beeps Gate A20/keyboard controller failure. The keyboard IC controller has failed, preventing gate A20 from switching the processor to protect mode.
7 beeps Virtual mode exception error.
8 beeps Video memory error. The BIOS cannot write to the frame buffer memory on the video card.
9 beeps ROM checksum error. The BIOS ROM chip on the motherboard is likely faulty.
10 beeps CMOS checksum error. Something on the motherboard is causing an error when trying to interact with the CMOS.
11 beeps Bad cache memory. An error in the level 2 cache memory.
1 long beep, 2 short Failure in the video system.
1 long beep, 3 short A failure has been detected in memory above 64K.
1 long beep, 8 short Display test failure.
Continuous beeping A problem with the memory or video.
BIOS Beep Codes
Phoenix Beep Codes
Phoenix uses sequences of beeps to indicate problems. The "-" between each number below indicates a pause between each beep sequence. For example, 1-2-3 indicates one beep, followed by a pause and two beeps, followed by a pause and three beeps. Phoenix version before 4.x use 3-beep codes, while Phoenix versions starting with 4.x use 4-beep codes. Click here for AMI BIOS beep codes.
4-Beep Codes
Beep Code Meaning
1-1-1-3 Faulty CPU/motherboard. Verify real mode.
1-1-2-1 Faulty CPU/motherboard.
1-1-2-3 Faulty motherboard or one of its components.
1-1-3-1 Faulty motherboard or one of its components. Initialize chipset registers with initial POST values.
1-1-3-2 Faulty motherboard or one of its components.
1-1-3-3 Faulty motherboard or one of its components. Initialize CPU registers.
1-1-3-2
1-1-3-3
1-1-3-4 Failure in the first 64K of memory.
1-1-4-1 Level 2 cache error.
1-1-4-3 I/O port error.
1-2-1-1 Power management error.
1-2-1-2
1-2-1-3 Faulty motherboard or one of its components.
1-2-2-1 Keyboard controller failure.
1-2-2-3 BIOS ROM error.
1-2-3-1 System timer error.
1-2-3-3 DMA error.
1-2-4-1 IRQ controller error.
1-3-1-1 DRAM refresh error.
1-3-1-3 A20 gate failure.
1-3-2-1 Faulty motherboard or one of its components.
1-3-3-1 Extended memory error.
1-3-3-3
1-3-4-1
1-3-4-3 Error in first 1MB of system memory.
1-4-1-3
1-4-2-4 CPU error.
1-4-3-1
2-1-4-1 BIOS ROM shadow error.
1-4-3-2
1-4-3-3 Level 2 cache error.
1-4-4-1
1-4-4-2
2-1-1-1 Faulty motherboard or one of its components.
2-1-1-3
2-1-2-1 IRQ failure.
2-1-2-3 BIOS ROM error.
2-1-2-4
2-1-3-2 I/O port failure.
2-1-3-1
2-1-3-3 Video system failure.
2-1-1-3
2-1-2-4 I/O port failure.
2-1-4-3
2-2-1-1 Video card failure.
2-2-1-3
2-2-2-1
2-2-2-3 Keyboard controller failure.
2-2-3-1 IRQ error.
2-2-4-1 Error in first 1MB of system memory.
2-3-1-1
2-3-3-3 Extended memory failure.
2-3-2-1 Faulty motherboard or one of its components.
2-3-2-3
2-3-3-1 Level 2 cache error.
2-3-4-1
2-3-4-3 Motherboard or video card failure.
2-3-4-1
2-3-4-3
2-4-1-1 Motherboard or video card failure.
2-4-1-3 Faulty motherboard or one of its components.
2-4-2-1 RTC error.
2-4-2-3 Keyboard controller error.
2-4-4-1 IRQ error.
3-1-1-1
3-1-1-3
3-1-2-1
3-1-2-3 I/O port error.
3-1-3-1
3-1-3-3 Faulty motherboard or one of its components.
