Under what circumstances is it desirable to use a graphical user interfaceGUI, and when is it better to use a command language to address a computer?
1. Under what circumstances is it desirable to use a graphical user interface (GUI), and when is it better to use a command language to address a computer?
    ?When we want to make our program easier to use.
    ?It uses under desirable interaction with human-interface devices such as keyboards, mice and touchscreens.
Dec 19, 2016 | Computers & Internet
After changing from English to Spanish having problems opening
Follow the Set language, site, time zone link under Account Settings. Make sure the language (or language variant) you want to use as the user interface language for Yahoo! Mail is listed under Languages. Click Set as primary next to the desired language.see more
Try Yahoo Mail in Different Language
Sep 21, 2017 | Yahoo Mail
I am trying to install a lp 2824 plus zebra label printer and i need to know whether to select epl or zpl?
You should probably select ZPL, but that depends on which program you will use together with the printer.
Jun 20, 2011 | Zebra LP 2824 Printer
I forget a pasward air live 5400cpe now what i do
you would need to directly connect your computer ( Laptop ) and access point.
check ip address of your access point in Command prompt = ipconfig
once you have your access point's ip, pull up a browser ( Internet Explorer ) and place ip address on the address bar and press enter. once your inside the GUI (Graphic User Interface ) of your AP, click wireless security so you can see your password.
May 31, 2011 | Computers & Internet
How we can change windows7 langueg for exmple fraench to english
Windows 7 language packs are available for computers that are running Windows 7 Ultimate or Windows 7 Enterprise. The Windows 7 language packs can be installed only from the Optional Updates section in Windows Update. However, these language packs are not available on the Microsoft Windows Server Update Services (WSUS) server or through the Microsoft Download Center.
To download and install a Windows 7 language pack, follow these steps:
  1. Start Microsoft Update. To do this, click Start Collapse this imageExpand this image vistastartbutton.jpg, type Microsoft Update in the Start Search box, and then click Microsoft Update in the Programs list.
  2. Click the optional update links for the language packs.
  3. Under the Windows 7 Language Packs category, select the desired language pack.
    Note If you install many additional language packs, the disk space and system performance are affected. In particular, disk space and system performance are affected during servicing operations, such as Service Pack installations. Therefore, we recommend that you only add a language pack to your computer if you will use the language pack.
  4. Click OK, and then click Install updates to start the download and installation process.
    When you install a language pack, you can change the interface language of Windows 7 to the language that you select.
    Language packs also let multiple users who share a computer select distinct display languages. For example, one user can select to see the dialog boxes, menus, and other text in Japanese, whereas another user can select to see the same content in French.
    To change the display language, follow these steps:
    1. Click Start, and then type Change display language in the Start Search box.
    2. Click Change display language.
    3. In the drop-down list that appears, select the language that you want, and then click OK.
    To uninstall a language pack, follow these steps:
    1. Click Start, and then type Uninstall display language in the Start Search box.
    2. Click Install or uninstall display languages.
    3. Click Uninstall display languages.
    4. Select the language or the languages that you want to uninstall, and then click Next.
    5. Follow the rest of the steps to uninstall this language or these languages.
    After you install the desired language packs, you can hide unwanted language packs in Windows Update. To hide unwanted language packs in Windows Update, follow these steps:
    1. Click the Windows 7 Language Packs category in the Select the updates you want to install page to highlight all the language packs.
    2. Right-click the highlighted updates, and then select Hide update.
Dec 21, 2010 | Sony VAIO Notebook
Terminal command for graphic screen
At its heart linux is a text based operating system. You enter commands and view output as text. One of the many great things about Ubuntu is that it comes with a graphical user interface as well. Most users prefer the graphical interface to the text interface, and have it start automatically. If your computer is starting in text mode rater than graphical mode, you can simply enter the command 'startx' without the quotes and then press the enter key.
On most computers, that's all there is to it, but on very few computers, you will need proper permissions to start the graphical system. If that is the case on the computer you are using, then use the command 'sudo startx' and then enter your password.
