Question about Samsung Cell Phones
I have a samsung sound bar, and a 12 button remote, I'm blind, and cannot see the buttons, can someone tell me what the buttons are?
I know that there are 3 buttons that I can find, a power button, and the volume up and down controls. but don't know what the other 9buttons are. The only thing I see in regards to it's name in my bluetooth section on my iPhone is: end of text [Samsung] Soundbar J-Series
SOURCE: Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Posted on Jan 26, 2008
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
Posted on Mar 19, 2008
SOURCE: direct tv remote control - tv volume
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Posted on Jul 29, 2008
andy4254
  • 226 Answers
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
Posted on Apr 28, 2009
SOURCE: Air conditioner stop working after fall and lack
buy a f u c k i n g new one ya cheap c u n t
Posted on Oct 11, 2009
Nakamochi no 1b sound bar, display model no remote, buttons on unit non responsive, any suggestions like codes for Samsung remote, or scrap
Unless your Samsung remote control is universal, you are unlikely to find a code for your Yakamichi sound bar.
Nov 26, 2017 | Samsung Televison & Video
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
I hooked up my soundbar using the HDMI out (TV) port from bar to HDMI in port on my Philips TV power is on bar however I can't get any sound out of bar. But just audio cables worked what to do?
OK, If its the Samsung Sound Bar, this item should have 2 HDMI input, 1 3.5mm audio jack input and a digital audio input (fiber optic). Since there are various input, the remote control should have a source button, or it will probably read O/A Input, this is to change thru the inputs from the sound bar. If you connected your TV HDMI output to HDMI 1 from the Sound Bar, then press the source button to reach HDMI 1, maybe it will be display with a different name, like sound 1, or DIGI.1 Give it a shot and let me know in the comment section. Good luck.
Dec 19, 2015 | Samsung HW-H450 2.1 Channel 290 Watt...
Free subscription with code With new Sony TV
Syncing Comcast remote with Samsung Sound Bar. 1 Turn on the Audio/Other you are programming. 2 Press and release the "AUX" button on your Universal remote. 3 Press and hold the "Setup" button on your remote until the button blinks twice. 4 Type in the 5-digit code using the number buttons. Most likely code 21014 Others to try 20045 What worked with ours was 32609. We have a Samsung Crystal Surround Air Track (bought 12/2013). 5 If the code is correct, you will get 2 blinks. If the code is incorrect, you will get one long blink.
Dec 29, 2013 | Televison & Video
Samsung AH59-02341A remote control problems
To whom it concerns, I'm wanting to know which button on the following Samsung remote I press to adjust the base in the subwoofer & adjust the treble??.... I'm finding with the surround sound system that this remote functions with that base is way to heavy & the treble/clarity of voice is not that clear unless the volume is way up....
Model of Samsung remote: "AH59-02341A"
If someone knows how to change these option functions for what I speak off above please let me know, Your help would be appreciated.
Email answer to: easts_ash@yahoo.com
Feb 13, 2013 | Televison & Video
Three digit code for ilive sound bar
Hi Scott, my name is Cheri Torres and I work with the DISH Network Internet Response Team. I came across your post and wanted to help! I will list here for you the best code for your iLive sound bar and also the instructions for addressing the remote to your sound bar. I hope you find this information useful and if you have further questions please let me know!
The best code 2835
The instructions for addressing the remote.
1. Press and hold down the AUX button until all the other mode buttons light up.
2. Enter the code 2835.
3. Press the pound(#) button once.
4. Test the functionality of your iLive sound bar.
Jan 18, 2012 | iLive Itp180b Ipod(r)/iphone(r) Speaker...
Need help syncing my Comcast remote control to a Samsung Crystal Surround AirTrack sound bar. Is there a remote code for this?
Go to the following website to look up your particular Comcast remote and look through the remote codes. My guess if there is a code, it will be under audio equipment. Good luck : )
http://customer.comcast.com/Pages/HelpNFC.aspx?print=false&id=remotes
Jul 25, 2011 | Televison & Video
I Have a 5.3 IR Remote and a vizio VSB200 Sound Bar. The remote will not program to the Sound Bar. The Optical Audio is connected to the TV. What do I need to do.
lojr,
We have code to use with amplifiers, TVs, VCRs, and DVD players. I do not have a code that will work on this sound bar. What is the code you are trying to use? Did Vizio supply a code with your sound bar. They do have codes to use for their TVs to program DISH remotes. Please let me know if you have a code or you can contact Vizio to see if they have a code available.
I have provided the Power Scan instructions on programming the remote to a sound bar. Use the VCR button to attempt to program the sound bar.
If you have further questions, please post it here.
Ray Calo
DISH Network - Executive Offices
Power Scan Instructions Power Scan Instructions
1. While at the sound bar location, point the remote at the sound bar. Press and hold the VCR MODE button on the remote until all four MODE buttons at the top of the remote light up.
filestream.ashx?id=435
2. Press the RECEIVER POWER button on the remote.
filestream.ashx?id=436
3. Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the sound bar turns off. This process may take several minutes.
filestream.ashx?id=438
4. Press POUND (#) on the remote. The VCR MODE button will flash three times.
filestream.ashx?id=440(VCR button instead of TV button)
5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press VOLUME on the remote to confirm the remote controls the sound bar. If this does not work, return to Step 1.
filestream.ashx?id=442
Remember to press the SAT MODE button to return to the Satellite mode to change channels.
Jan 13, 2011 | DISH Network IR Remote Control
Need dish code for remote for vizio soundbar
Hey there, this is Cheri Torres with DISH Network customerservice. I wanted to see if I could help you with the question you posted aboutthe Vizio sound bar. I was unfortunately not able to find any codes for theVizio sound bar. Another option you can try is running a channel scan to findyour code that will work best to control your sound bar. I hope that theseinstructions are useful to you. If you have any further questions or concernsplease feel free to post back here or email me at Cheri.Torres@Dishnetwork.com.
Remote: All Remotes (except Basic)
    1. With the desired equipment on, press and hold the correct Mode button until all mode button back lights illuminate, then release.
    2. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button
      • Press 0 for a TV
      • Press 1 for a VCR/DVD
      • Press 2 for any other device.
      Then Press STAR (*)
    3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
    4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Dec 27, 2010 | DISH Network IR Remote Control
Remote codes for sentry rmc10 really big universal remote
i need the codes for the Sentry Big universal remote for a philips magnavox or for someone to tell me how to do the code search
Jan 28, 2009 | Samsung DLP HL-P5663W 56" TV
Cell Phones Logo
29 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
