Question about iLO 3200 32 in. LCD Television
Can not adjust volume
Can't adjust volume or turn on television with remote, but can change channels
    Problem Solver:
  • 6 Answers
Is it the original remote that came with the TV? If you're using a universal remote or one that came with your audio receiver or DVD player or whatever then you may have accidentally switched modes to audio or something. Be sure the TV mode is selected.
Was it working previously?
Posted on Jul 21, 2009
Remote fall on floor and now it is stuck on one channel and I can not turn off the TV or change a channel or lower the volume
Hi, well you can do everything from the axtual TV itself, have a look on the TV you will find a setof buttons/keys. these allow you to controll almost everything that the remote can do.
here you can change channel change volume etc.
The buttons usually there are 6- 7 marked On/Off, Channel up/down, Volume Up/Down, Enter/OK & Menu. Now pressing these will bring up the onscreen display and you can adjust what you wish.
Now with the remote, it's probably best to obtain a new one..
Sometimes disassembly may fix it, but it sounds like it has a bad problem.
To ensure it doesn't interfere remove the batteries.
Aug 19, 2010 | Televison & Video
Controller will only turn equipment on and off. Can't do anything else, ie: adjust volume, change channel, etc. Universal MX-900 Remote
Hello, Reset the remote control and use with the equipment . If it does adjust volume, change channel. then use have to get another one of different model
May 20, 2010 | Universal MX-900 Remote Control
When I adjust the volume on the remote control it changes the channel, but not on every occasion.
Hey,
This could be due to the accumulation of dust inside the remote control. You can try to open up the controller and just clean it up.
Thanks
Apr 15, 2009 | Televison & Video
TV won't change channels or adjust volume
Do you have a universal remote? If the batteries are taken out for a little period of time, the remote will loose the codes and they will have to be reset. You can find the codes by google universal remote codes.
If you have a factory remote that came with the television, than it may be faulty or the sensor on remote or tv may need to be cleaned.
Mar 11, 2009 | Televison & Video
How to program ilo TV w/universal remote to play DVD
I Believe You Can Go To Channel 2 And Right Below Those Channels Are The 3 Video Channels Turn On Your Dvd Player And Go Through Them. If That Doesn't Work Try Looking At The Buttons On Your Tv For A Tv Video. Make Sure You Dont Have A Tv Video Button On Your Remote If You Do Then Just Click It Till You Find The Appropriate Video Channel.
Jan 05, 2009 | iLO 3200 32 in. LCD Television
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Samsum PLH403W service menu
Here is how you get to the service menu. Just be sure to write down anything you change in case you want to change it back.
1. TV turned off
2. Press 'Mute' then '182' then 'Power' buttons on the remote.
You are now in the Adjustment mode
4. Use the 'Channel up'or"Channel dwn' to select the category.
5. Use the 'Volume up or dwn' to enter the category.
note:Some models may not have Category Selection.
6. Use the 'Channel up or dwn' buttons to select item to be adjusted.
7. Write down the old value of the item before changing.
8. Use Volume up and down adjust the value.
9. When you have made all the adjustments you want turn the set off to exit.
Feb 01, 2008 | Samsung PLH403W 40" Rear Projection...
Service menu
1. TV turned off
Jan 23, 2008 | Televison & Video
iLO 3200 32 in. LCD Television Logo
82 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