3-1-4-1
3-2-1-1
3-2-1-2 Floppy drive or hard drive failure.
3-2-1-3 Faulty motherboard or one of its components.
3-2-2-1 Keyboard controller error.
3-2-2-3
3-2-3-1
3-2-4-1 Faulty motherboard or one of its components.
3-2-4-3 IRQ error.
3-3-1-1 RTC error.
3-3-1-3 Key lock error.
3-3-3-3 Faulty motherboard or one of its components.
3-3-3-3
3-3-4-1
3-3-4-3
3-4-1-1
3-4-1-3
3-4-2-1
3-4-2-3
3-4-3-1
3-4-4-1
3-4-4-4 Faulty motherboard or one of its components.
4-1-1-1 Floppy drive or hard drive failure.
4-2-1-1
4-2-1-3
4-2-2-1 IRQ failure.
4-2-2-3
4-2-3-1
4-2-3-3
4-2-4-1 Faulty motherboard or one of its components.
4-2-4-3 Keyboard controller error.
4-3-1-3
4-3-1-4
4-3-2-1
4-3-2-2
4-3-3-1
4-3-4-1
4-3-4-3 Faulty motherboard or one of its components.
4-3-3-2
4-3-3-4 IRQ failure.
4-3-3-3
4-3-4-2 Floppy drive or hard drive failure.
3-Beep Codes
Beep Code Meaning
1-1-2 Faulty CPU/motherboard.
1-1-3 Faulty motherboard/CMOS read-write failure.
1-1-4 Faulty BIOS/BIOS ROM checksum error.
1-2-1 System timer not operational. There is a problem with the timer(s) that control functions on the motherboard.
1-2-2
1-2-3 Faulty motherboard/DMA failure.
1-3-1 Memory refresh failure.
1-3-2
1-3-3
1-4-1 Address line failure.
1-4-2 Parity RAM failure.
1-4-3 Timer failure.
1-4-4 NMI port failure.
2-_-_ Any combination of beeps after 2 indicates a failure in the first 64K of memory.
3-1-1 Master DMA failure.
3-1-2 Slave DMA failure.
3-1-3
3-1-4 Interrupt controller failure.
3-2-4 Keyboard controller failure.
3-3-1
3-3-2 CMOS error.
3-3-4 Video card failure.
3-4-1 Video card failure.
4-2-1 Timer failure.
4-2-2 CMOS shutdown failure.
4-2-3 Gate A20 failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure.
4-3-3 Timer failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port failure.
4-4-2 Parallel port failure.
4-4-3 Math coprocessor.
on Feb 02, 2010 | Computers & Internet
Tip
Beep Code Manual
(I'm Computer Technician, I use these codes to trouble shoot hardware issues at my job. Enjoy.)
BIOS Beep Codes
When a computer is first turned on, or rebooted, it's BIOS performs a power-on self test (POST) to test the system's hardware, checking to make sure that all of the system's hardware components are working properly. Under normal circumstances, the POST will display an error message; however, if the BIOS detects an error before it can access the video card, it will produce a series of beeps, and the pattern of the beeps indicates what kind of problem the BIOS has detected. Because there are many brands of BIOS, there are no standard beep codes for every BIOS.
AMI Beep Codes
Beep Code Meaning
1. beep DRAM refresh failure. There is a problem in the system memory or the motherboard.
2. beeps Memory parity error. The parity circuit is not working properly.
3. beeps Base 64K RAM failure. There is a problem with the first 64K of system memory.
4. beeps system timer not operational. There is problem with the timer(s) that control functions on the motherboard.
5. beeps Processor failure. The system CPU has failed.
6. beeps Gate A20/keyboard controller failure. The keyboard IC controller has failed, preventing gate A20 from switching the processor to protect mode.
7. beeps Virtual mode exception error.
8. beeps Video memory error. The BIOS cannot write to the frame buffer memory on the video card.
9. beeps ROM checksum error. The BIOS ROM chip on the motherboard is likely faulty.
