Question about Krups Coffee Makers & Espresso Machines
My krups machine is not switching on - Krups Coffee Makers & Espresso Machines
Code 12 krups
There was no ejection switch pulse during 2x empty cycles. Inspect the switch or what activates the switch, check the wiring to the switch and PCB. Is the chamber clogged with grinds.
Jun 10, 2014 | Krups Small Appliances Espresso Machine
Error code 3 on krup xp7220
Direct from repair manual for your model, these are the possibilities
- Fault in the actuator high
position switch (mechanical or
- Distributor switch fault
- Faulty electronic boards
- Actuator switch short-circuited
Dec 08, 2013 | Krups XP Coffee Makers & Espresso Machines
Krups xp 7225 replaced piston, reassembled and is now dead, power switch seems ok and all wires firmly attached
Your Power Switch Part No Ms-0675088 need to change.,your
machine have appear any error No ? God Bless
Jul 23, 2012 | Krups XP7225 Espresso Machine
Can't get my Krups panini maker to start when it's plugged in. It has no on off switch.
I am sorry for my ignorance.
Ihad not relized that paninis were made in coffe machine ((-:
Mar 03, 2012 | Coffee Makers & Espresso Machines
My Krups XN2005 coffee machine switches itself off as soon as I try and brew coffee from the pod. Any suggestions?
My Krups Nespresso XN2005 machine turns itself off when I try press the start button- any solutions ?
Feb 21, 2011 | Krups Nespresso Essenza XN 2009 Espresso...
I just recieved a krups fnd1 i have all parts
You should have the main machine, the screw-top to the main machine, a handled cup that holds the grounds, and inside that should have a metal lining. Drain basin. Main body should have: Screw top, turn-switch, milk foamer attached.
Aug 29, 2009 | Krups Allegro FND111 Espresso & Coffee...
Error Code 9 on a Krups XP7240 Expresso machine
After I changed piston sealing I get the same error 09. It was caused by missing connection to the thermoblock temperature sensor. In my case both connectors for thermocouple were cracked. They are located directly on the body of thermoblock, below two fuses, covered by rubber housing. After I solder them again on the position error 09 disappeared. Unfortunately it is necessary to open at least front panel of the machine. Moreover I tink that there is also important to save polarity of those two cables.
Jun 06, 2009 | Krups XP4030 Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
