Question about Krups Coffee Makers & Espresso Machines
Solution to fix it since its not switching on
E2 problem?how can i fix it?i have reset my washing and it doenst fix anything?
it appears when its going to spin the dryer :) THANKS NEED RESPONSE ASAP
Oct 14, 2014 | Washing Machines
Wipers don't stop why
the wiper motors have a sustain function inside
this magic switch, keeps wiper going it driver kill it with the switch.
preventing mid windows, stops. (safety and vision issues)
so that switch can break, and do what you said.
ive actually rebuilt them. and fixed the switch, many look mangled .
its inside the motor cover , below the wires connected there.
fix it, or replace it.
or the start up wire is hot all time.
the start up wire is the switch wire.
you turn off the wiper switch and its output goes to 0v, that be good
if stuck at 12v, its bad.
one way to check that is pull the switch connector (combo)
does wiper stop, yes, bad wiper switch
no,then bad wiper motor guts.
Dec 24, 2013 | Toyota Matrix Cars & Trucks
Turn signals work but they don't return, how do I fix?
there's a little plastic piece inside the turn switch called a cancelling cam that broke or quit working. The only fix to get switch to return is replacing the turn signal switch. I don't think you can buy the part separately.
Dec 06, 2011 | Cars & Trucks
Bulb in four wheel drive dash switch burned out
if it burned out, but the 4wd works, the only way to fix it is to remove the dash. you might have to replace the switch, or just the bulb. a cheap fix, but one that is not fun to fix.
Dec 10, 2010 | 1998 Ford Expedition
Brake lights remain on when engine off and key removed. Fix how?
Hi I'm litoshop your problem is not that hard to fix under the dash on your brake pedal you have a switch, that's your brake light switch it may need adjustment look under the dash some switch will adjust by screwing it in if yours don't have adjustment then you need to replace the switch good luck. if this information has been helpful please let us know thank you
Jul 29, 2009 | 1991 Nissan Pickup
Digitech RP 90 foot switch is not working
I removed the back cover, unscrewed the two (of 4) screws holding down the circuit board, replaced them again, and it worked fine.
Jan 11, 2009 | Music
Two way lighting switches
This switch system is not wired correctly which makes me wonder if the "qualified" electrician is actually qualified. Since the system is not working properly, I would first request that the original electrician comeback to fix it at no charge to you. Failing that, get another to trace the problem and fix it. I would get this fixed ASAP as there is the possibility of short circuits and fire if not addressed.
Oct 01, 2008 | Electrical Supplies
Psp switch is broken
You should get it fixed. You can get it fixed on just type in psp repair and you will see people who fix them.
May 31, 2008 | Sony PlayStation Portable (PSP) Console
Laptop switch
try to spray the switch with "Contact Spray 90" ur switch maybe oxidised i think it will solve
Nov 28, 2007 | Fujitsu Siemens AMILO Pro V7010 Notebook
Coffee Makers & Espresso Machines Logo
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