10. beeps CMOS checksum error. Something on the motherboard is causing an error when trying to interact with the CMOS.
11. beeps Bad cache memory. An error in the level 2 cache memory.
1 long beep, 3 short A failure in the video system.
1 long beep, 8 short display test failure.
BIOS Beep Codes
Phoenix Beep Codes
For example, 1-2-3 indicates one beep, followed by a pause and three beeps. Phoenix version before 4.x use 3-beep codes, while Phoenix versions starting with 4.x use 4-beep codes.
4-Beep Codes
Beep Code Meaning
1-1-3-2
1-1-3-3
1-2-1-2
1-2-3-3 DMA error.
1-3-3-3
1-3-4-1
1-4-1-3
1-4-2-4 CPU error.
1-4-3-1
1-4-3-2
1-4-4-1
1-4-4-2
2-1-1-3
2-1-2-4
2-1-3-1
2-1-1-3
2-1-4-3
2-2-1-3
2-2-2-1
2-2-3-1 IRQ error.
2-3-1-1
2-3-2-3
2-3-4-1
2-3-4-1
2-3-4-3
2-4-2-1 RTC error.
2-4-4-1 IRQ error.
3-1-1-1
3-1-1-3
3-1-2-1
3-1-3-1
3-1-4-1
3-2-1-1
3-2-2-3
3-2-3-1
3-2-4-3 IRQ error.
3-3-1-1 RTC error.
3-3-3-3
3-3-4-1
3-3-4-3
3-4-1-1
3-4-1-3
3-4-2-1
3-4-2-3
3-4-3-1
3-4-4-1
4-2-1-1
4-2-1-3
4-2-2-3
4-2-3-1
4-2-3-3
4-3-1-3
4-3-1-4
4-3-2-1
4-3-2-2
4-3-3-1
4-3-4-1
4-3-3-2
4-3-3-3
3-Beep Codes
Beep Code Meaning
1-2-2
1-3-2
1-3-3
3-1-3
3-3-1
3-3-2 CMOS error.
on Dec 31, 2009 | Computers & Internet
How can I translate the motherboard beeps on startup
AMI Beep Codes
Beep Code Meaning
BIOS Beep Codes
Phoenix Beep Codes
4-Beep Codes
Beep Code Meaning
1-1-3-2
1-1-3-3
1-2-1-2
1-2-3-3 DMA error.
1-3-3-3
1-3-4-1
1-4-1-3
1-4-2-4 CPU error.
1-4-3-1
1-4-3-2
1-4-4-1
1-4-4-2
2-1-1-3
2-1-2-4
2-1-3-1
2-1-1-3
2-1-4-3
2-2-1-3
2-2-2-1
2-2-3-1 IRQ error.
2-3-1-1
2-3-2-3
2-3-4-1
2-3-4-1
2-3-4-3
2-4-2-1 RTC error.
2-4-4-1 IRQ error.
3-1-1-1
3-1-1-3
3-1-2-1
3-1-3-1
3-1-4-1
3-2-1-1
3-2-2-3
3-2-3-1
3-2-4-3 IRQ error.
3-3-1-1 RTC error.
3-3-3-3
3-3-4-1
3-3-4-3
3-4-1-1
3-4-1-3
3-4-2-1
3-4-2-3
3-4-3-1
3-4-4-1
4-2-1-1
4-2-1-3
4-2-2-3
4-2-3-1
4-2-3-3
4-3-1-3
4-3-1-4
4-3-2-1
4-3-2-2
4-3-3-1
4-3-4-1
4-3-3-2
4-3-3-3
3-Beep Codes
Beep Code Meaning
1-2-2
1-3-2
1-3-3
3-1-3
3-3-1
3-3-2 CMOS error.
