Question about Winter Sports
How do I ajust the boondocker on 05 ski-doo mach z 1000. It seems to be running rich and I have no power when I throttle up on it . ?
  • 85 Answers
SOURCE: I have a Ski doo 583 RAVE motor theat backfires
It sounds like you have a reed problem they should be in a "cage" just behind the carbs on the cylinder and if they were missing a piece or if they were cracked it would cause the engine to backfire. If they are in good condition they should close against the cage and stop the back pressure coming through the carbs.
Posted on Jan 21, 2010
  • 677 Answers
SOURCE: Sea doo jet ski won't get full throttle. It idles
I am not sure of the model that you have,so its a bit hard to help.If you have a seadoo and you want great help,I would go to seadooforum.Its the best site with really good,and also total knowledge of all things Seadoo.I have one also.The help is unsurpassed.I have a seadoo also.Hope this helps you
Posted on Feb 03, 2010
  • 635 Answers
SOURCE: quadrajet running rich, how to ajust
Turn your idle mixture screws IN to make it less rich.
Check the float height it may also contribute to rich running.
Smaller jets.
Posted on Apr 02, 2010
  • 1978 Answers
SOURCE: fuel mix in jetski is to oil rich need to lean out
Jet ski's do not have an adjustment on the oil pumps unless they are cable operated. Most just run off the end of the crankshaft. If the machine sits for a while and the oil pump seal is leaking. Oil will collect in the crankcase and take a few minutes of running to clear out. You can live with this, replace the pump, or block off the pump and pre-mix. A popular, cheap solution but a pain when it comes to refueling. As for the lack of power you probably have water corrosion in your carburetor nothing a simple cleaning won't cure.
Posted on Sep 03, 2010
SOURCE: my 93 ski-doo mxz 470 has trouble starting/when it
recoil rope routing?
Posted on Jan 28, 2011
1990 ski doo mach 1
You have dirt in the carburetor jets and or passages, clean the fuel tank and rebuild the carb.
Dec 20, 2016 | Winter Sports
How do I adjust seadoo RFI mixture?
There should be an adjustment screw that looks like a "t" on the side of each carb. Screw it in 1/8th turn at a time to lean it out. Too much and engine detonation. I would recommend getting the retrofit kit to block off the oil tank and run mix fuel. Then there are no issues with too lean/rich, oil pump failure, plugged oil filter, broken or collapsed oil lines etc.
Sep 03, 2014 | WSM 1999-2003 Sea Doo Gtx 951 Cc Jet Ski...
How to access idle screws
Big brass screws on each carb, left side of carb I think, not that easy to get at on the GTX, but you can turn them by hand
Mar 01, 2014 | Ski-Doo 2008 GTX Fan 550F
Ski doo engine troubleshooting
What is your Issue?
What are you troubleshooting?
What is it doing?
Lack of Power?
Engine Light?
Have you Checked your Compression?
Do you have a Dirty Carburator?
We need much more information..
Jan 02, 2014 | Ski-Doo 2010 MX Z TNT 600
Ski Doo's are known to have BAD KILL SWITCHES
DPM going bad
Dec 24, 2013 | Ski-Doo 2009 Summit Everest 146 800R Power...
Skidoo has no pick-up power
I am assuming that you have checked the following?
Replaced Spark Plugs
Cleaned the Needles (Making sure you can see through the Center of the Jet
Nov 30, 2013 | Ski-Doo 2006 Mach Z Adrenaline 1000 SDI
Jet ski
too rich, adjust thehigh idle screw
Jul 06, 2008 | 1997 Chevrolet Cavalier
Winter Sports Logo
137 people viewed this question
Top Winter Sports Experts
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