Good Luck,
-Josh
Oct 21, 2010 | Canonical Ltd. Ubuntu
About operating system
Operating Systems Means, Tips & Tools. An operating system (sometimes abbreviated as "OS") is the program that, after being initially loaded into the computer by a boot program, manages all the other programs in a computer. The other programs are called applications or application programs. The application programs make use of the operating system by making requests for services through a defined application program interface (API). In addition, users can interact directly with the operating system through a user interface such as a command language or a graphical user interface (GUI).
Jul 13, 2010 | Answer Carbon Expert BMX Handlebar
HOW DO I BLOCK AN IP?...IM GETING HACKED, IT WONT STOP
The easiest means to block IP addresses in Windows XP is to use Internet Protocol Security (IPSec) filtering rules. The primary reason to block IP addresses is to protect your computer from network-based threats, such as computer worms, viruses and other malware. To block IP addresses in Windows XP, you will need to activate and configure IPSeccmd, the firewall that comes bundled with Windows XP. IPSeccmd does not come preinstalled with XP on your computer. It can be found on Disk 2 of your service pack upgrade or downloaded from Microsoft directly.
  1. Install IPSeccmd from your Window's XP Service Pack 2 installation disk.
  2. Step 2 Open the Command Prompt on your computer by selecting "Start > Run" from the primary file menu and type the word "cmd" in the blank text field that appears.
  3. Step 3 Enter the following command at the DOS command prompt to block a specific communication type (UDP or TCP) and port number on your computer:
    "IPSeccmd.exe -f [*=0:PortNumber:Protocol]
  4. Step 4 Open the user interface for IPSeccmd on your desktop, and select the "General" tab under the "Policy" section. Choose the "IP Block" option and enter the specific IP address of the host(s) that you desire to block. Exit the application when complete.
Jul 07, 2009 | Microsoft Windows XP Home SP3 for PC
Control panel menu is not in english.
Here are 2 ways of changing that. I changed mine to Portugese once. Had a heck of a time figuring out what the menu said LOL. Both proceses will change it back. To change the language used for the text on the front panel:
  1. On the front panel, with Menus highlighted, press the OK key.
  2. Scroll to the Printer Setup Menu by pressing the Up Arrow or Down Arrow key.
  3. Press the OK key.
  4. Scroll to Set Front Panel Language by pressing the Up Arrow or Down Arrow key.
  5. Press the OK key.
  6. Scroll to the desired language by pressing the Up Arrow or Down Arrow key.
  7. Press the OK key to save the selected setting
This is how you change it via your computer.
  1. Open a web browser on your pc.
  2. Type the IP address of the printer into the address area and press return.
  3. Select the Properties tab when the page is done loading.
  4. Look in the left hand column for the + General folder.
  5. Click on the + one time to open the folder.
  6. Under the general folder you will see a subfolder named Printer Defaults.
  7. Click on the Printer Defaults folder one time and you will see a new column open on the right side of the page named Printer Defaults.
  8. In the first box, User Preferences, you will see a header for; Set front panel language with the default setting.
  9. Click on the down arrow and a list of different languages will open.
  10. Select the desired language.
  11. Scroll down the page and under the last box you will see two tabs named Save Changes and Discard Changes.
  12. Select Save Changes one time.
  13. Once you have pressed Save Changes you should get a box that opens up and states; Request Acknowledged; No errors were reported.
  14. Look at the front panel of the printer and the language should be changed to the language you selected above.
Dec 09, 2008 | Xerox Phaser 6200DP Laser Printer
HP 3845 Printer language problem
Use the following link for the updates:
HP Deskjet 3840 Printer series - (Windows) Setup Poster
HP Deskjet 3840 Printer series - (Windows) User's Guide
or
in address bar copy paste the following address:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=372330&lc=en&cc=us&dlc=en&lang=en&cc=us
From the above stated link u can download the desired setup manual and posters for the printer.
Dec 18, 2007 | HP Deskjet 3845 InkJet Printer
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