Jul 26, 2012 | Sony VAIO PCV-RX850 (T99861067) PC Desktop
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
E03 error code
Error Codes
f16 N/A
Aug 09, 2010 | Siemens WTXD8300 Electric Dryer
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
Bios Beep code
(I'm IT, I use these codes to trouble shoot hardware issues at my job. Enjoy) cold.gif
BIOS Beep Codes
When a computer is first turned on, or rebooted, its BIOS performs a power-on self test (POST) to test the system's hardware, checking to make sure that all of the system's hardware components are working properly. Under normal circumstances, the POST will display an error message; however, if the BIOS detects an error before it can access the video card, or if there is a problem with the video card, it will produce a series of beeps, and the pattern of the beeps indicates what kind of problem the BIOS has detected. Because there are many brands of BIOS, there are no standard beep codes for every BIOS.
AMI Beep Codes
Beep Code Meaning 1 beep DRAM refresh failure. There is a problem in the system memory or the motherboard. 2 beeps Memory parity error. The parity circuit is not working properly. 3 beeps Base 64K RAM failure. There is a problem with the first 64K of system memory. 4 beeps System timer not operational. There is problem with the timer(s) that control functions on the motherboard. 5 beeps Processor failure. The system CPU has failed. 6 beeps Gate A20/keyboard controller failure. The keyboard IC controller has failed, preventing gate A20 from switching the processor to protect mode. 7 beeps Virtual mode exception error. 8 beeps Video memory error. The BIOS cannot write to the frame buffer memory on the video card. 9 beeps ROM checksum error. The BIOS ROM chip on the motherboard is likely faulty. 10 beeps CMOS checksum error. Something on the motherboard is causing an error when trying to interact with the CMOS. 11 beeps Bad cache memory. An error in the level 2 cache memory. 1 long beep, 2 short Failure in the video system. 1 long beep, 3 short A failure has been detected in memory above 64K. 1 long beep, 8 short Display test failure. Continuous beeping A problem with the memory or video. BIOS Beep Codes
Phoenix Beep Codes
Phoenix uses sequences of beeps to indicate problems. The "-" between each number below indicates a pause between each beep sequence. For example, 1-2-3 indicates one beep, followed by a pause and two beeps, followed by a pause and three beeps. Phoenix version before 4.x use 3-beep codes, while Phoenix versions starting with 4.x use 4-beep codes. Click here for AMI BIOS beep codes. 4-Beep Codes Beep Code Meaning 1-1-1-3 Faulty CPU/motherboard. Verify real mode. 1-1-2-1 Faulty CPU/motherboard. 1-1-2-3 Faulty motherboard or one of its components. 1-1-3-1 Faulty motherboard or one of its components. Initialize chipset registers with initial POST values. 1-1-3-2 Faulty motherboard or one of its components. 1-1-3-3 Faulty motherboard or one of its components. Initialize CPU registers. 1-1-3-2 1-1-3-3 1-1-3-4 Failure in the first 64K of memory. 1-1-4-1 Level 2 cache error. 1-1-4-3 I/O port error. 1-2-1-1 Power management error. 1-2-1-2 1-2-1-3 Faulty motherboard or one of its components. 1-2-2-1 Keyboard controller failure. 