Question about Krups Coffee Makers & Espresso Machines
I need to know where to fix the machine - Krups Coffee Makers & Espresso Machines
Cs6000i. What caused it to pop and smoke?
You need to fix it. US machines are wired for 120VAC, 60Hz. Other countries are often 220V, 50Hz. Some machines have a switch that allows you to select. Some models have auto-switching power supplies that can handle either. Obviously yours did not. You most likely have damaged, at a minimum, the power supply. Once it is fixed, if it does not have a dual-voltage switch, you'll need to get a voltage adapter for it.
Nov 17, 2015 | Sewing Machines
How to adjust trimmer on tajima tumx
WIll need more information about what you are trying to adjust?
Machine functions a mechanical cut, but the thread wasn't cut?
Cutter has timing to be set or replace the fixed blade. are two basic possibilities. I need to know what it's doing cut wise? to know what to adjust.
Embroidery Services
San Diego, CA
Nov 19, 2014 | Sewing Machines
Mainboard/mother board repair for husqvarna viking #1
look in the yellow pages of the phone book
when you find a sewing machine shop ask them if they work on your model of sewing machine.
if they do, when you get your machine back make sure to sew on the machine that very day so you know it works correctly, if it doesn't let them know about it, make sure you get a reciept showing what was done to the machine, the price you paid to have it fixed is on the reciept.
Mar 05, 2012 | Husqvarna Sewing Machines
My Fisher and Paykel Smart Drive 501 toploading machine won't finish its always gets stuck on the spin cycle and starts beeping. This happens every time not just occasionally. How can i fix...
need to have a look at the machine, how old is the machine 15 years roughly, Yes this is when the machine plays up, hard to find spare parts. If you are getting rid of the machine let me know. 0412676652 Since I want to learn fixing the machine, I did fix one of this model long time ago
Jul 01, 2010 | Fisher and Paykel Fisher & Paykel Washer
My roper wash machine is leaking. is it worth
check when it's leaking during the cycle.
If the fill hose has become unhooked from the outer drum of the machine, it'll just dump water all over the floor... it'll leak out of the case of the machine, but it's an easy fix... you simply open the machine, reinstall the hose into the drum or you may have to replace the hose...washing machines will last a good long's worth the trouble to fix...let me know if you need help opening it up.
This can happen if the machine is overloaded... I had a laundromat and this happened alot because people were cheeeeep and wanted to overstuff the machine thinking they'd get a better deal...not true...dirtier clothes and broken machines....
Aug 05, 2009 | Roper RAB2121KW Top Load Washer
I believe there is a silver chain necklace stuck in the motor and now the machine won't spin! Is it worth fixing??? How much do you think it would cost for the maytag repairman to fix? Approximate is...
i would say it would defantly be worth looking at if it just something stuk in the pump or motor and no parts are needed it would be worth the repair if it needs a part the repair man should let you know how much the part is and you can compair that to the price of a new machine they start around 300 -350 a service call have the machine checked could run between 50 - 100 don't know what people charch where you are
Jan 21, 2009 | Maytag PAV2300 Top Load Washer
Can't open Pfaff Select 3.0 Sewing Machine to fix timing
I found an electric drill with a hex bit and that did the trick!
Dec 30, 2008 | Sewing Machines
Need Parts for an older Baby Lock Serger
Contact Steve at they have alot of parts machines they can help.
Aug 04, 2008 | Sewing Machines
Setting fax number for my machine
Thanks for the quick return offer. We did get it fixed by taking the machinea and cartridge to Staples and there was a gentleman there that knew the problems fix. Thanks again.
Mar 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Coffee Makers & Espresso Machines Logo
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