1-2-2-3 BIOS ROM error. 1-2-3-1 System timer error. 1-2-3-3 DMA error. 1-2-4-1 IRQ controller error. 1-3-1-1 DRAM refresh error. 1-3-1-3 A20 gate failure. 1-3-2-1 Faulty motherboard or one of its components. 1-3-3-1 Extended memory error. 1-3-3-3 1-3-4-1 1-3-4-3 Error in first 1MB of system memory. 1-4-1-3 1-4-2-4 CPU error. 1-4-3-1 2-1-4-1 BIOS ROM shadow error. 1-4-3-2 1-4-3-3 Level 2 cache error. 1-4-4-1 1-4-4-2 2-1-1-1 Faulty motherboard or one of its components. 2-1-1-3 2-1-2-1 IRQ failure. 2-1-2-3 BIOS ROM error. 2-1-2-4 2-1-3-2 I/O port failure. 2-1-3-1 2-1-3-3 Video system failure. 2-1-1-3 2-1-2-1 IRQ failure. 2-1-2-3 BIOS ROM error. 2-1-2-4 I/O port failure. 2-1-4-3 2-2-1-1 Video card failure. 2-2-1-3 2-2-2-1 2-2-2-3 Keyboard controller failure. 2-2-3-1 IRQ error. 2-2-4-1 Error in first 1MB of system memory. 2-3-1-1 2-3-3-3 Extended memory failure. 2-3-2-1 Faulty motherboard or one of its components. 2-3-2-3 2-3-3-1 Level 2 cache error. 2-3-4-1 2-3-4-3 Motherboard or video card failure. 2-3-4-1 2-3-4-3 2-4-1-1 Motherboard or video card failure. 2-4-1-3 Faulty motherboard or one of its components. 2-4-2-1 RTC error. 2-4-2-3 Keyboard controller error. 2-4-4-1 IRQ error. 3-1-1-1 3-1-1-3 3-1-2-1 3-1-2-3 I/O port error. 3-1-3-1 3-1-3-3 Faulty motherboard or one of its components. 3-1-4-1 3-2-1-1 3-2-1-2 Floppy drive or hard drive failure. 3-2-1-3 Faulty motherboard or one of its components. 3-2-2-1 Keyboard controller error. 3-2-2-3 3-2-3-1 3-2-4-1 Faulty motherboard or one of its components. 3-2-4-3 IRQ error. 3-3-1-1 RTC error. 3-3-1-3 Key lock error. 3-3-3-3 Faulty motherboard or one of its components. 3-3-3-3 3-3-4-1 3-3-4-3 3-4-1-1 3-4-1-3 3-4-2-1 3-4-2-3 3-4-3-1 3-4-4-1 3-4-4-4 Faulty motherboard or one of its components. 4-1-1-1 Floppy drive or hard drive failure. 4-2-1-1 4-2-1-3 4-2-2-1 IRQ failure. 4-2-2-3 4-2-3-1 4-2-3-3 4-2-4-1 Faulty motherboard or one of its components. 4-2-4-3 Keyboard controller error. 4-3-1-3 4-3-1-4 4-3-2-1 4-3-2-2 4-3-3-1 4-3-4-1 4-3-4-3 Faulty motherboard or one of its components. 4-3-3-2 4-3-3-4 IRQ failure. 4-3-3-3 4-3-4-2 Floppy drive or hard drive failure. 3-Beep Codes Beep Code Meaning 1-1-2 Faulty CPU/motherboard. 1-1-3 Faulty motherboard/CMOS read-write failure. 1-1-4 Faulty BIOS/BIOS ROM checksum error. 1-2-1 System timer not operational. There is a problem with the timer(s) that control functions on the motherboard. 1-2-2 1-2-3 Faulty motherboard/DMA failure. 1-3-1 Memory refresh failure. 1-3-2 1-3-3 1-3-4 Failure in the first 64K of memory. 1-4-1 Address line failure. 1-4-2 Parity RAM failure. 1-4-3 Timer failure. 1-4-4 NMI port failure. 2-_-_ Any combination of beeps after 2 indicates a failure in the first 64K of memory. 3-1-1 Master DMA failure. 3-1-2 Slave DMA failure. 3-1-3 3-1-4 Interrupt controller failure. 3-2-4 Keyboard controller failure. 3-3-1 3-3-2 CMOS error. 3-3-4 Video card failure. 3-4-1 Video card failure. 4-2-1 Timer failure. 4-2-2 CMOS shutdown failure. 4-2-3 Gate A20 failure. 4-2-4 Unexpected interrupt in protected mode. 4-3-1 RAM test failure. 4-3-3 Timer failure. 4-3-4 Time of day clock failure. 4-4-1 Serial port failure. 4-4-2 Parallel port failure. 4-4-3 Math coprocessor.
Oct 19, 2008 | Computers & Internet
24 people viewed this question
k24674
